    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
    • KrisidiousK Offline
      Krisidious
      no, that didn't work either...
      file.
      size - 188 KB (193,410 bytes)
      size on disk - 192 KB (196,608 bytes)
      By: Kristoff Rand
        kaas
        @ppoublan said:
        But the lenght of the brenches in fact are varying based on their position on the tree as you are asking for. This is managed by the "tree shape" parameter (pyramidal, spherical, ...) . See the pdf doc for this parameter.
        As always, I did not spend enough time reading the manual. I will read it.
        I ran into another small issue: I made my own leaf-component and textured both front and backside of the faces. If I run the tree plugin the mapping coordinates of the backfaces of those leafs get messed up.
        It's easy to fix by right clicking on a component and reload the original leaf-file but a bit strange.
        Still, compliments on the plugin! Having great fun with it the last couple of hours 👍 👍 👍
        • massimoM Offline
          massimo Moderator
          Played a bit with an olive tree. 😄
            leminilab
            Amazing plug-in... 😮
            How heavy is this file Massimo?
            • "Live every day as if it were your last and then some day you'll be right."
            • "ThomThom rules!!!"
            • massimoM Offline
              massimo Moderator
              Only purged (and not tried yet with cleanup), 3,5Mb.
                tomasz
                @ppoublan said:
                Does someone could confirm SU 2013 has or not better features to build user input data interfaces ? Or should I go any way with Applets and html code ?
                No improvements whatsoever.
                You can try a library Aerilius-onscreen-gui. That is what He has doneto improve things.
                • olisheaO Offline
                  olishea
                  how many faces? this is the important thing. leaves should be substituted for quad face PNGs.
                  oli
                  • massimoM Offline
                    massimo Moderator
                    This is after running cleanup.
                      leminilab
                      Sorry for the following dumb question but I didn't take the time to read all the post or even try the plug-in yet...
                      😕 All the leaves are components?
                      • CadFatherC Offline
                        CadFather
                        yes
                          leminilab
                          @cadfather said:
                          yes
                          Thanks! 😄
                          • ppoublanP Offline
                            ppoublan
                            Dear all,
                            I’m really impressed by the number of interesting comments and feedbacks received on this plugin. And I really like the olive tree variations of Massimo. (Encourage everyone to publish their preferred trees made with the plugin).
                            Thanks to all of you. I will do my best to improve it in future releases, but as the plugin is free and not my job please be patient. I will need to learn more on dev.
                            Here are few bug corrections that include :
                            • Reversed faces for the trunk and branches in order for face normals to point outward
                            • Changed the scaling function of flowers to be correctly handled by Thea (and other renders)
                            • Removed the ruby console
                              Version available on http://3darcstudio.com/en/downloads-files/sketchup-plugins/206-3d-tree-maker-sketchup-plugin
                              I carefully read all other comments and I’m looking how to integrate them in other devs.
                              Yours
                              Pascal
                            PS: script will be published into the Sketchucation Store, but not ready yet.
                              Krisidious
                              Don't feel rushed Pascal... This is an incredible contribution to the community. Very exciting.
                              By: Kristoff Rand
                              • massimoM Offline
                                massimo Moderator
                                Thanks for the very quick fix Pascal. 👍
                                  archigrafix
                                  Doesnt seem to work with sketchup 7???
                                  Agir comme un homme de pensée, et penser comme un homme d'action...
                                    Krisidious
                                    What's happening Arch? error? nothing at all?
                                    By: Kristoff Rand
                                      archigrafix
                                      Yes Kris nothing happens at all...just frustration 😲
                                      • ppoublanP Offline
                                        ppoublan
                                        Hi Kris,
                                        Sorry for that but I only tested it on SU8 as dev started after SU8 was available. Do not know what functions are not correctly supported by previous versions.
                                        Do you get at least the menu in plugins ?
                                        I you activate the Ruby console, do you get some messages in the console ?
                                        Yours
                                        Pascal
                                        • V Offline
                                          versus
                                          I found the problem, perhaps due to a misspelling between lines = begin and = end, this is due only to a point out of place, just before = end, in my case, I have many plugins installed and thought it was due to one that caused the conflict, I tried an installation of SU 8 without additional plugins and charge well, it might be the WXP vs windows vista, in windows vista remove the point of the last sentence of the load file header specifically as follows:
                                          original
                                          AND FITNESS FOR A PARTICULAR PURPOSE.
                                          = end
                                          new
                                          = end
                                          in windows vista files are not loaded when I was at the end point of the line before = end, but in windows xp there was no problem loading the plugin
                                          another thing I did was copy the contents of the folder directly in the plugins folder of SU 8
                                            archigrafix
                                            @ppoublan said:
                                            Hi Kris,
                                            Yours
                                            Pascal
                                            Yes the menu is there...When I choice "Make tree" it returns:
                                            Error: #<RuntimeError: Can't insert empty component.>
                                            (eval):1050:in load' (eval):1050:in initialize'
                                            (eval):1042:in each' (eval):1042:in initialize'
                                            (eval):1217:in new' (eval):1217:in initialize'
                                            (eval):653:in new' (eval):653:in f3das_loadconfiguration'
                                            (eval):651:in each' (eval):651:in f3das_loadconfiguration'
                                            (eval):4443:in require' (eval):4443:in call'
                                            Hope you can help
                                            • 16
                                            • 17
                                            • 3 / 17
