    [Request] Rotate Constrained
    16 Posts 8 Posters 868 Views 8 Watching
      Seems there is the FredoScale for that πŸ˜‰
      I come back in 5 minutes for the video by himself! β˜€
      from this thead of anthology πŸ˜„
      Second video ...But maybe i don't understand the question 😳
      http://sketchucation.com/forums/download/file.php?id=87785
      http://sketchucation.com/forums/download/file.php?id=87786
      • BoxB
        You are right Pilou, you haven't understood the question. πŸ’š
          So just using Move on the endpoint/corner wouldn't work for you?
            @Dave
            No, I posted a simple example for illustration. I'm dealing with substantially more geometry 😞
              I see.
                All that is very cryptic! πŸ’š
                • tt_suT
                  tt_su
                  @rich o brien said:
                  @Dave
                  Example? The simple example you posted wouldn't be too hard - but it'd be difficult to make it scale. How is the real life scenario like?
                    @thom
                    See attached..
                    thomthom-example.skp
                    ...I think having pivot point in SU would be very beneficial.
                    I suppose in this example I am looking for linear falloff extrude
                    • cottyC
                      cotty
                      Not one step, but relatively fast:
                      • draw face
                      • use EEbyVtO (Extrude Edge by Vector to Object) from TIGs Extrusion Tools
                      my SketchUp gallery
                      • tt_suT
                        tt_su
                        In that case you want to apply a restraint on all the vertical edges to keep their directions. That would be doable. But I think you'd have to create a custom tool as this would be difficult to do with observers intercepting the native tools.
                          AAAh, now I See! Vicious problem! πŸ˜„
                          • gillesG
                            gilles
                            for me with Fredo's taper tool it's a one step.
                              Excellent! 😳 πŸ’š 😎 β˜€ πŸ‘
                              The trick was to take the entiere object! πŸ€“ πŸ˜’
                              "Pourquoi faire simple quand on peut faire compliquΓ©!" πŸ˜†
                              "Why make it simple when it can be complicated!"
                              Same remark than above: you must draw first something for the "Hot Point" with the protractor! πŸ€“
                              Because the Taper Tool has a distance and not an angle!
                              Normally a simple Help Line with the protractor is sufficient! πŸ€“
                              Morality : a rotation with constraint is just a tapering tapered taper! β˜€
                                Not so vicious! πŸ˜‰
                                Fredo Scale again! β˜€
                                Tapering of the bounding box seems make the trick ! πŸ’š So the Doh Duh for Rich! πŸ˜„
                                & CleanUp by Thomthom at the end! πŸ˜‰
                                10 seconds with a hand attached in the back πŸ’š
                                Of course you must make an Helper guide line of the angle wished first by the external Top edge! πŸ€“
                                So 2 seconds more! πŸ€“
                                thomthom-example1v6.skp
