    Triangulate triangles ?
    41 Posts 8 Posters 12.2k Views 8 Watching
      Does this is existing ?
      SandBox makes something but one by one and you must find the red point! ๐Ÿ˜ฎ
      (read image right to left ๐Ÿ˜ณ Like Suzan ๐Ÿ˜„
        See a new entry of an oldie in the SCF PluginStore...
        http://sketchucation.com/forums/viewtopic.php?p=495376#p495376
          Seems that is not the trick!
          You must find first the middle point intersection on the face! ๐Ÿ˜„
          And works only face by face!
          I have tried your "Add Center Point": alas that don't work for a triangle! (for it's edges yes but not for the face itself)
          I have tried your "Center of Gravity": alas that don't work with a face
          There is something cool with your roof plugin, alas that works only one trangular face by one triangular face (and the minimum angle of roof is 1ยฐ and not 0ยฐ ๐Ÿ˜„
          (the angle problem will be not a problem : we can flatten the result - but face one by one is a problem ๐Ÿ˜„
          And there is a little deviation / view top / Camera projection Parallel
            seems it's also the connections of the medians and the gravity center of a triangle so
            an interesting thing! ๐Ÿ˜„
              Does it need to be 3 tris? Can it be 4?
                  4 ? Like what ? Please an image! You speak of a quadrangle hidden on a triangle ?
                  No 3 triangles!
                  A simple triangle(s)( any number ) with this simple construction of 3 medians ๐Ÿ˜„
                  • renderizaR
                    renderiza
                    Adding the feature to slit multiple face by automatically finding the center point will be great addition! This should triangulate any type of face aka trig, quad, ect... Because your connecting a line from center to every other vertex. Maybe adding things like skip one vertex every time you add a line will be interesting to see.
                    Rich O Brian that would be great as well!
                    [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                      It is Artisan subdivide. Thank you Catmull Clark ๐Ÿ˜‰
                        So no! ๐Ÿ˜„ And why not the connections with middles ?
                        Medians are wanted! ๐Ÿ˜„
                        But if you a have the plugin why not, that can be used for other thing ๐Ÿ˜„
                          Yep cool, but not like the first post ๐Ÿ˜„
                          And I should know it! ๐Ÿ˜‰
                            Alas I have deserted the Ruby language for a while! ๐Ÿ˜ž
                            If you can make a little plugin that will be wonderful ๐Ÿ˜Ž
                            • renderizaR
                              renderiza
                              Here is an example code for achieving what you want Pilou...
                              model = Sketchup.active_model
                              ents = model.active_entities
                              sel = model.selection
                              faces = ents.grep(Sketchup;;Face)
                              faces.each do |face|
                                vertices = face.vertices
                                bbox = face.bounds
                                cpoint = bbox.center
                                vertices.each do |vertex|
                                  p1 = cpoint
                                  p2 = vertex
                                  line = ents.add_line p1,p2
                              Note: Some very pretty geometry start appearing when you keep splitting! ๐Ÿ‘
                              • renderizaR
                                renderiza
                                I will do that! ๐Ÿ‘
                                  Beat me to it ๐Ÿ˜‰
                                  You might want to change the
                                  faces = ents.grep(Sketchup::Face)
                                  to
                                  faces = **sel**.grep(Sketchup::Face)
                                  So then the user changes only selected faces ?
                                  OR perhaps
                                  faces = sel.grep(Sketchup::Face) faces = ents.grep(Sketchup::Face) **unless faces[0]**
                                  so it works on a selection OR everything if there is no selection...
                                  Also you want to make it undoable, so add
                                  **model.start_operation('subtri')** faces.each... ...end **model.commit_operation**
                                  ๐Ÿค“
                                  • renderizaR
                                    renderiza
                                    Hahaha!
                                    TIG I would be very happy if you modify your existing plugin to add Pilou is feature request. ๐Ÿ‘
                                    I am interested in making this for learning and I have some additional ideas I want to explore. I consider you my mentor TIG and there will never be competition between you and me I promise! ๐Ÿ’š
                                    By the way thanks for the suggestion! ๐Ÿ‘
                                    Here is updated code...
                                    faces = sel.grep(Sketchup;;Face)
                                    model.start_operation('csplit')
                                        bbox = face.bounds
                                          p1 = cpoint
                                          p2 = vertex
                                      sel.clear
                                      OK
                                      I'll make a simple script and publish it shortly...
                                      • renderizaR
                                        renderiza
                                        Thank you TIG! ๐Ÿ‘
                                          anar
                                          Thanks Pilou !
                                          You convinced TIG...
                                          And Thanks TIG, I think it's a must have !
                                          http://www.polyloop.net/attachment.php?attachmentid=32959&d=1382032801
                                            Try this http://sketchucation.com/forums/viewtopic.php?p=495430#p495430
                                            TriangulateAllFaces...
                                            • 1 / 3
