    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
      rowandoyle
      Hello,
      I know there is already a post on this topic, but it is a little advanced for this Newbie! This is my first attempt at downloading a plugin.
      I am running Mac OSX and downloaded FredoScale into the appropriate folder - Library/Application Support/Google Sketchup 8/Sketchup/Plugins.
      I also downloaded the LibFredo6 application (the accompanying software). I restarted my computer and sketch up and a new Ruby Console options appeared under windows, but I can't find the plugin.
      Any help would be greatly appreciated! It is probably something obvious, but I don't know where else to look.
      I am also super excited to try this tool!
      Thanks...
        If all you did was download and save the files into the Plugins folder, you didn't install them. You're right, this has been covered before. Many times. The link to FredoScale is for a ZIP file. You need to extract the contents of the ZIP file. You should wind up with a folder called FredoScale... When you download the LibFredo files you'll get either a ZIP file or the RBZ file depending upon the link you've clicked on. If you got the ZIP file, extract the contents making sure to respect and maintain the file structure. If you got the RBZ file, install it by going to Preferences>Extensions and click on Install Extension... Navigate to the location in which you saved the RBZ file, select it and click Open.
        It would be easier in the future if you install the Sketchucation Plugin Store, linked above, and auto-install plugins after that.
        • fredo6F Offline
          NEW RELEASE: FredoScale v2.4a - 22 Aug 13
          FredoScale 2.4 is a technical release that implements naming conventions for files and folders to be compliant with EWH requirements. Otherwise there is no functional changes in this release.
          FredoScale 2.4 requires LibFredo6 5.1 or higher.
          The footprint for FredoScale is based on one file and one subfolder:
          It is also a good idea to clean up your plugin directory and remove the older versions.
          In the menu Windows > LibFredo6 Settings...> Purge Obsolete Files, you will find a dialog box allowing to remove all or some of these older versions.
          • fredo6F Offline
            NEW RELEASE: FredoScale v2.5a - 30 Aug 13
            FredoScale 2.5 is a technical release that implements naming conventions for files and folders to be compliant with EWH requirements. Otherwise there is no functional changes in this release.
            FredoScale 2.5 requires LibFredo6 5.2 or higher.
            • F Offline
              flyashy
              @fredo6 said:
              @macker said:
              Does anyone else have sketchup crash completely when using the scale/stretch tool on groups that contain groups? I always use extensive grouping so that I can take my models into 3ds max, and this tool would undoubtedly speed up my workflow - but keeps crashing sketchup.
              This may be related to the big issues of "freshly copied groups".
              In your case, was one of the group a copy of another one (you should see "2 instances" in the Entity Info Window.
              If this is the case, then FredoScale needs some evolutions. I have done it on Curvizard.
              As a workaround for complex hirearchy of groups and components, try to perform a Make Unique before [highlight=#ffff80:1qv24jnd](Make Unique is also part of FredoScale).[/highlight:1qv24jnd]
              I didn't understand that bit about Make Unique being part of fredoscale.
              Is there a hidden option in FredoScale command that allows me to make the group unique?
              (I work with groups within groups within groups within.. with a smattering of components thrown in the mix and copies of them all floating all over my models, all the time and could never use fredoStretch as it gives a splat.)
              Or alternately is there a way to make the copied 'group' unique? Components I know, groups I don't know how to make unique.
              Cheers,
              flyashy
                If you have lots of nested groups that have duplicates try this one-liner, copy+paste+<enter> in the Ruby Console - every group in the model is made unique...
                Sketchup.active_model.definitions.each{|d|(d.instances.each{|i|i.make_unique})if d.group? && d.instances[1]}
                • solid-woodS Offline
                  solid-wood
                  Hi Fredo,
                  Why don't I get the same functions in Mac 10.6 for "Streching" target?
                  Can't move the fixed point...windows is what I am trying to strech.
                  Only moves in the center glass, the L&R glas stayes the same. Doesn't matter where I put the "X"
                  Please help. Thanks
                  Solid-Wood
                    solid-wood
                    Hi Fredo,
                    Just got it...From the new video, thanks. Works like a charm.
                    Wonderful!
                    SW
                    • guanjinG Offline
                      guanjin
                      Hello Fredo6
                      In sketchup2013 normal display Chinese language, Chinese language does not show sketchup8M5 is still in English.
                      I LibFredo6 5.2 or higher
                      Thank you
                      • fredo6F Offline
                        @guanjin said:
                        Hello Fredo6
                        Thank you
                        I know and this is true for all languages.
                        This is related to the change of naming conventions. I need to republish.
                        In the meantime, just replace __Module = FredoScale by __Module = F6_FredoScale in the file FredoScale_ZH.lang
                        • guanjinG Offline
                          guanjin
                          @fredo6 said:
                          @guanjin said:
                          Hello Fredo6
                          Thank you
                          Thank you, waiting for your new release! πŸ‘
                          • fredo6F Offline
                            NEW RELEASE: FredoScale v2.5b - 15 Sep 13
                            FredoScale 2.5b fixes a bug preventing language translations to load.
                              dedmin
                              After the update:
                              • fredo6F Offline
                                @dedmin
                                Thanks very much. I updated the post and Plugin Store today at 15h.
                                  dedmin
                                  πŸ‘ πŸ‘
                                  BTW, did You see this:
                                  http://sketchucation.com/forums/viewtopic.php?f=323&t=46473&start=90
                                  http://sketchucation.com/forums/viewtopic.php?f=323&t=54176
                                  • fredo6F Offline
                                    @dedmin said:
                                    :thumb: πŸ‘
                                    1. For Curvizard Edge Prop, I had found the bug actually but forgot to republish
                                    2. For BezierSpline, I have to investigate. This is old code and the tooltip may not reflect the correct alignment
                                    • guanjinG Offline
                                      guanjin
                                      Thank timely updates, thank you 😍
                                      • LanaL Offline
                                        Lana
                                        Thank you, thank you, thank you....is very good.
                                        • enigmaticE Offline
                                          enigmatic
                                          Hi Fredo,
                                          Is it normal dimensions differences in?
                                          scale_01
                                          scale_02
                                          • dereiD Offline
                                            derei
                                            @enigmatic said:
                                            Hi Fredo,
                                            Maybe some rounding ... bug? I'm guessing it rounds in all situations, not considering the units used (and number of decimals) ?
                                            DESIGNER AND ARTIST DEREI.UK
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 58
                                            • 59
                                            • 41 / 59
