    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
      So you can easily add your own by copying your files into this dir.
      Cool! โ˜€
      ๐Ÿ˜‰
      http://www.web-libre.org/medias/img/articles/a501bebf79d570651ff601788ea9d16d-2.jpg
        Let's try some testing with the Ruby Console...
        Copy paste these lines + <enter>
        path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
        Then this
        File.exist?(path)
        which will return 'true' or 'false'...
        If 'false' that's plain weird as you can 'see' it !?
        Check the exact spellings, compared to the error messages etc the 'loader text is '3darcstudio/3darcstudiotree.rbs'
        If it's 'true' then try...
        load path
        If it's 'true', then the code in the rbs file has loaded and the menu/toolbar etc should be available, as if the Extension had been loaded and activated...
        What happens ?
        • KrisidiousK Offline
          Krisidious
          Then this
          File.exist?(path)
          True
          load path
          I get. on Load Path
          Error: #<SyntaxError: (eval):155:in load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char \010' in expression>
          (eval):155
          (eval):155
          By: Kristoff Rand
          • ppoublanP Offline
            ppoublan
            @kaas said:
            Hello Pascal,
            Just had a go with the plugin. It works really fine already!
            My 2 cts:
            1. if I right-click and adjust any part of a tree it also generates new elements for every other part of the tree. I understand changing the branches should also change the position of the leaves but changing the leaves atm also changes the trunk, not really what you want if you're fine tuning a tree
            2. i might be a nice feature if one could control the size / length of the branches (size decrease or increase by x %) depending on the position on the tree (higher up the tree = make branches less long by 50% etc).
            3. ditto for the leaves - for instance smaller leaves near the end of a branch.
            edit: 4. adjusting a tree reloads all materials and textures. If you-re fine-tuning a tree and already edited one of your materials you have to do that again and again.
            Greetings,
            Max
            The tree is entirely rebuilt each time a single parameter is changed (as almost all parameters have impacts on others"). Something I do not know how to fix.
            But the lenght of the brenches in fact are varying based on their position on the tree as you are asking for. This is managed by the "tree shape" parameter (pyramidal, spherical, ...) . See the pdf doc for this parameter.
              kaas
              Hello Pascal,
              My 2 cts:
              edit: 5. the textures for the bark must be located in the 3d arcstudio directory. The same for the models of the leaves. Many people have all their content on (shared and backupped) network drives. It would be great if one could make a redirection to external folders for the textures and a different one for the leaf-models.
              Greetings,
              Max
              • ppoublanP Offline
                ppoublan
                @krisidious said:
                I get. on Load Path
                (eval):155
                (eval):155
                Strange. Really seams the file is corrupted. Could you try deleting all local files from 3darcstudio, and downloading it again after emptying your browser cache from the web site (http://www.3darcstudio.com)
                Looks like Sketchup unable to read/interpret source code rbs file :
                • the script start with : =begin and =end remarks lines so they should be ignored
                • no "." dot character used without the number 0 before, maybe wrong interpretation of the decimal point
                exact size of rbs file on my computer is 193ย 410 octets
                  Krisidious
                  no, that didn't work either...
                  file.
                  size - 188 KB (193,410 bytes)
                  size on disk - 192 KB (196,608 bytes)
                  By: Kristoff Rand
                    kaas
                    As always, I did not spend enough time reading the manual. I will read it.
                    I ran into another small issue: I made my own leaf-component and textured both front and backside of the faces. If I run the tree plugin the mapping coordinates of the backfaces of those leafs get messed up.
                    It's easy to fix by right clicking on a component and reload the original leaf-file but a bit strange.
                    Still, compliments on the plugin! Having great fun with it the last couple of hours ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    • massimoM Offline
                      massimo Moderator
                      Played a bit with an olive tree. ๐Ÿ˜„
                        leminilab
                        Amazing plug-in... ๐Ÿ˜ฎ
                        How heavy is this file Massimo?
                        • "Live every day as if it were your last and then some day you'll be right."
                        • "ThomThom rules!!!"
                        • massimoM Offline
                          massimo Moderator
                          Only purged (and not tried yet with cleanup), 3,5Mb.
                            tomasz
                            @ppoublan said:
                            Does someone could confirm SU 2013 has or not better features to build user input data interfaces ? Or should I go any way with Applets and html code ?
                            No improvements whatsoever.
                            You can try a library Aerilius-onscreen-gui. That is what He has doneto improve things.
                            • olisheaO Offline
                              olishea
                              how many faces? this is the important thing. leaves should be substituted for quad face PNGs.
                              oli
                              • massimoM Offline
                                massimo Moderator
                                This is after running cleanup.
                                  leminilab
                                  Sorry for the following dumb question but I didn't take the time to read all the post or even try the plug-in yet...
                                  ๐Ÿ˜• All the leaves are components?
                                  • CadFatherC Offline
                                    CadFather
                                    yes
                                      leminilab
                                      @cadfather said:
                                      yes
                                      Thanks! ๐Ÿ˜„
                                      • ppoublanP Offline
                                        ppoublan
                                        Dear all,
                                        Iโ€™m really impressed by the number of interesting comments and feedbacks received on this plugin. And I really like the olive tree variations of Massimo. (Encourage everyone to publish their preferred trees made with the plugin).
                                        Thanks to all of you. I will do my best to improve it in future releases, but as the plugin is free and not my job please be patient. I will need to learn more on dev.
                                        Here are few bug corrections that include :
                                        • Reversed faces for the trunk and branches in order for face normals to point outward
                                        • Changed the scaling function of flowers to be correctly handled by Thea (and other renders)
                                        • Removed the ruby console
                                          Version available on http://3darcstudio.com/en/downloads-files/sketchup-plugins/206-3d-tree-maker-sketchup-plugin
                                          I carefully read all other comments and Iโ€™m looking how to integrate them in other devs.
                                          Yours
                                          Pascal
                                        PS: script will be published into the Sketchucation Store, but not ready yet.
                                          Krisidious
                                          Don't feel rushed Pascal... This is an incredible contribution to the community. Very exciting.
                                          By: Kristoff Rand
                                          • massimoM Offline
                                            massimo Moderator
                                            Thanks for the very quick fix Pascal. ๐Ÿ‘
                                            • 16
                                            • 17
                                            • 3 / 17
