    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 164.0k Views 79 Watching
      Can be apply other things than trunck ? (as textures/material or as components)
      Can be apply other things than branch ? (as textures/material or as components)
      Can be apply other things than leaf ? (as textures/material or as components)
      • ppoublanP Offline
        ppoublan
        Can be apply other things than trunck ? (as textures or as components)
        Can be apply other things than branch ? (as textures or as components)
        Can be apply other things than leaf ? (as textures or as components)
        Hi Pilou,
        If your question is how to add your own textures and leaves/flowers types, here is how it works now :
        • textures available are all "*.jpg" files that exists in the 3darcstudio plugin dir.
        • leaves/flowers components are all "*.skp" files that exists in the 3Darcstudio plugin dir.
          So you can easily add your own by copying your files into this dir.
          Be careful when defining your own components to make the origin of the component at the beginning of the leaf, and the leaf pointing to the sky (z direction), with size arrong 10 cms long.
        • ppoublanP Offline
          ppoublan
          Tried and still the same error.[/quote]
          Arghh...! do not understand why. Maybe try to delete files and copy them again to be sure file has not been corrupted. Does it work with SU8 ?
          • KrisidiousK Offline
            Krisidious
            No, it doesn't work on either 8 or 13... Tried deleting. nothing changes.
            Just my luck.
            By: Kristoff Rand
              Cool! โ˜€
              ๐Ÿ˜‰
              http://www.web-libre.org/medias/img/articles/a501bebf79d570651ff601788ea9d16d-2.jpg
              • TIGT Online
                Let's try some testing with the Ruby Console...
                Copy paste these lines + <enter>
                path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
                Then this
                File.exist?(path)
                which will return 'true' or 'false'...
                If 'false' that's plain weird as you can 'see' it !?
                Check the exact spellings, compared to the error messages etc the 'loader text is '3darcstudio/3darcstudiotree.rbs'
                If it's 'true' then try...
                load path
                If it's 'true', then the code in the rbs file has loaded and the menu/toolbar etc should be available, as if the Extension had been loaded and activated...
                What happens ?
                  Krisidious
                  Then this
                  File.exist?(path)
                  True
                  load path
                  I get. on Load Path
                  Error: #<SyntaxError: (eval):155:in load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char \010' in expression>
                  (eval):155
                  (eval):155
                  By: Kristoff Rand
                  • ppoublanP Offline
                    ppoublan
                    @kaas said:
                    Hello Pascal,
                    Just had a go with the plugin. It works really fine already!
                    My 2 cts:
                    1. if I right-click and adjust any part of a tree it also generates new elements for every other part of the tree. I understand changing the branches should also change the position of the leaves but changing the leaves atm also changes the trunk, not really what you want if you're fine tuning a tree
                    2. i might be a nice feature if one could control the size / length of the branches (size decrease or increase by x %) depending on the position on the tree (higher up the tree = make branches less long by 50% etc).
                    3. ditto for the leaves - for instance smaller leaves near the end of a branch.
                    edit: 4. adjusting a tree reloads all materials and textures. If you-re fine-tuning a tree and already edited one of your materials you have to do that again and again.
                    Greetings,
                    Max
                    The tree is entirely rebuilt each time a single parameter is changed (as almost all parameters have impacts on others"). Something I do not know how to fix.
                    But the lenght of the brenches in fact are varying based on their position on the tree as you are asking for. This is managed by the "tree shape" parameter (pyramidal, spherical, ...) . See the pdf doc for this parameter.
                      kaas
                      Hello Pascal,
                      My 2 cts:
                      edit: 5. the textures for the bark must be located in the 3d arcstudio directory. The same for the models of the leaves. Many people have all their content on (shared and backupped) network drives. It would be great if one could make a redirection to external folders for the textures and a different one for the leaf-models.
                      Greetings,
                      Max
                      • ppoublanP Offline
                        ppoublan
                        @krisidious said:
                        I get. on Load Path
                        (eval):155
                        (eval):155
                        Strange. Really seams the file is corrupted. Could you try deleting all local files from 3darcstudio, and downloading it again after emptying your browser cache from the web site (http://www.3darcstudio.com)
                        Looks like Sketchup unable to read/interpret source code rbs file :
                        • the script start with : =begin and =end remarks lines so they should be ignored
                        • no "." dot character used without the number 0 before, maybe wrong interpretation of the decimal point
                        exact size of rbs file on my computer is 193ย 410 octets
                          Krisidious
                          no, that didn't work either...
                          file.
                          size - 188 KB (193,410 bytes)
                          size on disk - 192 KB (196,608 bytes)
                          By: Kristoff Rand
                            kaas
                            As always, I did not spend enough time reading the manual. I will read it.
                            I ran into another small issue: I made my own leaf-component and textured both front and backside of the faces. If I run the tree plugin the mapping coordinates of the backfaces of those leafs get messed up.
                            It's easy to fix by right clicking on a component and reload the original leaf-file but a bit strange.
                            Still, compliments on the plugin! Having great fun with it the last couple of hours ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                            • massimoM Offline
                              massimo Moderator
                              Played a bit with an olive tree. ๐Ÿ˜„
                                leminilab
                                Amazing plug-in... ๐Ÿ˜ฎ
                                How heavy is this file Massimo?
                                • "Live every day as if it were your last and then some day you'll be right."
                                • "ThomThom rules!!!"
                                • massimoM Offline
                                  massimo Moderator
                                  Only purged (and not tried yet with cleanup), 3,5Mb.
                                    tomasz
                                    @ppoublan said:
                                    Does someone could confirm SU 2013 has or not better features to build user input data interfaces ? Or should I go any way with Applets and html code ?
                                    No improvements whatsoever.
                                    You can try a library Aerilius-onscreen-gui. That is what He has doneto improve things.
                                    Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                                    • olisheaO Offline
                                      olishea
                                      how many faces? this is the important thing. leaves should be substituted for quad face PNGs.
                                      oli
                                      • massimoM Offline
                                        massimo Moderator
                                        This is after running cleanup.
                                          leminilab
                                          Sorry for the following dumb question but I didn't take the time to read all the post or even try the plug-in yet...
                                          ๐Ÿ˜• All the leaves are components?
                                          • CadFatherC Offline
                                            CadFather
                                            yes
                                            • 16
                                            • 17
                                            • 3 / 17
