    Flipping Crazy
    59 Posts 8 Posters 5.7k Views 8 Watching
      @TECHDAVE, I was referring to keeping components for future use in other models, not just the current one. You seem to be referring to the current model only.
      Bob, what tip is the "great tip"?
        Why don't you make the 'SKP library of bolt components' and sell it to others ?
        • T
          TECHDAVE02
          I understood that but if you are using BoltMaker over and over in the same model that is the result.
          The points that you make are all valid and I agree wholeheartedly with you and tig on all counts but if at this point BoltMaker is used then the workaround must consider this.
          • bsintzelB
            bsintzel
            Techdave02
            Sorry for the fuzzy answer: I was referring to a library of components I keep for all of my models πŸ˜‰
            I've taken obfuscating to a whole new level!
              A little image before / after for explain the problem ?
              This plugin by SDmitch don't resolve your trouble ?
              • bsintzelB
                bsintzel
                Pilou,
                I love this plugin from SDmitch, but it does unconventional things to the axis of the bolts it produces, causing a lot of axis alignment issues for me. I posted my issues in the Newbie Forum, see subject 'Flipping Crazy' for all of the screenshots.
                Bob
                  I always don't understand all that! πŸ˜„
                  As said previous in another thread
                  Seems the axe tools by Thomthom who give an axe to any objet
                  Then the replace component by Sdmitch Source / Target
                  makes that you want!
                  With that you have nothing to do! πŸ˜„
                  No click for give orientation πŸ˜„
                  What do you want more simple ?
                  • bsintzelB
                    bsintzel
                    Pilou,
                    It's ok...I'm going to put this problem to bed. Thanks to all for your input
                    Bob
                      Only with Axes tool by Thomthom + Replace random component by Sdmitch! πŸ˜‰
                      (with only one component as source)
                      At the end just select all the ("component of 2 components" very easy with the Outliner)
                      and explode them if you want refind the 2 original separated components!
                      And if you want a "resize on the Target"
                      use the special Replace random component file linked always by Sdmitch ! πŸ˜‰
                      Very easy, very speedy and nothing to do! πŸ’š
                      PilouComponentReplacement.zip
                      • bsintzelB
                        bsintzel
                        Pilou,
                        Very cool πŸ‘
                        It's also very kind of you to share this. Thank you πŸ˜„
                        Bob
                          Just a little thing that I have forgotten to write! 😳
                          Between each call of the random replace component you must erase inside the Info Box all the Words Source and Target! (use again the Outliner for an easy selection)
                          If not the plug will not work in some cases! πŸ€“
                          • bsintzelB
                            bsintzel
                            Pilou,
                            Since you put a lot of extra effort into this problem, I'm going to as well. First however, I have to be certain nothing is getting misunderstood by either of us.
                            I'll begin by asking you to use the BoltMaker XII plugin and (using the model I provided), try the following steps:
                            1 - open the file I've attached. It contains: a component (a block) with a bolt in it created using BoltMaker XII and a 'Source' component made by me.
                            2 - From the Window/Entity Info dialog box, confirm that the 'Source' bolt I created is a component. Double-click on the 'Source' component, you'll see that it's z-axis is pointing up (standard convention).
                            3 - From the Window/Entity Info dialog box, confirm that the bolt created by BoltMaker XII is a component. Double-click it and examine its axis. You'll find that the z-axis is pointing down. This is not standard practice as a new component should have the z-axis pointing up.
                            4 - Now run SDMitch's ComponentReplacement plugin against the 'Source' and 'Target' components.
                            What you should see is that the 'Source' component replaces the 'Target' component at a location and orientation you wouldn't expect.
                            Try this and let me know what you find. If you have a procedure I can follow that results in a properly oriented target replacement ( using the model I provided) ...I'll be ecstatic 😍 .
