    [Plugin] 3D Text Editor
    204 Posts 51 Posters 231.0k Views 50 Watching
    • doppelD
      doppel
      That's what i thought too. I uninstall IE11 and all work as before! I don't need it anyway, i prefer firefox & chrome ^^
      • tt_suT
        tt_su
        Ah! Right. Thanks for confirming that. I only hope that forcing a compatibility IE10 mode will return the use of the font-list.
          IE11 also just installed itself on my Win7 PC and I confirm that your 3d-text tool is now indeed broken - these a js error when it can't compile the font-list and 'count' it...
            I have managed to reproduce the issue - and it was indeed an IE11 issue. When I force IE10 compatibility it becomes usable again. This is however something I need to fix in TT_Lib2 - so keep an eye out for an update soon.
              Updated TT_Lib 2.9.5 will fix the issue.
              Download from PluginStore or BitBucket:
              http://sketchucation.com/resources/pluginstore?pln=TT_Lib
              https://bitbucket.org/thomthom/tt-library-2/downloads
              Submitted to moderation on Extension Warehouse.
              • pwilkerP
                pwilker
                The same error is happening to me, can you help me troubleshoot?
                "TT_Lib² detected that some of the files in SketchUp's plugin folder has ended up
                in Window's Virtual Store. It happens because of insufficint permissions for the
                plugin folder. Please move the files into the real Plugins folder."
                  This has been explained repeatedly here. You currently do not have full permissions to the Plugins folder. Edit those permissions and install the plugin.
                  • tt_suT
                    tt_su
                    There should be an Explorer window opening after that message that display the content of the Virtual Store. Notice the path of the folder - it's not the real Plugins folder.
                    Move the files to the real Plugins folder.
                      mutsu_kwq
                      This is the screen cap of the window shows after the message and i click ok
                      http://i837.photobucket.com/albums/zz292/mutsu_kwq/screencap1.jpg
                      which one is the real plugins folder?
                      please help me
                      • tt_suT
                        tt_su
                        What is the full path of that explorer window?
                          Because of the scant contents of that folder it must be the VirtualStore 'tree' - expand the path in the top-bar and you'll see it includes 'VirtualStore' - NOT 'Program Files'...
                          Fix your Plugins folder's permissions to FULL read/write, clear the VirtualStore folder and then reinstall the Lib, and you should avoid these problems thereafter... 😒
                            mutsu_kwq
                            Thank you so much Master TIG... i think my sketchup program works fine now.
                            But i'm curious where can i find the virtual store folder and how to clean it..
                              Your screen-shot shows the VirtualStore folder opened ?
                              If you have a 'Compatibility Files...' link/button in the top-bars of your Plugins folder's 'Windows Explorer' window, then that shows you have some mis-installed files/folders, click on that and it takes you there...
                              If you now have set FULL read/write Security permissions to the Plugins folder you should no longer get anything in the VirtualStore...
                              Its path is:
                              C:\Users\YourUserName\AppData\Local\VirtualStore
                              with nested subfolders matching the path into which you were prevented from installing files...
                              Ending in \Plugins
                              If your AppData folder is hidden you will need to either go to it using the path OR change your Folder Options to show hidden files/folders...
                                alexkara
                                Has anyone managed to use 3D text editor on Su 2014 under Win 8.1? I haven't been able to successfully execute the plugin under Win 8.1. All I get is a blank (black fill in) of the input dialog box. The same model can be processed in Win 7 using the same version of SU.
                                  I have no issues with this tool in v2014 under Win 7.
                                  I haven't upgraded to Win 8 yet.
                                  Anyone else with Win 8.1 having these problems ?
                                  You could PM thomthom... it might be something to do with the way the available-fonts list is accessed ?
                                    I have Win8.1, IE11 and it's working fine with SU2014 for me.
                                    There was an issue when Win8 came out where it wasn't working, but I addressed that in TT_Lib2. What version of TT_Lib2 do you have?
                                      alexkara
                                      Latest versions of everything (Win 8.1, IE, Plugins, TT_LIB2). I bit the bullet and "uninstalled" anything remotely related and re-installed and it seems to be working. Thanks for confirmation and sorry about the "cry wolf".
                                        driven
                                        Thomas,
                                        I sent you a PM re UFT8 3dText on Yosemite...
                                        The other thing I'm wondering is if scaling could be used to obtain higher vert count on curves...
                                        i.e. use a scaled down container, but scale up the input values?
                                          Have you seen indications that using Entities.add_3d_text base the quality on the size of the text?
                                            driven
                                            no, and just did some test and it doesn't, unfortunately...
                                            maybe it was todd's original $plugin that did, or just wishful thinking...
                                            if 3dText is your primary output, i.e. signage, then being able to increase precision would be good...
                                            • 11
                                            • 8 / 11
