    [Request] Rotate Constrained
    16 Posts 8 Posters 868 Views 8 Watching
    • BoxB
      You are right Pilou, you haven't understood the question. πŸ’š
        So just using Move on the endpoint/corner wouldn't work for you?
          @Dave
          No, I posted a simple example for illustration. I'm dealing with substantially more geometry 😞
            I see.
              All that is very cryptic! πŸ’š
              • tt_suT
                tt_su
                @rich o brien said:
                @Dave
                Example? The simple example you posted wouldn't be too hard - but it'd be difficult to make it scale. How is the real life scenario like?
                  @thom
                  See attached..
                  thomthom-example.skp
                  ...I think having pivot point in SU would be very beneficial.
                  I suppose in this example I am looking for linear falloff extrude
                  • cottyC
                    cotty
                    Not one step, but relatively fast:
                    • draw face
                    • use EEbyVtO (Extrude Edge by Vector to Object) from TIGs Extrusion Tools
                    my SketchUp gallery
                    • tt_suT
                      tt_su
                      In that case you want to apply a restraint on all the vertical edges to keep their directions. That would be doable. But I think you'd have to create a custom tool as this would be difficult to do with observers intercepting the native tools.
                        AAAh, now I See! Vicious problem! πŸ˜„
                        • gillesG
                          gilles
                          for me with Fredo's taper tool it's a one step.
                            Excellent! 😳 πŸ’š 😎 β˜€ πŸ‘
                            The trick was to take the entiere object! πŸ€“ πŸ˜’
                            "Pourquoi faire simple quand on peut faire compliquΓ©!" πŸ˜†
                            "Why make it simple when it can be complicated!"
                            Same remark than above: you must draw first something for the "Hot Point" with the protractor! πŸ€“
                            Because the Taper Tool has a distance and not an angle!
                            Normally a simple Help Line with the protractor is sufficient! πŸ€“
                            Morality : a rotation with constraint is just a tapering tapered taper! β˜€
                              Not so vicious! πŸ˜‰
                              Fredo Scale again! β˜€
                              Tapering of the bounding box seems make the trick ! πŸ’š So the Doh Duh for Rich! πŸ˜„
                              & CleanUp by Thomthom at the end! πŸ˜‰
                              10 seconds with a hand attached in the back πŸ’š
                              Of course you must make an Helper guide line of the angle wished first by the external Top edge! πŸ€“
                              So 2 seconds more! πŸ€“
                              thomthom-example1v6.skp
