    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 63.0k Views 19 Watching
    • bagateloB Offline
      bagatelo
      Hello tak2hata , this is an important update. Thanks.
      I think it would be very interesting if we could add in a particular component some items few who would not be modeled in 3D, but we could assign cost values​​. So when should copy such items automatically additional items would be added in the report.
      It would also be interesting if our selves just set things like:
      Set up a special layer, and for each item (component or group) (only those who were at the root of the outliner) additional other items would be included, which would not be modeled in 3d.
      Thanks again for your efforts.
      • H Offline
        hebeijianke
        SOLID MATERIAL CHANGER error
        Error; #<NoMethodError; undefined method `entities' for #<Sketchup;;Edge;0x5f77d44>>
        E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2141;in `selectVolumetrics2'
        E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2130;in `each'
        E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2130;in `selectVolumetrics2'
        E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2094;in `select_bySOLIDMAT'
        E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2009;in `wd_solid_material_changer'
        E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2141;in `call'
          tak2hata
          Hi,hebeijianke.
          I fix the problems in using Solid Material Changer.
          Sorry for keep you waiting long time.
          Thanks.
          by TAK2HATA
            jorgeeparra
            IMPRESSIVE PLUGIN VERY USEFUL 👍
              jorgeeparra
              Nice plugin ..I Like it a lot it will be nice to be able to use Tag and profile columns just like you do with Materials
                cadmunkey
                It would be great if you could add the IFC classifier type to the quantities list.
                For example IFC_footings = 300m3.
                • gudio83G Offline
                  gudio83
                  is there a version compatible with sketchup 2015 x64?
                    cadmunkey
                    tak2hata hasn't posted for a while now, I think he's really busy.
                    • TIGT Online
                      What makes you think it is not compatible ?
                      It has no compiled C add-ons so it should work with either bit-ness.
                      • gudio83G Offline
                        gudio83
                        Its show me only the total amount (m3). All components are with 0 value for all dimensions. I try to take off the quantity of components and groups made by housebuilder
                        • TIGT Online
                          PM the author...........
                          • 4 / 4
