    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • thkian92T Offline
      thkian92
      Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
        No existing randomize size of elements, Components? 😲
          tak2hata
          @mwm5053 said:
          Here we go still no slider.
          Ummm...
          It is difficult.
          I consider well.
          Please wait.
          Hi,Pilou.
          In Fur webdialog,
          TopJitter(%) will randomize the size of placing component.
          Or Use Crowd Dialog.
          Hi,thkian92.
          I tested on Sketchup13.It works well.
          I have some questions.
          Was the error mesasge show on starting sketchup?
          Does fur Toolbar exits on your sketchup.
          Did you install fur correctly?
          Sketchup V8,too?
          Thanks.
          by TAK2HATA
            Tested on V7 πŸ˜‰
            Very cool! 😎
            Does exist something for avoid "collisions" of volumes?
            And seems Preview positions of the crowd don't gives the good result?
            Number is good but not the position! 😲
            Does it possible in the Crowd Menu to have something who gives random size
            but not a rotation ?
            What the "Stand Up" (Yes / No) is supposed to do ?
              tak2hata
              Hi,Pilou.
              This tool is fur tool.
              To interference solids will make too many raytest checks.
              So it will be too slow to use.
              The purpos of preview is chechking the styles.
              The show full preview will too slowly to use fine.
              I limit the number of fur in previwe to make it fast.
              So preview position is not same to generating.
              Sorry for my poor technology.
              Hi,Walt.
              This is last test.
              Please open Ruby console in sketchup.
              (menu bar -> windows -> ruby console)
              And copy and paste this line.
              wdlg=UI;;WebDialog.new( "Fur TEST", true, "T2H_FUR_DIALOG", 300, 680, 150, 150, true);wdlg.set_url("http://jqueryui.com/slider/");wdlg.show_modal
              like this picture.
              2013.06.30screenshot1
              And press enter key to run the script.
              Webdialog will be shown.
              The right state of display is here.
              2013.06.30screenshot2
              I am not able to solve this problem when there is no slider.
              If the slider is shown,I think the prbolem caused to "CSS" folder.
              Thanks.
              by TAK2HATA
                Thanks for the infos! β˜€
                No problem! It's yet a truelly very cool plugin! πŸ‘
                  mwm5053
                  Thanks or all the help tak2hata this what I get with a slider.
                  2011 iMac
                  SU 2015 Pro, 2017 Make
                  V2 Twilight
                  macOS Sierra 10.12.5
                  • thkian92T Offline
                    thkian92
                    Nope, no error message was shown when starting sketchup 2013. The Toolbar doesn't show and I can't find the plugin anywhere. But the older version of your plugin works perfectly in sketchup 2013.
                    How did you install version 2.0.6 in order to get it to work?
                      DavorP
                      Hi Takuji,
                      Love the new Fur. Works great for populating grass. Here are a few images populated with Fur using Podium Browser grass instances and rendered with Podium.
                      There is one thing I noticed though. Fur paints component instances with currently selected SU material when using Make by Component.
                        kashkasha
                        @mdm said:
                        man this plugin is awesome 😍 πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰
                        for landscaper couldn't be anything better, our dreams came through now we can grow grass in the computer, can't wait for the first mower 🀣 will be available
                        great stuff I love it, and it's so much fun πŸ˜„
                        where can i download it also? its seems everyone is "make-furing" except me... πŸ˜•
                          Go to the start of the tools thread OR... please learn to use the SCF PluginStore... which can be accessed from the Resources menu above... πŸ˜’
                            tak2hata
                            Hi,Walt.
                            I create the test_dialog.html
                            test_dialog.html.zip
                            please copy this file to fur_en folder.
                            test_dialog copy to there
                            And open the html file on browser.
                            I will modify fur_en to create html file if the html file show sliders
                            Hi,Davor.
                            Nicely rendered image! 😍
                            Architecture need the beautiful grass like this.
                            Hi,kashkasha.
                            Please get install files on the top of this thread.
                            And Enjoy fur_en!
                            Hi,TIG.
                            Thank you very much for your advice.
                            Thanks All.
                            by TAK2HATA
                              leaosenzala
                              @thkian92 said:
                              what i did was change the extension rbz to zip then extract to plugin folder
                                Are they really in the folder?
                                Do you have full security access rights to your Plugins folder?
                                Were all files left in the same relationship [subfolders etc] as in the RBZ [ZIP]?
                                Because you didn't bother to complete your User-Info we don't know your OS [although we can guess 64bit PC] or your SUp Version.
                                If you have SUp v8 or v2013 you could far more easily install RBZ files etc in several ways... avoiding any of the complications you outlined...
                                This kind of issue has been discussed many times, in many threads...
                                  ChEBaNaNa
                                  This Plugin is probably the best Plugin i've ever seen....
                                  Big Thanks from Switzerland!!!!! πŸ˜ƒ
                                  • plot-parisP Offline
                                    plot-paris
                                    Hey tak2hata,
                                    excellent plugin! It is fun to use and a great enhancement for SketchUp.
                                    However, sometimes I find it a bit difficult to master. Therefore I have two ideas:
                                    1. Some of the settings use units that are not very intuitive. The stiffness for example is measured in a undefined number. Or while the jitter options use percent, the direction and force options use meters (which can be difficult, so that one has to test a lot before achieving the right result).
                                      I think it might be better to have those as a percentage as well (0% no effect, 100% full effect). Like that one can see a linear increase of the effect, which makes it easier to understand.
                                    2. Some of the settings are not self-explanatory. Do you think it would be possible to add tooltips that show up, when you hover over the setting with your cursor for some time? You know, with a short description of what the setting does...
                                    Would be great to hear your opinion on this...
                                      bb6
                                      谒谒!hebeijianke
                                        Sharkyzero
                                        I don't seem to be getting the results everybody else is. I make a grass square and make it a component, then I try to use the crowd maker and it puts the grass everywhere else other than what I have selected. Anybody else have this problem? Also, how do you get so much grass? My comp is no slouch and it virtually crashes whenever I try to get more than a little bit in view.
                                          tak2hata
                                          Hi,Sharkyzero.
                                          I need to know your detail to help the problems.
                                          Please upload screenshot of your model and crownd maker dialog.
                                          crowdmaker
                                          Thanks.
                                          by TAK2HATA
                                            Sharkyzero
                                            I just realized something, Tak. I think the fact that I'm not using instances of the grass components is screwing with everything. Let me fiddle around with it some more and I'll see if I can't get it working the way I think it should.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 32
                                            • 33
                                            • 27 / 33
