    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 65.1k Views 19 Watching
    • bagateloB Offline
      bagatelo
      You could take a look at these things I asked here?
      http://sketchucation.com/forums/viewtopic.php?f=323&t=54080
        tak2hata
        @bagatelo said:
        I found this plugin simply fantastic! Wonderful!
        But...
        If some component have several copies, with several scales from outside,is presented in the report as if everyone had the same size, and this is not desirable to me.
        Also would like to know if is possible to organize the report by displaying objects by layer, and if we can disable to make report to hidden layers.
        Thank you!
        Hi,bagatelo.
        I will fixe the first problem about scaled component.
        but I'm sorry ,Now I am too busy.So wait this weekend.
        I think the component in hidden layer is not included in report.
        In the case of the faces in component are placed in hidden layer,
        that faces are not included,but the number of that component are counted.
        I think finding that case is difficult.
        Please place the components on hidden layers.
        And I will read your ask topic,
        but I do not know I can create the function for the request.
        by TAK2HATA
          tak2hata
          Hi,I updated this to version2.5.0
          Bugfix::Calculate correctly volume of the solid in scaled group.
          by TAK2HATA
          • bagateloB Offline
            bagatelo
            Hello tak2hata , this is an important update. Thanks.
            I think it would be very interesting if we could add in a particular component some items few who would not be modeled in 3D, but we could assign cost values​​. So when should copy such items automatically additional items would be added in the report.
            It would also be interesting if our selves just set things like:
            Set up a special layer, and for each item (component or group) (only those who were at the root of the outliner) additional other items would be included, which would not be modeled in 3d.
            Thanks again for your efforts.
            • H Offline
              hebeijianke
              SOLID MATERIAL CHANGER error
              Error; #<NoMethodError; undefined method `entities' for #<Sketchup;;Edge;0x5f77d44>>
              E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2141;in `selectVolumetrics2'
              E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2130;in `each'
              E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2130;in `selectVolumetrics2'
              E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2094;in `select_bySOLIDMAT'
              E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2009;in `wd_solid_material_changer'
              E;/Google SketchUp 8/Plugins/solid_quantify2/main.rb;2141;in `call'
                tak2hata
                Hi,hebeijianke.
                I fix the problems in using Solid Material Changer.
                Sorry for keep you waiting long time.
                Thanks.
                by TAK2HATA
                  jorgeeparra
                  IMPRESSIVE PLUGIN VERY USEFUL 👍
                    jorgeeparra
                    Nice plugin ..I Like it a lot it will be nice to be able to use Tag and profile columns just like you do with Materials
                      cadmunkey
                      It would be great if you could add the IFC classifier type to the quantities list.
                      For example IFC_footings = 300m3.
                      • gudio83G Offline
                        gudio83
                        is there a version compatible with sketchup 2015 x64?
                          cadmunkey
                          tak2hata hasn't posted for a while now, I think he's really busy.
                            What makes you think it is not compatible ?
                            It has no compiled C add-ons so it should work with either bit-ness.
                            • gudio83G Offline
                              gudio83
                              Its show me only the total amount (m3). All components are with 0 value for all dimensions. I try to take off the quantity of components and groups made by housebuilder
                                PM the author...........
                                • 3 / 4
