    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
    • fredo6F
      @guanjin said:
      Hello Fredo6
      In sketchup2013 normal display Chinese language, Chinese language does not show sketchup8M5 is still in English.
      I LibFredo6 5.2 or higher
      Thank you
      I know and this is true for all languages.
      This is related to the change of naming conventions. I need to republish.
      In the meantime, just replace __Module = FredoScale by __Module = F6_FredoScale in the file FredoScale_ZH.lang
      • guanjinG
        guanjin
        @fredo6 said:
        @guanjin said:
        Hello Fredo6
        Thank you
        Thank you, waiting for your new release! 👍
        • fredo6F
          NEW RELEASE: FredoScale v2.5b - 15 Sep 13
          FredoScale 2.5b fixes a bug preventing language translations to load.
          FredoScale 2.5 requires LibFredo6 5.2 or higher.
            dedmin
            After the update:
            • fredo6F
              @dedmin
              Thanks very much. I updated the post and Plugin Store today at 15h.
                dedmin
                BTW, did You see this:
                http://sketchucation.com/forums/viewtopic.php?f=323&t=46473&start=90
                http://sketchucation.com/forums/viewtopic.php?f=323&t=54176
                • fredo6F
                  @dedmin said:
                  :thumb: 👍
                  1. For Curvizard Edge Prop, I had found the bug actually but forgot to republish
                  2. For BezierSpline, I have to investigate. This is old code and the tooltip may not reflect the correct alignment
                  • guanjinG
                    guanjin
                    Thank timely updates, thank you 😍
                    • LanaL
                      Lana
                      Thank you, thank you, thank you....is very good.
                      • enigmaticE
                        enigmatic
                        Hi Fredo,
                        Is it normal dimensions differences in?
                        scale_01
                        scale_02
                        • dereiD
                          derei
                          @enigmatic said:
                          Hi Fredo,
                          Maybe some rounding ... bug? I'm guessing it rounds in all situations, not considering the units used (and number of decimals) ?
                          DESIGNER AND ARTIST DEREI.UK
                            samothrace41
                            Bonjour,
                            J'utilise régulièrement FredoScale et Curviloft et je viens de télécharger Joint Push/Pull. Je voudrais te faire une petite donation (symbolique) mais je ne veux pas passer par PayPal. Je voudrais t'envoyer un mail mais je n'ai pas ton adresse. Le mien est samothrace41 @ yahoo.fr
                            A+
                            Sylvie
                              jumpjack
                              I don't understand if this plugin can help me.
                              I have a non-planar surface close to a cylindrical surface; I want to extrude a region of the non-planar surface up to the cylinder to create a solid 3d joint between cylinder and the non-planar surface.
                              Can I use this plugin, or do I need another one?
                                If you want to project the bottom face of the cylinder down onto the surface then look at my ExtrudeEdgesByVector[ToObject] tool.
                                Edit the cylinder [group?] and copy the bottom face.
                                Exit the edit and use Edit>PlaceInPlace.
                                Select the face-copy [double-click].
                                Activate EEby..Object tool and pull a vertical [blue] vector down through your surface.
                                The face is extruded and stops on the surface...
                                With some finely divided surfaces the 'auto-trim' might fail, so in that case extrude through and manually intersect/delete parts.. With the simple 'toVector' version of the tool it extrudes through the surface - in that case then edit the grouped extrusion and Select its geometry and then use Intersect with Model: now Select [by fence] for the unwanted lower geometry and delete it.
                                  sunchart
                                  • hamedmemarH
                                    hamedmemar
                                    excellent
                                    your amazing tools are very useful
                                    thank you very mach fredo
                                    • fredo6F
                                      NEW RELEASE: FredoScale v2.6a - 27 Nov 13
                                      FredoScale 2.6a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                                      • utilerU
                                        utiler
                                        I recall a while ago the question being asked how to rotate accurately say a cross brace in a fence [see below]
                                        I'm drawing a louvre window and want my blades to be angled in 3D to accept shadowing but only want to open the blades to the point where the top of the blade is in the same horizontal line as the bottom of the blade above. This way in elevation I achieve a clean horizontal section as well as seeing depth in shadow.
                                        For the life of me I have been trying to rotate the lourve blades using Fredoscale rotate but do not have the option to inference to the centre of the louvre blade overlap... [middle of the 12mm overlap]
                                        I've attached the skippy to let you see what I'm doing as well as a short video.
                                        I expect it is something really simple that will make me look like a goose [holidays will do that...
                                        Lourves.swf
                                        Window-Lourve X1.skp
                                        Just Curious...
                                          Andrew, try this:
                                          Draw a short line segment along that horizontal guideline in the vicinity of where the corner of the bottom louver should be. You can then use Rotation by Selection and Angle of Plane (the red rotate icon) to rotate and snap to the line.
                                          Short line shown in blue
                                          Select the bottom louver.
                                          Get the red Rotate tool from Fredoscale.
                                          Click on the center of rotation.
                                          Click on the top corner of the louver.
                                          Click on the top corner again.
                                          Move the cursor over toward the line bringing the louver corner with it.
                                          When the line turns orange, click again to set the corner on the line.
                                          Do not repeat for the other louvers. Delete them and copy the rotated one up and make a linear array.
                                          Delete the little short line when you've finished with it.
                                          • utilerU
                                            utiler
                                            I can see what you've done here, Dave. THANKS!!!
                                            I was going into the component and trying to inference from within.....
                                            YOU DA MAN!!
                                            Just Curious...
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 58
                                            • 59
                                            • 41 / 59
