    1.5k Posts 478 Posters 4.3m Views 478 Watching
      michelleyeo
      Dear TIG and Oxer,
      Many thanks for your reply.
      I've installed correctly and enabled the extensions however no sign for Roundcorner.
      Please helpppp
      • BoxB
        Are you saying that if you put your mouse on the words "Tool Palettes" you don't get round corner in the list that pops up? or haven't you found that list of toolbars yet.
          michelleyeo
          Yes, I don't get the round corner in the list
          • jeff hammondJ
            @michelleyeo said:
            Dear TIG and Oxer,
            Please helpppp
            according to your second picture, you haven't installed it correctly.. you're missing libFredo files.
            you can get that here:
            http://sketchucation.com/forums/viewtopic.php?t=17947
            (download the .rbz version underneath the word DOWNLOAD in the first post)
            to install it, go Sketchup (menu)-> Preferences-> Extensions..
            click the 'Install Extensions' button at the bottom then navigate to the libFredo .rbz file... it will be placed in the proper location for you..
            • W
              wisar
              Great tool but I am wondering if I can undo the rounded corners if I want to revisit a design and make some changes like pushing and pulling a face?
              Cheers,
              W
              • mitcorbM
                mitcorb
                Hi:
                You can undo the rounded corners while in the same session, but you cannot undo the round corners tomorrow.
                If you were using Blender you could simply switch it off, because rounded corners would be a modifier "channel"(?).
                In Sketchup, do the rounding on a separate copy, group or unique component of the original geometry.
                You could then save these copies out of your working file if you wish.
                • L
                  Lyubov
                  Please, help me to delete plugin from SketchUp Pro 2013, after Setting plugin Fredo6_Round Corner i decieded to delete him from foulder plugins, but now after openning SketchUp I have every time notice about that I have to install this plugin...(YOU MUST INSTALL LIBFREDO6 VERSION 5.2 OR HIGHER TO RUN FREDO ROUND CORNER)... Thank you so much for helping!! 😒
                  • mitcorbM
                    mitcorb
                    Hi, Lyubov:
                    Your question generates many questions.
                    Please visit this thread and see if an answer is there:
                    http://sketchucation.com/plugin/696-SketchUcationTools
                    Fredo6's RoundCorner is a very reliable plugin and requires a helper file called Libfredo. In fact, most if not all of his tools utilize the helper file.
                    See if the above helps and post back if you need further assistance.
                    Someone is sure to respond.
                    • frankflafyF
                      frankflafy
                      is it compatible with su2014? im trying and still get error.
                        Round Corner is indeed compatible with SU2014. What error do you get? Just saying you get an error is useless.
                        Make sure you've installed the current version of Round Corner AND Libfredo6.
                        • frankflafyF
                          frankflafy
                          sorry i just copy paste old plugins to a new plugins folder. and i got screwed.
                          but it fixed. thanx community.
                            Frank, it has been posted all over Sketchucation that copying and pasting plugins from an older installation is not advised.
                            • K
                              keramare
                              THANX again
                                Antonius43
                                Just do not understand, do I need to pay for this plugin to work? After following the instructions I cannot find the toolbar? What a waste!!!
                                • massimoM
                                  massimo Moderator
                                  No.
                                  What a waste!!!
                                  Waste? this is a great and must have plugin and many people use it successfully.
                                  Correct.
                                    Maybe you wil be more lucky with this!
                                    Now there is a sort of integration of it inside Join PusPushPull Interactive!
                                      It is free to download, install and use [but of course you are free to donate to authors]...
                                      If you have installed the Plugin properly [and how did you do that?]... then you might need to restart SketchUp and activate the it under Preferences > Extensions... and then activate its Toolbar...
                                      Also having read the Plugin's installation instructions... you will be aware that you also need to have 'LibFredo' downloaded and installed to make this work [that's free too 😉 ]
                                        synthkim1
                                        Thank u so much,,,it's amazing
                                        • Z
                                          ZRaupp
                                          took me a few minutes to get it working, had to run Sketchup as administrator..
                                            Why? Where and how did you install the plugin?
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 74
                                            • 75
                                            • 44 / 75
