    [Plugin] 3D Text Editor
    204 Posts 51 Posters 237.9k Views 50 Watching
    • tt_suT
      tt_su
      Hm... I've not had time to look at this yet, but TIG's comment about the font list not being populated could be a clue. Maybe IE11 had removed the MS hack I used to get the font list...
      The %20 instead of a space is just IE transforming the path string into a URL string. Nothing wrong there.
      • dkdickialD
        dkdickial
        @tig said:
        With admin powers...
        Select the Plugins folder icon.
        Right-click
        Context-menu
        Properties
        Security
        Edit...
        Bad news.
        I'v make everyone in the list has full permissions ticked, and still, it doesn't work šŸ˜ž
        • G
          greg24k
          For some reason I get error when I start the plug-in. Everything else works, but it will not load the fonts. I get a java error is in the TT Lib2 in the webdialog/base.js It says that Unable to ger property "count" of undefined or null reference. Line 115 Char 9
          Is anyone else experienced that, and if there a fix for it?
            What operating system? What SketchUp version? Help us help you. Please complete your profile.
            • tt_suT
              tt_su
              I'm going to guess that you have Windows 8.x? I'm getting some reports that it's not working there. I'm not sure why - it might be Windows 8.x preventing me from using the font list or it could be IE11. Either way - I've not had time to investigate in detail yet.
              • G
                greg24k
                Sorry about that... Windows 7 Sketchup Pro 2013
                • tt_suT
                  tt_su
                  What version of Internet Explorer do you have?
                  • doppelD
                    doppel
                    Nice & Useful plugin!!! thanks for your work.
                    But since the last version of TT_Lib², i always have this message on Sketchup starts :
                    "TT_Lib² detected that some of the files in SketchUp's plugin folder has ended up
                    in Window's Virtual Store. It happens because of insufficint permissions for the
                    plugin folder. Please move the files into the real Plugins folder."
                    TT Lib² v.2.9.4
                    Internet Explorer 11
                    Sketchup 8
                    EDIT : uninstall et install TT Lib². The message doesn't appeared anymore.
                    But now, when I start the plugin, i have a message with an error script about the file base.js. And whatever i click yes or no, i can't choose my font šŸ˜• šŸ˜†
                    • tt_suT
                      tt_su
                      TT Lib² v.2.9.4
                      Sketchup 8
                      1. The VirtualStore warning - did you follow its instructions? Move the files from Virtual Store to the proper Plugins folder?
                      2. You unintalled TT_Lib2? Then 3D Text Editor wont' work. (But yet you indicate it does? This could be a result of the files in the VirtualStore.)
                      3. Regarding the Javascript error, do you have Windows 8? I've gotten reports from Windows 8 users that this plugin doesn't work for them. But I'm not sure if it's Window 8 or IE11...
                      • doppelD
                        doppel
                        1 - yes, i moved the files in the plugin folder of Sketchup
                        2 - uninstalled and re-install TT_Lib²
                        3 - Windows 7
                        I will try few things to fix that. Thanks all of you for your replies šŸ˜„
                        • tt_suT
                          tt_su
                          Windows 7 eyh... then IE11 might be the culprit. I might be lucky and be able to force the webdialog to user IE10 compatibility mode.
                          • doppelD
                            doppel
                            That's what i thought too. I uninstall IE11 and all work as before! I don't need it anyway, i prefer firefox & chrome ^^
                            • tt_suT
                              tt_su
                              Ah! Right. Thanks for confirming that. I only hope that forcing a compatibility IE10 mode will return the use of the font-list.
                                IE11 also just installed itself on my Win7 PC and I confirm that your 3d-text tool is now indeed broken - these a js error when it can't compile the font-list and 'count' it...
                                  I have managed to reproduce the issue - and it was indeed an IE11 issue. When I force IE10 compatibility it becomes usable again. This is however something I need to fix in TT_Lib2 - so keep an eye out for an update soon.
                                    Updated TT_Lib 2.9.5 will fix the issue.
                                    Download from PluginStore or BitBucket:
                                    http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                                    https://bitbucket.org/thomthom/tt-library-2/downloads
                                    Submitted to moderation on Extension Warehouse.
                                    • pwilkerP
                                      pwilker
                                      The same error is happening to me, can you help me troubleshoot?
                                        This has been explained repeatedly here. You currently do not have full permissions to the Plugins folder. Edit those permissions and install the plugin.
                                        • tt_suT
                                          tt_su
                                          There should be an Explorer window opening after that message that display the content of the Virtual Store. Notice the path of the folder - it's not the real Plugins folder.
                                          Move the files to the real Plugins folder.
                                            mutsu_kwq
                                            This is the screen cap of the window shows after the message and i click ok
                                            http://i837.photobucket.com/albums/zz292/mutsu_kwq/screencap1.jpg
                                            which one is the real plugins folder?
                                            please help me
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 7 / 11
