    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 113.4k Views 95 Watching
      pepa
      @holmes1977 said:
      Im working alot more from home so using my Laptop
      -ASUS G74
      -i7 CPU @2.00Ghz
      -8 GB RAM
      -Win7 64bit
      SU8 Pro
      Im having problems with using this pluggin. I draw a simple rectangle, select the rectangle, select Subdivide selection, which divides the rectangle. I again select subdivide selection and I get a bug splat. I have tried this 10 times with the same result every time. Ive uninstalled the Artisan and re installed it, but still with the same result. This problem does not happen on my work computer. Do I need to delete all pluggins and slowly reinstall to see if there is a conflict?
      Hi I tried instal new vray 1.6 and started exactly same issue. If are you using new vray try turn it of in extension panel or uninstall it, works for me.. maybe some ruby conflict
      http://jsvizualizace.daportfolio.com/
      • holmes1977H Offline
        holmes1977
        @pepa said:
        @holmes1977 said:
        -ASUS G74
        -i7 CPU @2.00Ghz
        -8 GB RAM
        -Win7 64bit
        SU8 Pro
        BINGO
        You are so right. I turn off Vray4SU 1.6 beta and it works fine. Thanks so much. Im gona post this in the beta forum.
        Exaggeration makes a dull story better.
          The vRay plugin is notorious for causing conflicts in other plugins.
          • cottyC Offline
            cotty
            There seems to be a problem with this plugin and the new SU2014, any ideas how to solve it?
            my SketchUp gallery
              Carsten, it works fine for me. Make sure you've got the current version and didn't just move an old version over from an earlier SU version.
                kaas
                Strange, I reloaded the installer from Artisan's site, installed and same error occurs. Win7 X64
                  Win7 X64 here, too. It works as advertised.
                  Did you try copying your previously installed version over first? Maybe you need to make sure the Plugins folder is cleared out first. Are you installing it under Users/...AppData/...Plugins?
                  • cottyC Offline
                    cotty
                    I've installed a new version from the extension warehouse and this one is working! (Seems that it's different from the one on the artisan4sketchup website.)
                    my SketchUp gallery
                      PluginStore version updated to 1.2.3 SU2014 compatible
                        kaas
                        I removed the previously installed artisan_loader.rb and artisan folder. Installed in user/appdata/...etc/plugins (See image)
                        edit: removed image because now it works thanks to Cotty (see next post).
                          We can download Artisan from 3Dwarehouse ?
                            Time to get the eyes tested Pilou...2 mistakes already today πŸ˜•
                              Excellent! So it really was just updating to the current version.πŸ˜‰
                              • W Offline
                                Whaat
                                I appreciate everyone's patience as the plugins authors work to fix any remaining kinks with their plugins for SU2014. Although we have done our best to prepare for SU2014, some bugs only become apparent when it gets released to the masses πŸ˜„
                                Artisan 1.2.4 was released yesterday on
                                http://artisan4sketchup.com/download/
                                This version resolves a loading bug that was apparent if you have non-english characters in your user name.
                                The version on the Extension Warehouse will be updated as soon as the QA team reviews it.
                                Dale
                                • plot-parisP Offline
                                  plot-paris
                                  Hey Whaat,
                                  it seems that since SU2014 the undo-capability after a Subdivide and Smooth operation is broken.
                                  Ctrl + Z doesn't work any more. And if it does, its only on individual smoothing steps, rendering it useless.
                                  Has anyone else had these problems?
                                  PS: Once again: Thanks for this superb plugin. Every time I modify a terrain, it gives me great joy!
                                  • cottyC Offline
                                    cotty
                                    Ctrl+Z working fine here.
                                    my SketchUp gallery
                                    • W Offline
                                      Whaat
                                      @plot-paris said:
                                      Hey Whaat,
                                      Thanks for the report! I will have to do some testing. I also noticed some strange undo behavior on another plugin I am working on. Do you know if this only occurs when you have 'Subsurface Materials' enabled?
                                      • I Offline
                                        imabzeous
                                        can anyone tell me is there anyway to slect edges and vertice and cerease them? ARTISAN PLUGIN, am manually clicking each vertice and edge?
                                          Documentation Archives
                                          Artisan (artisan4sketchup.com)
                                          Page 10 and 9 πŸ˜‰
                                          • Mistro11M Offline
                                            Mistro11
                                            Anything to consider for SU2015?
                                            i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                            Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                            • 14
                                            • 15
                                            • 8 / 15
