    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 63.1k Views 19 Watching
      mickath
      Hi All,
      I think this is a very useful plugin, but I do not understand how to use it despite after watching the videos, it will be more meaningful if those video include narration & explanation in sound.
      Mickath
        tak2hata
        Hi,All.
        I update this to ver 2.4 in Apr28,2013.
        Add Short/Full report for Webdialog.
        Bug fix about surface area in scaled component.
        Including area of back_face material.
        deal with instance name as priority to definition name when the name applied to instance.
        Hi,Camilozunga and Souto.
        It can work with the model including no solid.
        Thanks for the ideas from Goga63.
        Thanks! 😄
        by TAK2HATA
          tak2hata
          I update this to version 2.4.2. in May 16,2013.
          New function"SHOW CHART".
          Showing charts on browser with JAVASCRIPT INFOVIS TOOL KIT(http://philogb.github.io/jit/)
          Thanks.
          by TAK2HATA
          • kenK Offline
            ken
            OK, there is a problem with this version.
            The older version has a plugin called,solid_quatify2.rb and this upgrade has a plugin called, solid_quantify2.rb. So when you install this upgrade you don't over write the old version.
            Ken
              tak2hata
              Ken
              The older file name was mistake.
              Remove solid_quatify2.rb
              by TAK2HATA
              • bagateloB Offline
                bagatelo
                I found this plugin simply fantastic! Wonderful!
                But...
                If some component have several copies, with several scales from outside,is presented in the report as if everyone had the same size, and this is not desirable to me.
                Also would like to know if is possible to organize the report by displaying objects by layer, and if we can disable to make report to hidden layers.
                Thank you!
                • bagateloB Offline
                  bagatelo
                  You could take a look at these things I asked here?
                  http://sketchucation.com/forums/viewtopic.php?f=323&t=54080
                    tak2hata
                    But...
                    Thank you!
                    Hi,bagatelo.
                    I will fixe the first problem about scaled component.
                    but I'm sorry ,Now I am too busy.So wait this weekend.
                    I think the component in hidden layer is not included in report.
                    In the case of the faces in component are placed in hidden layer,
                    that faces are not included,but the number of that component are counted.
                    I think finding that case is difficult.
                    Please place the components on hidden layers.
                    And I will read your ask topic,
                    but I do not know I can create the function for the request.
                    by TAK2HATA
                      tak2hata
                      Hi,I updated this to version2.5.0
                      Bugfix::Calculate correctly volume of the solid in scaled group.
                      by TAK2HATA
                      • bagateloB Offline
                        bagatelo
                        Hello tak2hata , this is an important update. Thanks.
                        I think it would be very interesting if we could add in a particular component some items few who would not be modeled in 3D, but we could assign cost values​​. So when should copy such items automatically additional items would be added in the report.
                        It would also be interesting if our selves just set things like:
                        Set up a special layer, and for each item (component or group) (only those who were at the root of the outliner) additional other items would be included, which would not be modeled in 3d.
                        Thanks again for your efforts.
                        • H Offline
                          hebeijianke
                          SOLID MATERIAL CHANGER error
                          Error; #<NoMethodError; undefined method `entities' for #<Sketchup;;Edge;0x5f77d44>>
                          E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2141;in `selectVolumetrics2'
                          E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2130;in `each'
                          E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2130;in `selectVolumetrics2'
                          E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2094;in `select_bySOLIDMAT'
                          E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2009;in `wd_solid_material_changer'
                          E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2141;in `call'
                            tak2hata
                            Hi,hebeijianke.
                            I fix the problems in using Solid Material Changer.
                            Sorry for keep you waiting long time.
                            Thanks.
                            by TAK2HATA
                              jorgeeparra
                              IMPRESSIVE PLUGIN VERY USEFUL 👍
                                jorgeeparra
                                Nice plugin ..I Like it a lot it will be nice to be able to use Tag and profile columns just like you do with Materials
                                  cadmunkey
                                  It would be great if you could add the IFC classifier type to the quantities list.
                                  For example IFC_footings = 300m3.
                                  • gudio83G Offline
                                    gudio83
                                    is there a version compatible with sketchup 2015 x64?
                                      cadmunkey
                                      tak2hata hasn't posted for a while now, I think he's really busy.
                                        What makes you think it is not compatible ?
                                        It has no compiled C add-ons so it should work with either bit-ness.
                                        • gudio83G Offline
                                          gudio83
                                          Its show me only the total amount (m3). All components are with 0 value for all dimensions. I try to take off the quantity of components and groups made by housebuilder
                                            PM the author...........
                                            • 3 / 4
