    [Request] Rotate Constrained
    16 Posts 8 Posters 868 Views 8 Watching
      I see.
        All that is very cryptic! πŸ’š
        • tt_suT
          tt_su
          @rich o brien said:
          @Dave
          No, I posted a simple example for illustration. I'm dealing with substantially more geometry 😞
          Example? The simple example you posted wouldn't be too hard - but it'd be difficult to make it scale. How is the real life scenario like?
            @thom
            See attached..
            thomthom-example.skp
            ...I think having pivot point in SU would be very beneficial.
            I suppose in this example I am looking for linear falloff extrude
            • cottyC
              cotty
              Not one step, but relatively fast:
              • draw face
              • use EEbyVtO (Extrude Edge by Vector to Object) from TIGs Extrusion Tools
              my SketchUp gallery
              • tt_suT
                tt_su
                In that case you want to apply a restraint on all the vertical edges to keep their directions. That would be doable. But I think you'd have to create a custom tool as this would be difficult to do with observers intercepting the native tools.
                  AAAh, now I See! Vicious problem! πŸ˜„
                  • gillesG
                    gilles
                    for me with Fredo's taper tool it's a one step.
                      Excellent! 😳 πŸ’š 😎 β˜€ πŸ‘
                      The trick was to take the entiere object! πŸ€“ πŸ˜’
                      "Pourquoi faire simple quand on peut faire compliquΓ©!" πŸ˜†
                      "Why make it simple when it can be complicated!"
                      Same remark than above: you must draw first something for the "Hot Point" with the protractor! πŸ€“
                      Because the Taper Tool has a distance and not an angle!
                      Normally a simple Help Line with the protractor is sufficient! πŸ€“
                      Morality : a rotation with constraint is just a tapering tapered taper! β˜€
                        Not so vicious! πŸ˜‰
                        Fredo Scale again! β˜€
                        Tapering of the bounding box seems make the trick ! πŸ’š So the Doh Duh for Rich! πŸ˜„
                        & CleanUp by Thomthom at the end! πŸ˜‰
                        10 seconds with a hand attached in the back πŸ’š
                        Of course you must make an Helper guide line of the angle wished first by the external Top edge! πŸ€“
                        So 2 seconds more! πŸ€“
                        thomthom-example1v6.skp
