    1.5k Posts 477 Posters 4.0m Views 477 Watching
    • BoxB Offline
      Are you saying that if you put your mouse on the words "Tool Palettes" you don't get round corner in the list that pops up? or haven't you found that list of toolbars yet.
        michelleyeo
        Yes, I don't get the round corner in the list
        • jeff hammondJ Offline
          @michelleyeo said:
          Dear TIG and Oxer,
          Many thanks for your reply.
          I've installed correctly and enabled the extensions however no sign for Roundcorner.
          Please helpppp
          according to your second picture, you haven't installed it correctly.. you're missing libFredo files.
          you can get that here:
          http://sketchucation.com/forums/viewtopic.php?t=17947
          (download the .rbz version underneath the word DOWNLOAD in the first post)
          to install it, go Sketchup (menu)-> Preferences-> Extensions..
          click the 'Install Extensions' button at the bottom then navigate to the libFredo .rbz file... it will be placed in the proper location for you..
          • W Offline
            wisar
            Great tool but I am wondering if I can undo the rounded corners if I want to revisit a design and make some changes like pushing and pulling a face?
            Cheers,
            W
            • mitcorbM Offline
              mitcorb
              Hi:
              You can undo the rounded corners while in the same session, but you cannot undo the round corners tomorrow.
              If you were using Blender you could simply switch it off, because rounded corners would be a modifier "channel"(?).
              In Sketchup, do the rounding on a separate copy, group or unique component of the original geometry.
              You could then save these copies out of your working file if you wish.
                Lyubov
                Please, help me to delete plugin from SketchUp Pro 2013, after Setting plugin Fredo6_Round Corner i decieded to delete him from foulder plugins, but now after openning SketchUp I have every time notice about that I have to install this plugin...(YOU MUST INSTALL LIBFREDO6 VERSION 5.2 OR HIGHER TO RUN FREDO ROUND CORNER)... Thank you so much for helping!! 😒
                • mitcorbM Offline
                  mitcorb
                  Hi, Lyubov:
                  Your question generates many questions.
                  Please visit this thread and see if an answer is there:
                  http://sketchucation.com/plugin/696-SketchUcationTools
                  Fredo6's RoundCorner is a very reliable plugin and requires a helper file called Libfredo. In fact, most if not all of his tools utilize the helper file.
                  See if the above helps and post back if you need further assistance.
                  Someone is sure to respond.
                  • frankflafyF Offline
                    frankflafy
                    is it compatible with su2014? im trying and still get error.
                      Round Corner is indeed compatible with SU2014. What error do you get? Just saying you get an error is useless.
                      Make sure you've installed the current version of Round Corner AND Libfredo6.
                        frankflafy
                        sorry i just copy paste old plugins to a new plugins folder. and i got screwed.
                        but it fixed. thanx community.
                          Frank, it has been posted all over Sketchucation that copying and pasting plugins from an older installation is not advised.
                            keramare
                            THANX again
                              Antonius43
                              Just do not understand, do I need to pay for this plugin to work? After following the instructions I cannot find the toolbar? What a waste!!!
                              • massimoM Offline
                                massimo Moderator
                                No.
                                What a waste!!!
                                Waste? this is a great and must have plugin and many people use it successfully.
                                Correct.
                                  Maybe you wil be more lucky with this!
                                  Now there is a sort of integration of it inside Join PusPushPull Interactive!
                                    It is free to download, install and use [but of course you are free to donate to authors]...
                                    If you have installed the Plugin properly [and how did you do that?]... then you might need to restart SketchUp and activate the it under Preferences > Extensions... and then activate its Toolbar...
                                    Also having read the Plugin's installation instructions... you will be aware that you also need to have 'LibFredo' downloaded and installed to make this work [that's free too 😉 ]
                                      synthkim1
                                      Thank u so much,,,it's amazing
                                      • Z Offline
                                        ZRaupp
                                        took me a few minutes to get it working, had to run Sketchup as administrator..
                                          Why? Where and how did you install the plugin?
                                          • Z Offline
                                            ZRaupp
                                            I installed plug-ins before i followed the steps and it works... .. ..
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 74
                                            • 75
                                            • 44 / 75
