    SketchUp 2014
    205 Posts 79 Posters 78.1k Views 79 Watching
      Mark H.
      Hey everyone,
      Yup, there's a new version available. We're working out a few licensing details for folks coming over from SketchUp Pro 8, but we expect to have an announcement blog post with lots of details first thing in the morning!
      Mark
        Mark H.
        For the time being: there are a lot of details about the release here:
        http://www.sketchup.com/products/sketchup-pro/new-in-2014
        • bmikeB
          bmike
          downloaded, but in the middle of a large project. so... does it install over 13 like the last versions? i'm pro on osx.
          i need layout to be stable... for at least the next week. despite the tease of page numbers and faster vector rendering.
            Mark H.
            It should not install over previous versions of SketchUp on your machine (it hasn't for me, and I've installed it about a dozen times now!)
            • John SayersJ
              John Sayers
              It won't accept housebuilder.rb or Layermanager.rb Tried them in Shipped Extensions folder and Tools folder.
              • mikebelluckfM
                mikebelluckf
                Hmm - tried the plugin solution, no joy on my PC - back to 2013 for the day - I have clients whom arent as lovely as an unexpected upgrade.
                MIKE BELL
                http://www.mikebell.euย  ย +44 7970 646 705
                Event // Exhibition // Experiential // Installation
                Design / Layouts / CAD Plans / Digital Scamps
                • K
                  kaas
                  The only problem I have now is reintegrating my plugins etc.. Opted out of the additional folders.rb > dropbox folder plugin setup for a Mega.co.nz account syncing folders straight to the ones in sketchup. Now to resync and deal with new folder names (plugins > Shippedextensions), plugins not working on transfer, what the heck!
                  *In windows it installs the plugins in \user\NAME\appdata\roaming\sketchup\sketchup2014*
                  edit: Installing with SketchUcation plugin store of course works great. Copy-ing the remaining plugins by hand to that directory works as well. Only Artisan doesn't work. Results in lots of start up errors when restarting Sketchup.
                    Jim
                    On Vista, Win 7, 8:
                    C;\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                    On Win XP:
                    C;\Documents and Settings\<username>\Application Data\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                    On Windows, we also load plugins from a user-independent support directory.
                    On Win Vista, 7, 8:
                    C;\ProgramData\SketchUp\SketchUp 2014\SketchUp\Plugins
                    On Win XP:
                    C;\Documents and Settings\All Users\Application Data\SketchUp\SketchUp 2014\SketchUp\Plugins
                    This path is only loaded to the $LOAD_PATH array if the folder exists when on the user's machine when SU starts.
                    • P
                      Pherim
                      Somehow I can't place the large tool set in the upper or lower lines... and I can't change its form as I could do before by pulling the edges and as I still can do with other toolbars. It just remains static in two vertical columns... any ideas?
                      • P
                        pcmoor
                        cant seem to be able to generate a report...wanted to test the BIM data on a component
                        • cottyC
                          cotty
                          here too:
                          my SketchUp gallery
                            Was everyone asleep?
                            That was annonced on the French part for a while! ๐Ÿ’š
                            http://www.adebeo.com/wp/wp-content/uploads/2014/02/SketchUp2014.png
                            • John SayersJ
                              John Sayers
                              Me too Mike. Tried loading into Appdata folder - made no difference.
                              • mikebelluckfM
                                mikebelluckf
                                Having reinstalled skp 14 & I have managed to get one plugin running in path / folder as shown. Will leave rest until later - Lumion changes call !!
                                Hope this helps.
                                MIKE BELL
                                  Sketchup v2014 uses a newer [better] version of Ruby.
                                  This has meant that in anticipation of the release, over the past weeks authors have been doing a lot of reworking of Plugins, discreetly in the background.
                                  Your older Plugins will probably cause issues with v2014.
                                  Do not copy them across.
                                  It's highly recommended that you install fresh versions from the PluginStore etc.
                                  Many of these are already updated to work with v2014 [as well as earlier versions].
                                  There may of course be issues with some older plugins that haven't been updated [yet]...
                                  Please report these in each Plugin's thread, so that the author is made aware of an issue and hopefully a v2014 friendly update will be forthcoming: sometimes there is major recoding needed, but often the .rb file just needs its "encoding" changing to "UTF-8 without BOM" rather than "ANSI", which can be easily done in Notepad++...
                                    @cotty said:
                                    here too:
                                    [attachment=0:30pant48]<!-- ia0 -->artisan14.jpg<!-- ia0 -->[/attachment:30pant48]
                                    It works fine for me. Make sure you've downloaded the current version and didn't just drag an old version over from an earlier version of SketchUp. As TIG indicated, download fresh copies of plugins because many of them required and have been updated.
                                    • HieruH
                                      Hieru
                                      I don't want to be one of 'those' naysayers (SU will no doubt still be a joy to use), but I was expecting this release to be an impressive upgrade where Trimble would firmly stamp their mark and show their ambition for the software.
                                      The improved shadows and arc tool are all well and good (not very useful for advanced modelling), but 2014 has stalled at my first test exploding a complex model.
                                      Back to the old workarounds for high-poly modelling.
                                      I'm sure the team have done some great work under the hood that I'll benefit from as I get deep into using 2014. Unfortunately I think we'll just get the same upgrade wish list we've seen since SU7.
                                      www.davidhier.co.uk
                                      • Clayton49C
                                        Clayton49
                                        To all,
                                        Just downloaded SU Pro 2014, installation was swift without any problems, o.k. so far. However some of my extension that I've become reliant on for work, has flagged up as "INCOMPATIBLE" on my extension warehouse, these are:-
                                        1001 BIT TOOLS
                                        2014 DIBAC
                                        LAYER MANAGER
                                        PROJECTION & GUIDE TOOL
                                        I've therefore reverted back to SU Pro 2103 in the meantime.
                                        As for SU Pro 2014, I'm not too sure what everyone was expecting, but the upgrade list seems a tad light to me... ๐Ÿ˜’
                                        I would have thought as there's so many extensions available, some would have made it into SU as hard wired. Perhaps an idea would be that SU HQ could offer an incentive for extension writer "GURUS" as a sort of cash prise for voted good ones to be included in future upgrades.
                                        I think these would have to be improved utility ones, as this would assist all SU users. For me, I just can't live without "LAYER MANAGER"...... so back to SU Pro 2013.
                                        Over & out,
                                        Clayton.
                                        Over & out,
                                        Clayton.
                                        %(#008000)[Trotman & Taylor
                                        Architectural Consultants]
                                        • K
                                          kaas
                                          For those interested in an overview of 2014 features read here:
                                          http://help.sketchup.com/en/tags/2014
                                            or here...
                                            404 Not Found
                                            (sketchucation.com)
                                            • 11
                                            • 1 / 11
