    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
      It works for me. How large is the cylinder?
      Or are you getting a result something like this?
      In this case the left edge of the rectangle falls on one of the natural softened edges of the cylinder. You can see that edge if you turn on Hidden Geometry under the View menu. You'll have to unsoften that edge to separate the rectangle from the rest of the surface. You can do that with the native Line tool or the Line tool in ToS and just connect the ends of the adjacent edges of the rectangle. Or you can display Hidden Geometry, select that edge and unsoften it.
      • jgbJ Offline
        jgb
        Faster; easier ..... Shift+Ctrl Erase (tool) Just click on the soft "missing" line segment.
        jgb
          dakenyon27
          I can't seem to get this fantastic plugin working on sketchup 2013. Can anyone help?
          David.
            Sure. But we need some useful information. What do you mean you can't get it working? What happens when you start SketchUp? Do you get an error message related to the plugin?
            Did you install the required LibFredo6 files as spelled out in the first post in the thread? How did you install the files? Do you have Administrative privileges for the Plugins folder?
              Can you please describe the problem?
              Installation problems? Operation problems? Errors?
                martosurf
                FRedo thanks a lot for all good plugins
                You a great thanks a lot
                  alek_mc
                  hi... I have a problem with this plugin... I installed the sketchup pro 2013 and when I started the program, one message said that the plugin can't been uploaded... what can I do?
                    Reread this plugin's main-page instructions.
                    Is it installed exactly like that page says ?
                    Have you also installed the very latest version of 'LibFredo...' from the link that is given [or the SCF PluginStore listing] ?
                    • I Offline
                      ibrahim zambak
                      tools on surface v1.8a plugin, sketchup 8 does not work. windows 8 operating system
                        Ibrahim,
                        More info is needed here. I have SU 8 on Windows 8 and the tool works fine on my computer so a "general doesn't work" is not enough.
                          sasrabirawa
                          works fine on SKP 8 but doesn't work on SKP 2013. The libfred doesn't compatible w/ SKP 2013. even if I use the latest one... can anybody tell me how to fix ??
                          Just an ordinary Sketchup user
                            The latest LibFredo... and several related tools were remade to be compatible with all previous versions and v2013.
                            We must assume you are using the latest versions available from the SCF PluginStore...
                            So you must be doing something wrong ?
                            Are you properly installing things ?
                            Since you haven't told us your OS I must guess at PC.
                            If it's a new v2013 installation into the usual 'Program Files' folder, then Windows will have given the new SketchUp folder [and all of its subfolders] Read-only permissions. Then you can't Write new files into the Plugins folder; but to confuse you Windows might make it look like you have, but it has a actually put the files into a VirtualStore to protect you from yourself, so they don't auto-load as SketchUp starts! A link/button in the top-bars of the Plugins folder's Windows Explorer window is an indication of such limitations...
                            If you use an RBZ archive and then 'install' button under Preferences > Extensions, or use the SCF Plugin Store dialog's AutoInstall feature from within SketchUp then it might still install properly, despite your own limited permissions; but that depends on several other things though...
                            It is always best to have your Plugins folder set to have FULL read/write permissions for every entry in the 'users' uder the Security list: to do this...
                            right-click > context-menu > Properties > Security > Edit ... tick FULL for each and Apply & OK...
                            [you will need admin rights to do this].
                            Note that even if you are setup in the Users Control Panel to have full 'admin' rights, that will not change the initial permissions the OS sets to the SketchUp folder and its contents, even admins are limited.
                            Note that it is also advisable to always install apps as as admin... AND for SketchUp.exe I'd also set its Properties > Compatibility, with the 'Run this program as an administrator' box ticked...
                            • E Offline
                              elisaha
                              Hi everyone,
                              I'm a SU-newbie with SU 8 on a Mac with OS X 10.7.5, however I have troubles installing ToolsOnSurface 1.8a. I do have the ZLoarder, LibFredo and the Tutorial Offset on Surface in the correct plugin folder. It even shows up in my extensions, but there is no line-up. What can I do?
                              I do have a general problem with installing plug-ins.. I don't know what I would be doing wrong, please help!
                              Thanks alot,
                              Elisa
                              • mitcorbM Offline
                                mitcorb
                                Hi:
                                On the very first page of this thread under Installation, for Mac is this:
                                [On Mac the SU plugin directory should be:
                                Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins]
                                In your case, it will be Sketchup 8 but the rest of the path should be correct.
                                Alternatively, go to the top of this page, mouse over Resources, and select Plugin Store Download. This automates the process. Watch the video, read the information.
                                  giltora
                                  tools on surface not responding.. help please!!!!
                                    More info is needed.
                                    HOW isn't it 'responding' ?
                                    Do you get the extension/toolbar ?
                                    Are there error messages?
                                    [Try it with the Ruby Console window open...]
                                    Did you get the latest versions of this tool AND the required LibFredo...
                                    Both are available in the SCF PluginStore...
                                      popfunky
                                      Thank but i can't install 😢
                                        Please explain your problem better, so we can help you properly.
                                        How are you trying to install this ?
                                        Do you have the required support 'Lib' installed as explained in the download details ?
                                          archdeacon
                                          Fredo thank you for these great tools. i am having a hard time installing this one though. I am on sketchup 8 pro - Windows 7. any ideas...? i have observed the footprint and everything. I do not appear to have the LibFredo6.rb that you are mentioning (i have the newer library). Is this because you have updated the lbrary to the new version? can you instruct me on how to cure this problem.
                                          thanks for your help.
                                          • fredo6F Offline
                                            Since you have Sketchup 8, you should
                                            • first, install the Sketchucation Plugin Store tool
                                            • Then Auto-install my scripts with this tool. You'll have zero problem and it's much easier and faster than with the ZIP file. You will also get the latest versions available
                                            You may need to do a clean up of your SU Plugins directory before if you had a wrong installation
                                            • 31
                                            • 32
                                            • 2 / 32
