    Flipping Crazy
    59 Posts 8 Posters 6.1k Views 8 Watching
      Lousy plugin, then. πŸ˜’
      If anyone takes up your challenge to rewrite/improve the plugin, maybe they can fix this problem, too.
      If Unglue is greyed out, there's no gluing established. If a component has three distinct axes as in your example and the screen shot I posted, there is no gluing.
      • BoxB
        That isn't what he is talking about.
        • T
          TECHDAVE02
          in edit mode, but it made no difference. Using the file I attached, are you able to see it black and not grey?
          Bob
          I am not sure if you are saying that it is hard to see??
          If so adjust as follows.
          adjust to suit
          • bsintzelB
            bsintzel
            TECHDAVE: Nope (but thanks anyway πŸ‘ ), see the screenshot and it'll make more sense.
            Dave: Not sure if I would call it "lousy" , rather 'more in need of some polishing up'.
            It's really quite a useful tool. It's just too bad it uses an unconventional way to set the axis of the components it makes.
            I've already chatted with the developer and he will permit 'anyone' to tweak it. He is no longer updating any of his plugins.
            There's a LOT of smart coders in here, surely someone has the skills to tweak this puppy. I think it deserves it. πŸ€“
            Thanks again to all for participating
            I've taken obfuscating to a whole new level!
            • BoxB
              I'm unable to look at your models as I am languishing in a hospital waiting room at present with just my phone, so perhaps I don't understand correctly.
              Can you not use the plugin to create the geometry, place it once correctly, then explode and recomponent it with the correct properties, then use the corrected component to insert or replace.
              • bsintzelB
                bsintzel
                Box: what ap are you using on your phone to monitor this forum? I have an Android phone, and I could use such an ap.
                And yes, I can do all of the things you mentioned, however, I found that the BoltMaker plugin allowed me to create custom-sized bolts in very rapid succession. Granted, I haven't found a way to incorporate my own bolt/nut designs using it, but I'm hoping with time, that some clever developer will take up the gauntlet and give it a go.
                Warm regards
                Bob
                • bsintzelB
                  bsintzel
                  Gaieus,
                  Thanks for the the tutorial links. The last one was particularly enlightening. β˜€
                  Bob
                    Are you keeping bolts the plugin creates for later use? Or are you just making them as you need them?
                    I would be correcting the component axes as I made the bolts whether they are made manually or via the plugin and save them for future use. I wouldn't ever make the same bolt or screw more than once.
                    • BoxB
                      I believe you can use tapatalk with the forum these days, but I still happily use a browser to access the forum. I currently use Dolphin browser, seems to work for me, but obviously you can't open skp's.
                      • bsintzelB
                        bsintzel
                        Dave,
                        RE: "I wouldn't ever make the same bolt or screw more than once". I agree, neither would I.
                        I use different bolts/nut components for different projects, but never recreate them from scratch each time. πŸ˜„
                        I keep a collection of them for my wood working projects and import them as needed.
                        Ideally, I would like to be able to buy a plugin that would allow me to pick a bolt/nut assembly from a library (much like Autodesk Inventor) then with once click, place it where I want and with the correct axis orientation. After that, all should need to do is 'nudge' the component up/down the z-axis and/or push/pull the bolt to specs.
                        So far, I haven't found such a plugin and have had to resort to a manual process 🀒 .
                        When you work with a multi-hinged project, doing this manually is very time consuming.
                        Bob
                        • T
                          TECHDAVE02
                          The plug in keeps bolts of the same size Dia./length and they are added to the entity count/COMPONENTS in the model.
                          If you flip the axes the next time that you use the same bolt........
                          • bsintzelB
                            bsintzel
                            Dave R,
                            Great tip...I'll do just that and see what happens. It might be just as simple as what you say πŸ‘ .
                              @TECHDAVE, I was referring to keeping components for future use in other models, not just the current one. You seem to be referring to the current model only.
                              Bob, what tip is the "great tip"?
                                Why don't you make the 'SKP library of bolt components' and sell it to others ?
                                • T
                                  TECHDAVE02
                                  I understood that but if you are using BoltMaker over and over in the same model that is the result.
                                  The points that you make are all valid and I agree wholeheartedly with you and tig on all counts but if at this point BoltMaker is used then the workaround must consider this.
                                  • bsintzelB
                                    bsintzel
                                    Techdave02
                                    Sorry for the fuzzy answer: I was referring to a library of components I keep for all of my models πŸ˜‰
                                      A little image before / after for explain the problem ?
                                      This plugin by SDmitch don't resolve your trouble ?
                                      • bsintzelB
                                        bsintzel
                                        Pilou,
                                        I love this plugin from SDmitch, but it does unconventional things to the axis of the bolts it produces, causing a lot of axis alignment issues for me. I posted my issues in the Newbie Forum, see subject 'Flipping Crazy' for all of the screenshots.
                                        Bob
                                          I always don't understand all that! πŸ˜„
                                          As said previous in another thread
                                          Seems the axe tools by Thomthom who give an axe to any objet
                                          Then the replace component by Sdmitch Source / Target
                                          makes that you want!
                                          With that you have nothing to do! πŸ˜„
                                          No click for give orientation πŸ˜„
                                          What do you want more simple ?
                                          • bsintzelB
                                            bsintzel
                                            Pilou,
                                            It's ok...I'm going to put this problem to bed. Thanks to all for your input
                                            Bob
                                            • 2 / 3
