    [Request] Rotate Constrained
    16 Posts 8 Posters 798 Views 8 Watching
    • mitcorbM Offline
      mitcorb
      Hi, Rich:
      The only way I know, is to rotate copy and correct the geometry. Do you mean a script? Perhaps Didier Bur's Projections?
        Seems there is the FredoScale for that πŸ˜‰
        I come back in 5 minutes for the video by himself! β˜€
        from this thead of anthology πŸ˜„
        Second video ...But maybe i don't understand the question 😳
        http://sketchucation.com/forums/download/file.php?id=87785
        http://sketchucation.com/forums/download/file.php?id=87786
        • BoxB Offline
          You are right Pilou, you haven't understood the question. πŸ’š
            So just using Move on the endpoint/corner wouldn't work for you?
              @Dave
              No, I posted a simple example for illustration. I'm dealing with substantially more geometry 😞
                I see.
                  All that is very cryptic! πŸ’š
                  • tt_suT Offline
                    tt_su
                    @rich o brien said:
                    @Dave
                    Example? The simple example you posted wouldn't be too hard - but it'd be difficult to make it scale. How is the real life scenario like?
                      @thom
                      See attached..
                      thomthom-example.skp
                      ...I think having pivot point in SU would be very beneficial.
                      I suppose in this example I am looking for linear falloff extrude
                      • cottyC Offline
                        cotty
                        Not one step, but relatively fast:
                        • draw face
                        • use EEbyVtO (Extrude Edge by Vector to Object) from TIGs Extrusion Tools
                        my SketchUp gallery
                        • tt_suT Offline
                          tt_su
                          In that case you want to apply a restraint on all the vertical edges to keep their directions. That would be doable. But I think you'd have to create a custom tool as this would be difficult to do with observers intercepting the native tools.
                            AAAh, now I See! Vicious problem! πŸ˜„
                            • gillesG Offline
                              gilles
                              for me with Fredo's taper tool it's a one step.
                                Excellent! 😳 πŸ’š 😎 β˜€ πŸ‘
                                The trick was to take the entiere object! πŸ€“ πŸ˜’
                                "Pourquoi faire simple quand on peut faire compliquΓ©!" πŸ˜†
                                "Why make it simple when it can be complicated!"
                                Same remark than above: you must draw first something for the "Hot Point" with the protractor! πŸ€“
                                Because the Taper Tool has a distance and not an angle!
                                Normally a simple Help Line with the protractor is sufficient! πŸ€“
                                Morality : a rotation with constraint is just a tapering tapered taper! β˜€
                                  Not so vicious! πŸ˜‰
                                  Fredo Scale again! β˜€
                                  Tapering of the bounding box seems make the trick ! πŸ’š So the Doh Duh for Rich! πŸ˜„
                                  & CleanUp by Thomthom at the end! πŸ˜‰
                                  10 seconds with a hand attached in the back πŸ’š
                                  Of course you must make an Helper guide line of the angle wished first by the external Top edge! πŸ€“
                                  So 2 seconds more! πŸ€“
                                  thomthom-example1v6.skp
