    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
      If you have lots of nested groups that have duplicates try this one-liner, copy+paste+<enter> in the Ruby Console - every group in the model is made unique...
      Sketchup.active_model.definitions.each{|d|(d.instances.each{|i|i.make_unique})if d.group? && d.instances[1]}
      • solid-woodS
        solid-wood
        Hi Fredo,
        Why don't I get the same functions in Mac 10.6 for "Streching" target?
        Can't move the fixed point...windows is what I am trying to strech.
        Only moves in the center glass, the L&R glas stayes the same. Doesn't matter where I put the "X"
        Please help. Thanks
        Solid-Wood
        • solid-woodS
          solid-wood
          Hi Fredo,
          Just got it...From the new video, thanks. Works like a charm.
          Wonderful!
          SW
          • guanjinG
            guanjin
            Hello Fredo6
            In sketchup2013 normal display Chinese language, Chinese language does not show sketchup8M5 is still in English.
            I LibFredo6 5.2 or higher
            Thank you
            • fredo6F
              @guanjin said:
              Hello Fredo6
              Thank you
              I know and this is true for all languages.
              This is related to the change of naming conventions. I need to republish.
              In the meantime, just replace __Module = FredoScale by __Module = F6_FredoScale in the file FredoScale_ZH.lang
              • guanjinG
                guanjin
                @fredo6 said:
                @guanjin said:
                Hello Fredo6
                Thank you
                Thank you, waiting for your new release! 👍
                • fredo6F
                  NEW RELEASE: FredoScale v2.5b - 15 Sep 13
                  FredoScale 2.5b fixes a bug preventing language translations to load.
                  FredoScale 2.5 requires LibFredo6 5.2 or higher.
                    dedmin
                    After the update:
                    • fredo6F
                      @dedmin
                      Thanks very much. I updated the post and Plugin Store today at 15h.
                        dedmin
                        BTW, did You see this:
                        http://sketchucation.com/forums/viewtopic.php?f=323&t=46473&start=90
                        http://sketchucation.com/forums/viewtopic.php?f=323&t=54176
                        • fredo6F
                          @dedmin said:
                          :thumb: 👍
                          1. For Curvizard Edge Prop, I had found the bug actually but forgot to republish
                          2. For BezierSpline, I have to investigate. This is old code and the tooltip may not reflect the correct alignment
                          • guanjinG
                            guanjin
                            Thank timely updates, thank you 😍
                            • LanaL
                              Lana
                              Thank you, thank you, thank you....is very good.
                              • enigmaticE
                                enigmatic
                                Hi Fredo,
                                Is it normal dimensions differences in?
                                scale_01
                                scale_02
                                • dereiD
                                  derei
                                  @enigmatic said:
                                  Hi Fredo,
                                  Maybe some rounding ... bug? I'm guessing it rounds in all situations, not considering the units used (and number of decimals) ?
                                  DESIGNER AND ARTIST DEREI.UK
                                    samothrace41
                                    Bonjour,
                                    J'utilise régulièrement FredoScale et Curviloft et je viens de télécharger Joint Push/Pull. Je voudrais te faire une petite donation (symbolique) mais je ne veux pas passer par PayPal. Je voudrais t'envoyer un mail mais je n'ai pas ton adresse. Le mien est samothrace41 @ yahoo.fr
                                    A+
                                    Sylvie
                                      jumpjack
                                      I don't understand if this plugin can help me.
                                      I have a non-planar surface close to a cylindrical surface; I want to extrude a region of the non-planar surface up to the cylinder to create a solid 3d joint between cylinder and the non-planar surface.
                                      Can I use this plugin, or do I need another one?
                                        If you want to project the bottom face of the cylinder down onto the surface then look at my ExtrudeEdgesByVector[ToObject] tool.
                                        Edit the cylinder [group?] and copy the bottom face.
                                        Exit the edit and use Edit>PlaceInPlace.
                                        Select the face-copy [double-click].
                                        Activate EEby..Object tool and pull a vertical [blue] vector down through your surface.
                                        The face is extruded and stops on the surface...
                                        With some finely divided surfaces the 'auto-trim' might fail, so in that case extrude through and manually intersect/delete parts.. With the simple 'toVector' version of the tool it extrudes through the surface - in that case then edit the grouped extrusion and Select its geometry and then use Intersect with Model: now Select [by fence] for the unwanted lower geometry and delete it.
                                          sunchart
                                          • hamedmemarH
                                            hamedmemar
                                            excellent
                                            your amazing tools are very useful
                                            thank you very mach fredo
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 58
                                            • 59
                                            • 41 / 59
