    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • solid-woodS Offline
      solid-wood
      Hi Fredo,
      Why don't I get the same functions in Mac 10.6 for "Streching" target?
      Can't move the fixed point...windows is what I am trying to strech.
      Only moves in the center glass, the L&R glas stayes the same. Doesn't matter where I put the "X"
      Please help. Thanks
      Solid-Wood
        solid-wood
        Hi Fredo,
        Just got it...From the new video, thanks. Works like a charm.
        Wonderful!
        SW
        • guanjinG Offline
          guanjin
          Hello Fredo6
          In sketchup2013 normal display Chinese language, Chinese language does not show sketchup8M5 is still in English.
          I LibFredo6 5.2 or higher
          Thank you
          • fredo6F Offline
            @guanjin said:
            Hello Fredo6
            Thank you
            I know and this is true for all languages.
            This is related to the change of naming conventions. I need to republish.
            In the meantime, just replace __Module = FredoScale by __Module = F6_FredoScale in the file FredoScale_ZH.lang
            • guanjinG Offline
              guanjin
              @fredo6 said:
              @guanjin said:
              Hello Fredo6
              Thank you
              Thank you, waiting for your new release! 👍
              • fredo6F Offline
                NEW RELEASE: FredoScale v2.5b - 15 Sep 13
                FredoScale 2.5b fixes a bug preventing language translations to load.
                FredoScale 2.5 requires LibFredo6 5.2 or higher.
                  dedmin
                  After the update:
                  • fredo6F Offline
                    @dedmin
                    Thanks very much. I updated the post and Plugin Store today at 15h.
                      dedmin
                      BTW, did You see this:
                      http://sketchucation.com/forums/viewtopic.php?f=323&t=46473&start=90
                      http://sketchucation.com/forums/viewtopic.php?f=323&t=54176
                      • fredo6F Offline
                        @dedmin said:
                        :thumb: 👍
                        1. For Curvizard Edge Prop, I had found the bug actually but forgot to republish
                        2. For BezierSpline, I have to investigate. This is old code and the tooltip may not reflect the correct alignment
                        • guanjinG Offline
                          guanjin
                          Thank timely updates, thank you 😍
                          • LanaL Offline
                            Lana
                            Thank you, thank you, thank you....is very good.
                            • enigmaticE Offline
                              enigmatic
                              Hi Fredo,
                              Is it normal dimensions differences in?
                              scale_01
                              scale_02
                              • dereiD Offline
                                derei
                                @enigmatic said:
                                Hi Fredo,
                                Maybe some rounding ... bug? I'm guessing it rounds in all situations, not considering the units used (and number of decimals) ?
                                  samothrace41
                                  Bonjour,
                                  J'utilise régulièrement FredoScale et Curviloft et je viens de télécharger Joint Push/Pull. Je voudrais te faire une petite donation (symbolique) mais je ne veux pas passer par PayPal. Je voudrais t'envoyer un mail mais je n'ai pas ton adresse. Le mien est samothrace41 @ yahoo.fr
                                  A+
                                  Sylvie
                                    jumpjack
                                    I don't understand if this plugin can help me.
                                    I have a non-planar surface close to a cylindrical surface; I want to extrude a region of the non-planar surface up to the cylinder to create a solid 3d joint between cylinder and the non-planar surface.
                                    Can I use this plugin, or do I need another one?
                                      If you want to project the bottom face of the cylinder down onto the surface then look at my ExtrudeEdgesByVector[ToObject] tool.
                                      Edit the cylinder [group?] and copy the bottom face.
                                      Exit the edit and use Edit>PlaceInPlace.
                                      Select the face-copy [double-click].
                                      Activate EEby..Object tool and pull a vertical [blue] vector down through your surface.
                                      The face is extruded and stops on the surface...
                                      With some finely divided surfaces the 'auto-trim' might fail, so in that case extrude through and manually intersect/delete parts.. With the simple 'toVector' version of the tool it extrudes through the surface - in that case then edit the grouped extrusion and Select its geometry and then use Intersect with Model: now Select [by fence] for the unwanted lower geometry and delete it.
                                        sunchart
                                        • hamedmemarH Offline
                                          hamedmemar
                                          excellent
                                          your amazing tools are very useful
                                          thank you very mach fredo
                                          • fredo6F Offline
                                            NEW RELEASE: FredoScale v2.6a - 27 Nov 13
                                            FredoScale 2.6a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                                            • 56
                                            • 57
                                            • 8 / 57