                            Warm regards
                            Bob
                            Bob
                            SU8 format
                            SU2013 format
                            • bsintzelB
                              bsintzel
                              Guys,
                              FINALLY...after listening to all of your ideas, I derived a solution based largely on your comments and it worked perfectly. When it happened, it was one of those cathartic moments.
                              The solution was mainly to forget all about trying to 'replace' a BoltMaker XII bolt with mine and instead, figure out how to 'insert' my custom bolt exactly where I wanted it in another component.
                              Steps followed:
                              1 - Selected my custom bolt component (the source).
                              2 - Using ThomThom's Axis tool, set the insertion point of the custom bolt x-y-z axis to 'center'
                              3 - Selected the Box component (the Target).
                              4 - Using ThomThoms Guide Tools plugin, set the Target's bounding box's cPoint at bound center.
                              5 - Click on the 'Source' component then CTRL-click on the 'Target' component.
                              6 - Using ThomThom's Guide Tools plugin, select Insert Component at cPoints.
                              voila, the custom bolt is inserted in the block at the precise location I want. 😍
                              THANK YOU ALL for your input
                              Figure 1: Set the custom bolt x-y-z axis to 'center'
                              Figure 2: Set cPoint of 'target'
                              Figure 3: Insert 'source' component at cPoint of 'Target' component
                                It appears you've got a process you're happy with. That's cool. πŸ‘
                                  So you don't use a replacement mehod πŸ˜„
                                  Yes ...but how do you make when you have a little hundred of bolts in any orientation to change ? πŸ˜„
                                  PS For me its' save as V6 or V7 for read the files πŸ˜‰
                                  • bsintzelB
                                    bsintzel
                                    Hi Dave...
                                    Forgive me if I already asked you, but could you remind me of the 'fewer' steps you use πŸ˜„ .
                                    I've had so much correspondence around this topic with so many people on different forums, I've lost track 😳
                                    Bob
                                    • bsintzelB
                                      bsintzel
                                      Piloe,
                                      Re "So you don't use a replacement method". Sorry to say, but I was going about this all wrong. I was using BoltMaker as a way to automatically create a bolt that would resize itself according to the dimensions of the target. I thought that by simply replacing the BoltMaker bolt with mine that it would be very easy to do. Sadly, I was wrong.
                                      I do thank you for your efforts.
                                      Bob
                                        Bob, there are links on the first page of this thread. No plugins required the way I do it.
                                        I'm curious about your procedure. You are locating the bolt so its center is aligned with the center of the block component. Why do you put a fastener in a single piece? Wouldn't that fastener be used to hold two parts together? And if that's the case, you don't want the center of the bolt located at the center of a single part, do you? What happens when you have a pair of bolts to locate on the part. Both of them can't be at the center in the part.
                                        I would locate the insertion point for the screw in your example centered at the top of the head and place the screws at points on the surface of the part. These would be the points you'd identify in reality instead of points inside the part.
                                        And with gluing, the bolts drop in easily in any orientation desired.
                                        The only plugin used in the creation of the model in the video was to drill and counterbore the holes for the bolts. Everything else was done with native tools. It would be trivial to adjust the lengths of the bolts as needed so I didn't show that.
                                          Maybe you can also look at Component Dropper by ThomThom πŸ˜‰
                                          • bsintzelB
                                            bsintzel
                                            Hi Dave...
                                            This is an excellent video tutorial. Thank you so much πŸ‘ πŸ‘ . I would prefer your solution to mine if I can get it to work on BoltMaker XII output. You see, BoltMaker automaticaaly sizes the bolt to match its target.
                                            Just one question: was the bolt you used created with BoltMaker XII and if so, did you manipulate it's axis in any prior to gluing them?
                                            To answer your question "Why do you put a fastener in a single piece?".
                                            Answer: To illustrate the 'flipping' issue I was experiencing when using BoltMaker XII. I totally agree that a single bolt in just one piece would serve no purpose πŸ€“ .
                                            • 2 / 3
