    [Plugin] 3D Text Editor
    204 Posts 51 Posters 237.9k Views 50 Watching
      What operating system? What SketchUp version? Help us help you. Please complete your profile.
      • tt_suT
        tt_su
        I'm going to guess that you have Windows 8.x? I'm getting some reports that it's not working there. I'm not sure why - it might be Windows 8.x preventing me from using the font list or it could be IE11. Either way - I've not had time to investigate in detail yet.
        • G
          greg24k
          Sorry about that... Windows 7 Sketchup Pro 2013
          • tt_suT
            tt_su
            What version of Internet Explorer do you have?
            • doppelD
              doppel
              Nice & Useful plugin!!! thanks for your work.
              But since the last version of TT_Lib², i always have this message on Sketchup starts :
              "TT_Lib² detected that some of the files in SketchUp's plugin folder has ended up
              in Window's Virtual Store. It happens because of insufficint permissions for the
              plugin folder. Please move the files into the real Plugins folder."
              TT Lib² v.2.9.4
              Internet Explorer 11
              Sketchup 8
              EDIT : uninstall et install TT Lib². The message doesn't appeared anymore.
              But now, when I start the plugin, i have a message with an error script about the file base.js. And whatever i click yes or no, i can't choose my font 😕 😆
              • tt_suT
                tt_su
                TT Lib² v.2.9.4
                Sketchup 8
                1. The VirtualStore warning - did you follow its instructions? Move the files from Virtual Store to the proper Plugins folder?
                2. You unintalled TT_Lib2? Then 3D Text Editor wont' work. (But yet you indicate it does? This could be a result of the files in the VirtualStore.)
                3. Regarding the Javascript error, do you have Windows 8? I've gotten reports from Windows 8 users that this plugin doesn't work for them. But I'm not sure if it's Window 8 or IE11...
                • doppelD
                  doppel
                  1 - yes, i moved the files in the plugin folder of Sketchup
                  2 - uninstalled and re-install TT_Lib²
                  3 - Windows 7
                  I will try few things to fix that. Thanks all of you for your replies 😄
                  • tt_suT
                    tt_su
                    Windows 7 eyh... then IE11 might be the culprit. I might be lucky and be able to force the webdialog to user IE10 compatibility mode.
                    • doppelD
                      doppel
                      That's what i thought too. I uninstall IE11 and all work as before! I don't need it anyway, i prefer firefox & chrome ^^
                      • tt_suT
                        tt_su
                        Ah! Right. Thanks for confirming that. I only hope that forcing a compatibility IE10 mode will return the use of the font-list.
                          IE11 also just installed itself on my Win7 PC and I confirm that your 3d-text tool is now indeed broken - these a js error when it can't compile the font-list and 'count' it...
                            I have managed to reproduce the issue - and it was indeed an IE11 issue. When I force IE10 compatibility it becomes usable again. This is however something I need to fix in TT_Lib2 - so keep an eye out for an update soon.
                              Updated TT_Lib 2.9.5 will fix the issue.
                              Download from PluginStore or BitBucket:
                              http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                              https://bitbucket.org/thomthom/tt-library-2/downloads
                              Submitted to moderation on Extension Warehouse.
                              • pwilkerP
                                pwilker
                                The same error is happening to me, can you help me troubleshoot?
                                  This has been explained repeatedly here. You currently do not have full permissions to the Plugins folder. Edit those permissions and install the plugin.
                                  • tt_suT
                                    tt_su
                                    There should be an Explorer window opening after that message that display the content of the Virtual Store. Notice the path of the folder - it's not the real Plugins folder.
                                    Move the files to the real Plugins folder.
                                      mutsu_kwq
                                      This is the screen cap of the window shows after the message and i click ok
                                      http://i837.photobucket.com/albums/zz292/mutsu_kwq/screencap1.jpg
                                      which one is the real plugins folder?
                                      please help me
                                      • tt_suT
                                        tt_su
                                        What is the full path of that explorer window?
                                          Because of the scant contents of that folder it must be the VirtualStore 'tree' - expand the path in the top-bar and you'll see it includes 'VirtualStore' - NOT 'Program Files'...
                                          Fix your Plugins folder's permissions to FULL read/write, clear the VirtualStore folder and then reinstall the Lib, and you should avoid these problems thereafter... 😒
                                            mutsu_kwq
                                            Thank you so much Master TIG... i think my sketchup program works fine now.
                                            But i'm curious where can i find the virtual store folder and how to clean it..
                                            • 11
                                            • 7 / 11
