    [Request] Rotate Constrained
    16 Posts 8 Posters 806 Views 8 Watching
      @Dave
      No, I posted a simple example for illustration. I'm dealing with substantially more geometry 😞
        I see.
          All that is very cryptic! πŸ’š
          • tt_suT Offline
            tt_su
            @rich o brien said:
            @Dave
            Example? The simple example you posted wouldn't be too hard - but it'd be difficult to make it scale. How is the real life scenario like?
              @thom
              See attached..
              thomthom-example.skp
              ...I think having pivot point in SU would be very beneficial.
              I suppose in this example I am looking for linear falloff extrude
              • cottyC Offline
                cotty
                Not one step, but relatively fast:
                • draw face
                • use EEbyVtO (Extrude Edge by Vector to Object) from TIGs Extrusion Tools
                my SketchUp gallery
                • tt_suT Offline
                  tt_su
                  In that case you want to apply a restraint on all the vertical edges to keep their directions. That would be doable. But I think you'd have to create a custom tool as this would be difficult to do with observers intercepting the native tools.
                    AAAh, now I See! Vicious problem! πŸ˜„
                    • gillesG Offline
                      gilles
                      for me with Fredo's taper tool it's a one step.
                        Excellent! 😳 πŸ’š 😎 β˜€ πŸ‘
                        The trick was to take the entiere object! πŸ€“ πŸ˜’
                        "Pourquoi faire simple quand on peut faire compliquΓ©!" πŸ˜†
                        "Why make it simple when it can be complicated!"
                        Same remark than above: you must draw first something for the "Hot Point" with the protractor! πŸ€“
                        Because the Taper Tool has a distance and not an angle!
                        Normally a simple Help Line with the protractor is sufficient! πŸ€“
                        Morality : a rotation with constraint is just a tapering tapered taper! β˜€
                          Not so vicious! πŸ˜‰
                          Fredo Scale again! β˜€
                          Tapering of the bounding box seems make the trick ! πŸ’š So the Doh Duh for Rich! πŸ˜„
                          & CleanUp by Thomthom at the end! πŸ˜‰
                          10 seconds with a hand attached in the back πŸ’š
                          Of course you must make an Helper guide line of the angle wished first by the external Top edge! πŸ€“
                          So 2 seconds more! πŸ€“
                          thomthom-example1v6.skp
