    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 220.5k Views 79 Watching
      Mr. Bill
      I have had trouble getting this ruby to load in SU8 pro, which i see a few others have previously screamed/posted. I have used thomthom's installer plugin as well as just placing the .rb in the appropriate plugin folder. I've had success loading .rbz, but not .rb in general. This .rb is just particularly needed at the moment. Both come back with the error below. Input appreciated.
      Thanks,
        Is that either, the only plugin you have installed - or the first file alphabetically in your Plugins folder?
        I'm guessing it's either one of them and that the file is missing require 'sketchup.rb' at the beginning of the file. Check the file in notepad, and insert that line at the top of the file if it's missing.
          Mr. Bill
          thank you thomthom,
          I tried typing that in at a few different beginning locations to no avail, even compared it to one of you .rb.
          Unfortunately operator error (me) is in play. With that said i've uploaded the .rb (is that kosher to do with someone else's .rb? i'm sorry for not knowing protocol here) and if someone was able to determine where that require 'sketchup.rb i would be eternally grateful.
          [mod=:3stt16al]I've removed that FAK.rb attachment, as it's already available in the first post here and such duplicates simply lead to confusion...
          TIG[/mod:3stt16al]
            As thomthom said, you are missing a line of code require 'sketchup.rb' which should be on a line on its own at the very beginning of the file [indeed any file using some of sketchup's own methods like file_loaded? should include this line of code].
            So... check the FAK.rb file by opening it in Notepad [or any other plain-text editor, BUT never a wordprocessor!], and insert that simple line at the very top [include it exactly as the red text shown above - with the two enclosing '' around the second part etc].
            On a restart SketchUp should no longer throw up the error...
            Incidentally, if you had more scripts loading the chances are the 'sketchup.rb' would have already been 'required' by one of them, and the error would never have manifested - because once a file has been loaded a later 'require' skips over it... That's probably why this omission in this script has gone unnoticed for so long...
              Mr. Bill
              Thanks guys, i was missing the enclosing '', but it works now.
              • cottyC
                cotty
                Example with standard follow-me (c) and FAK (d)...
                Thank you for this plugin!
                my SketchUp gallery
                • P
                  phoeniax
                  It does not work now i used it for some time now it does nor do anything
                    Obviously it does work for many people!
                    If you explain better what doesn't work, what's installed, what's changed etc... we might find what's wrong.
                    • JBJDesignsJ
                      JBJDesigns
                      Thank you wikii! I can really use this tool!!! Jo πŸ˜„
                      ...you send them to school, you give them books, and they eat the pages...
                      • N
                        News
                        Hi everyone,
                        I am trying to draw a handrail for "2 quart tournant" stairs ( don't know the word in english πŸ˜• ) since a bit.
                        When i saw this plugin i thought a miracle will come, but actually after i downloaded and installed it...nothing happened !
                        I select my path and my shape and then click on the FAK pluginin my plugin menu, but nothing happens.
                        Where am i wrong ? What do i don't understand ?
                        Please help, this handrail is making me crazy !
                        Thanks !!
                        Handrail stairs.skp
                        • BoxB
                          The profile and path need to be in the same context. Put the profile into the paths group and try again. Your path isn't continuous either, there is a slight problem in the top straight section, easy fix, delete it and redraw it making sure to connect properly with the curve.
                          • N
                            News
                            Thank you soo much for answering so quickly !
                            I tried to do what you explain, but nothing happens again.
                            I may not redraw and fix well the straight sections, but i don't know how to do it properly.
                            Would you help me again ? could you join the .skp file you did for me to see how you did ?
                            Thanks again !
                            • N
                              News
                              I even tried to connect the lines with the Weld ruby script, then put the profile into the path context, but it dosen't work.
                              • BoxB
                                Here you go.
                                Handrail.skp
                                • N
                                  News
                                  Ohh merci ! But i have SU8 so i can't open your file who is in SU13 πŸ˜•
                                  • BoxB
                                    Why does your profile say 2013, I checked that before I saved it.
                                    SU8
                                      Here is the 'written' version...
                                      Edit the path group...
                                      Double-click on an end segment.
                                      If there is a break in the path not all of it will highlight.
                                      Zoom into the 'gap' between the parts.
                                      In this case it's near the top part and very small...
                                      Either draw in the missing piece, or perhaps more easily - deselect everything, and then use the Move tool to drag and relocated the end of one part snapped onto the other, thereby closing the gap.
                                      Double-click again and everything should highlight.
                                      IF you want a smooth path now 'weld' the selection, and provided there are no branching lines in the path [none in this case], it'll become a single 'curve': this will select with a single pick-click.
                                      Exit the path edit.
                                      That's the path fixed.
                                      Next... did you understand the part about 'same context'.
                                      You only need one profile and that needs to be at one end of the path.
                                      Delete any others?
                                      Now select the profile and Edit>Cut.
                                      Edit the path group again and Edit>Paste In Place to add the profile onto the path end.
                                      Now you should be able to use FAK [FollowMeAndKeep] on the desired path and the profile face as desired... You may need to smooth the result or reverse faces [depends on the profile's initial orientation], or with View > Hidden Geometry ON you may wish to make some of the form's edges solid [NOT smoothed/softened] - so select them and use the Entity Info check-boxes to adjust as desired...
                                      • N
                                        News
                                        Merci beaucoup beaucoup !
                                        I will try to do exactly what you say.
                                        Hope i'll be smart enough to suceed !
                                        • N
                                          News
                                          And thank you Box, i can open it now!
                                          • N
                                            News
                                            What i don't understand is that when i use the move tool at the end of the straight line on the top, the curved line moves with it, as if it was already snapped. So i don't figure out where is the gap you are talking about
                                            • 11
                                            • 12
                                            • 9 / 12
