    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 656.3k Views 155 Watching
      daniabreu1
      Good evening everybody,
      Again I am having problem ith the thickener.
      Date: 15-Apr-20 20:31:28
      An error occurred in Thickener
      Error in generation of the geometry
      Cannot convert argument to Geom::Point3d
      jointpushpullgeometry.rbe:: 531 -- vector_to
      jointpushpullgeometry.rbe:: 531 -- geometry_block_reversal
      jointpushpullgeometry.rbe:: 243 -- geometry_robot_prepare_mesh
      jointpushpullgeometry.rbe:: 212 -- robot_call_action
      jointpushpullgeometry.rbe:: 183 -- geometry_robot_exec
      jointpushpullgeometry.rbe:: 166 -- geometry_robot
      jointpushpullgeometry.rbe:: 81 -- block in geometry_execute
      lib6operation.rbe:: 370 -- step_geometry
      lib6operation.rbe:: 419 -- start_execution
      jointpushpullgeometry.rbe:: 81 -- geometry_execute
      jointpushpulltool.rbe:: 1118 -- go_preview_or_geom
      jointpushpulltool.rbe:: 844 -- dragging_stop
      jointpushpulltool.rbe:: 1399 -- execute_validate
      jointpushpulltool.rbe:: 1590 -- onReturn
      I have LibFredo6v9.5k and using SU2020. There is a post describing almost the same thing:
      "It's a fairly complex surface - a piece of terrain that is a hill with sections cut out of it (I draped a road onto the surface so that counts as a separate surface, for example)."
      It was solve with Libfredo 9.0 but I have 9.5 version.
      Any idea?
      Thank you all.
      • fredo6F Offline
        I fixed the error in the code, but somehow this reflects a problem or complexity in the generated geometry. It may be helpful to get the model where it happens.
        I am no longer able to publish updates to my plugins, pending Sketchup changes to their releasing process for developers.
        So the fix will go in the next version whenever I can resume publishing.
          rv1974
          Hi Fredo,
          Say I have a surface cut to non-coplanar patches by visible edges.
          I can't find a proper combination of Borders+Surface selection settings to perform a global JPP so every patch would get an independent border by contour (BTW there's some negative molding).
          I'm able to JJP manually patch-by-patch (demonstrated in attached gif) but there's no way to process all surface en-masse instantly.
          Would it be possible to implement please?
          • fredo6F Offline
            First, you could select the 4 surfaces at once
            • select the first surface
            • Move over the other surfaces with SHIFT pressed
            • Release Shift
            Second, if you do it surface by surface, you should toggle on the button "Neighbour influence" in the 'Misc' sub-palette.
              rv1974
              Fredo, I don't understand. Could you please show 'one click' procedure (not strip by strip clicks). thank you in advance.
              Untitled.skp
              • fredo6F Offline
                I am not clear. Do you want a 'valley' between each surface or have them joined.
                If you wish the valleys, then you have to select the surfaces one by one. Otherwise, you would mold the whole terrain.
                  rv1974
                  πŸ˜† you just exactly reproduced the way I created the 'wanted' model.
                  Originally I just wanted clarity (or request πŸ˜‰) maybe there's some combination of settings that allows to achieve the 'wanted' result without tedious 'one by one' clicking
                  • fredo6F Offline
                    @rv1974 said:
                    :lol: you just exactly reproduced the way I created the 'wanted' model.
                    Many things can be done, but it would make the UI more complex...
                      rv1974
                      something like this
                        rv1974
                        Ok, I'm just suggesting to tweak the plugin's behavior without UI changing:
                        If face selection = surface,
                        molding not equal 0,
                        borders = grid,
                        Then
                        'moldings' to be created between surfaces (and not along contour only)?
                          a_pusen
                          This does not work in Sketchup 2020 after installing the latest Fredotools. When will this be fixed?
                            It should work OK.
                            You need the latest RBZs installing for the Fredo Extensions and his LibFredo.
                            Note that the JPP Extension is separate from FredoTools Extension ???
                            After installing them you'll also need to restart SketchUp to sync everything.
                            When you say, "it doesn't work", what is the problem ? what are the error messages ? etc - providing those [if any] would help us to help you...
                              Tymnastik
                              Please I have installed fredo jpits shows on the tool bar but it won't work
                                Did you also install LibFredo6?
                                What version of SketchUp are you actually using? Your profile says 2018 Free/Make but there is no such version. Knowing the right version could help us help you.
                                  AISmebel
                                  hi Fredo.
                                  I ran into such a problem, I cannot make a uniform indentation around the entire perimeter on a model with an irregular shape. I couldn't find any plugin that could do this.
                                  I have a big request to you to consider this improvement in the next versions of your excellent plugin. Thank you so much for your work!
                                  https://youtu.be/wCsli3Ps7xc
                                    slb_jwm
                                    Joint push pull Joint and Thickener both fail with errors when I try to make this skin (part of a geodesic dome of frequency 3) thicker (by 3/4"). But they only do it when the component is part of a larger model.
                                    In a separate model, both those forms work, but only extrude normal to the faces (as designed).
                                    Extrude works, but takes only an average direction, presumably along the radius to the centre of the hexagon.
                                    Feature request: could there be an option in the existing plugin to enlarge radially from a given centre? Either the origin of a component opened for editing, or perhaps picked by the user?
                                    Trying to thicken this radially from its origin.
                                    I've managed to do it approximately with the Scale tool, but can't get it to scale to an exact thickness of 3/4"
                                      Is this what you're trying to do?
                                      Click on the picture
                                      • fredo6F Offline
                                        JPP Thickening is done along the normal of faces. If it happens that all faces are perpendicular to the the radial dierction, then it is OK.
                                          Raimondo_Vincenti
                                          Installed libfredo6 11.4f -> JointPushPull is not awailable and cannot be installed anymore.
                                          Message(german): "JointPushPull_v4.4e.rbz konnte nicht installiert werden."
                                            Where are you looking for it?
                                            SketchUp Plugins | PluginStore | SketchUcation
                                            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                            (sketchucation.com)
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 30
                                            • 31
                                            • 23 / 31
