    [Request] Rotate Constrained
    16 Posts 8 Posters 533 Views 8 Watching
      In SU when you rotate a selection thus...
      ...it narrows/widens the dimension
      Is there a tool tht prevent this so the dimension is constrained on rotation...
      I know I can place a series of guide and shift geometry around afterwards.
      Or I am having a Doh! moment....
      • mitcorbM Offline
        mitcorb
        Hi, Rich:
        The only way I know, is to rotate copy and correct the geometry. Do you mean a script? Perhaps Didier Bur's Projections?
          Seems there is the FredoScale for that πŸ˜‰
          I come back in 5 minutes for the video by himself! β˜€
          from this thead of anthology πŸ˜„
          Second video ...But maybe i don't understand the question 😳
          http://sketchucation.com/forums/download/file.php?id=87785
          http://sketchucation.com/forums/download/file.php?id=87786
          • BoxB Offline
            You are right Pilou, you haven't understood the question. πŸ’š
              So just using Move on the endpoint/corner wouldn't work for you?
                @Dave
                No, I posted a simple example for illustration. I'm dealing with substantially more geometry 😞
                  I see.
                    All that is very cryptic! πŸ’š
                    • tt_suT Offline
                      tt_su
                      @rich o brien said:
                      @Dave
                      Example? The simple example you posted wouldn't be too hard - but it'd be difficult to make it scale. How is the real life scenario like?
                        @thom
                        See attached..
                        thomthom-example.skp
                        ...I think having pivot point in SU would be very beneficial.
                        I suppose in this example I am looking for linear falloff extrude
                        • cottyC Offline
                          cotty
                          Not one step, but relatively fast:
                          • draw face
                          • use EEbyVtO (Extrude Edge by Vector to Object) from TIGs Extrusion Tools
                          my SketchUp gallery
                          • tt_suT Offline
                            tt_su
                            In that case you want to apply a restraint on all the vertical edges to keep their directions. That would be doable. But I think you'd have to create a custom tool as this would be difficult to do with observers intercepting the native tools.
                              AAAh, now I See! Vicious problem! πŸ˜„
                              • gillesG Offline
                                gilles
                                for me with Fredo's taper tool it's a one step.
                                  Excellent! 😳 πŸ’š 😎 β˜€ πŸ‘
                                  The trick was to take the entiere object! πŸ€“ πŸ˜’
                                  "Pourquoi faire simple quand on peut faire compliquΓ©!" πŸ˜†
                                  "Why make it simple when it can be complicated!"
                                  Same remark than above: you must draw first something for the "Hot Point" with the protractor! πŸ€“
                                  Because the Taper Tool has a distance and not an angle!
                                  Normally a simple Help Line with the protractor is sufficient! πŸ€“
                                  Morality : a rotation with constraint is just a tapering tapered taper! β˜€
                                    Not so vicious! πŸ˜‰
                                    Fredo Scale again! β˜€
                                    Tapering of the bounding box seems make the trick ! πŸ’š So the Doh Duh for Rich! πŸ˜„
                                    & CleanUp by Thomthom at the end! πŸ˜‰
                                    10 seconds with a hand attached in the back πŸ’š
                                    Of course you must make an Helper guide line of the angle wished first by the external Top edge! πŸ€“
                                    So 2 seconds more! πŸ€“
                                    thomthom-example1v6.skp
