    Flipping Crazy
    59 Posts 8 Posters 6.1k Views 8 Watching
      @techdave02 said:
      This may help to match up components
      He already found that and had the axes shown in his model.
      • bsintzelB
        bsintzel
        Dave,
        Yes that is 'precisely' what I was trying to do. The bolt shown in the block was created using BoltMaker XII and I found it's axis orientation odd from the beginning. That is why I've had to resort to finding a way to change the source component axis to match it.
        Also, I stand corrected regarding the 'glue' button. Thanks for catching that 😳
        Tig:
        I agree wholeheartedly that the 'blue' axis should be up. However, I was unable to do so with the bolt in the block. That bolt was created with BoltMaker XII. Why it's down, I don't know. All I know is that I can't change it to go up. I therefore tried to change the orientation of (my) source bolt to match that of the BoltMaker XII component.
        You wrote "you can select > context-menu unglue to allow you to manipulate the location". Are you referring to the 'Glue To: None' option in the Component window? I searched all over but couldn't find anything with the word 'Unglue' in it.
        Thanks to all for jumping in
        I've taken obfuscating to a whole new level!
          Is the bolt maker plugin locating the axes incorrectly or did you just rotate the component after creating it? As I said, if you aren't going to set the component to glue, adjust the axes so it'll insert in the most common orientation.
          • BoxB
            Right click on the component and a context menu item is unglue.
            You can always explode the component in the correct location and remake it as a component which will give you the opportunity to set the axis, glue, cut etc
            • bsintzelB
              bsintzel
              Dave,
              Thinking that I might have...I went back and created a new bolt with BoltMaker XII. I was correct in that the z-axis always points down when using this plugin.
              Box:
              I tried your suggestion. I can see the 'unglue' option in the context window, but it's greyed out. I also tried putting the bolt component ( seen in the block) in edit mode, but it made no difference. Using the file I attached, are you able to see it black and not grey?
              • T
                TECHDAVE02
                I have used BoltMaker and it has always produced the fastener with the axes in this configuration and my solution was always to match the specialty fastener to it. Or to go into the component delete it and redraw/copy past new one if I want all the instances to be the same
                  Lousy plugin, then. πŸ˜’
                  If anyone takes up your challenge to rewrite/improve the plugin, maybe they can fix this problem, too.
                  If Unglue is greyed out, there's no gluing established. If a component has three distinct axes as in your example and the screen shot I posted, there is no gluing.
                  • BoxB
                    That isn't what he is talking about.
                    • T
                      TECHDAVE02
                      Bob
                      I am not sure if you are saying that it is hard to see??
                      If so adjust as follows.
                      adjust to suit
                      • bsintzelB
                        bsintzel
                        TECHDAVE: Nope (but thanks anyway πŸ‘ ), see the screenshot and it'll make more sense.
                        Dave: Not sure if I would call it "lousy" , rather 'more in need of some polishing up'.
                        It's really quite a useful tool. It's just too bad it uses an unconventional way to set the axis of the components it makes.
                        I've already chatted with the developer and he will permit 'anyone' to tweak it. He is no longer updating any of his plugins.
                        There's a LOT of smart coders in here, surely someone has the skills to tweak this puppy. I think it deserves it. πŸ€“
                        Thanks again to all for participating
                        • BoxB
                          I'm unable to look at your models as I am languishing in a hospital waiting room at present with just my phone, so perhaps I don't understand correctly.
                          Can you not use the plugin to create the geometry, place it once correctly, then explode and recomponent it with the correct properties, then use the corrected component to insert or replace.
                          • bsintzelB
                            bsintzel
                            Box: what ap are you using on your phone to monitor this forum? I have an Android phone, and I could use such an ap.
                            And yes, I can do all of the things you mentioned, however, I found that the BoltMaker plugin allowed me to create custom-sized bolts in very rapid succession. Granted, I haven't found a way to incorporate my own bolt/nut designs using it, but I'm hoping with time, that some clever developer will take up the gauntlet and give it a go.
                            Warm regards
                            Bob
                            • bsintzelB
                              bsintzel
                              Gaieus,
                              Thanks for the the tutorial links. The last one was particularly enlightening. β˜€
                              Bob
                                Are you keeping bolts the plugin creates for later use? Or are you just making them as you need them?
                                I would be correcting the component axes as I made the bolts whether they are made manually or via the plugin and save them for future use. I wouldn't ever make the same bolt or screw more than once.
                                • BoxB
                                  I believe you can use tapatalk with the forum these days, but I still happily use a browser to access the forum. I currently use Dolphin browser, seems to work for me, but obviously you can't open skp's.
                                  • bsintzelB
                                    bsintzel
                                    Dave,
                                    RE: "I wouldn't ever make the same bolt or screw more than once". I agree, neither would I.
                                    I use different bolts/nut components for different projects, but never recreate them from scratch each time. πŸ˜„
                                    I keep a collection of them for my wood working projects and import them as needed.
                                    Ideally, I would like to be able to buy a plugin that would allow me to pick a bolt/nut assembly from a library (much like Autodesk Inventor) then with once click, place it where I want and with the correct axis orientation. After that, all should need to do is 'nudge' the component up/down the z-axis and/or push/pull the bolt to specs.
                                    So far, I haven't found such a plugin and have had to resort to a manual process 🀒 .
                                    When you work with a multi-hinged project, doing this manually is very time consuming.
                                    Bob
                                    • T
                                      TECHDAVE02
                                      The plug in keeps bolts of the same size Dia./length and they are added to the entity count/COMPONENTS in the model.
                                      If you flip the axes the next time that you use the same bolt........
                                      • bsintzelB
                                        bsintzel
                                        Dave R,
                                        Great tip...I'll do just that and see what happens. It might be just as simple as what you say πŸ‘ .
                                          @TECHDAVE, I was referring to keeping components for future use in other models, not just the current one. You seem to be referring to the current model only.
                                          Bob, what tip is the "great tip"?
                                            Why don't you make the 'SKP library of bolt components' and sell it to others ?
                                            • 2 / 3
