    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
      mwm5053
      Great plugin 👍 I updated to 2.0.6 but not getting sliders or realtime preview like video shows I get the older dialog style. I'm using latest SU8 Pro on Mac 10.7.5
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        tak2hata
        Hi,Walt.
        I will test it on Mac.
        Please wait.
        Thanks.
        by TAK2HATA
          mwm5053
          2011 iMac
          V2 Twilight
            tak2hata
            Hi,Walt.
            I tested on mac.
            Screen shots here.
            files in plugin folder
            work fine on mac.
            I think the problem is folder.
            The webdialog lost the sight of "JS" folder or "CSS" folder.
            But I think no problem about the non-alphabetical character file names on mac.
            So please tell me your plugin folder.
            Thanks.
            by TAK2HATA
              mwm5053
              Path can be seen at bottom of screen shot.
              2011 iMac
              V2 Twilight
                tak2hata
                I think there is no problem.....
                The problem becomes the mystery.
                I will create test code for you.
                Please wait.
                by TAK2HATA
                • Z Offline
                  Zacchia
                  Hi tak2hata
                  Many thanks for your wonderful plugin! See attached an idea, hope you can understand 😒 It is just an idea.
                    tak2hata
                    Hi,Walt.
                    I create the test ruby for you.
                    test ruby
                    It shows the folders for fur and Test Slider on Webdialog.
                    Select from menu bar.
                    Plugins -> Fur Test For Walt
                    It will show like this.
                    Show like this
                    Hi,Zacchia.
                    I understand your idea.
                    But It will add new many properties.
                    They take long time.
                    Wait for Fur v3.0.
                    Now I must sleep soon for tomorrow.
                    Thanks.
                    by TAK2HATA
                      mwm5053
                      Here we go still no slider.
                      2011 iMac
                      V2 Twilight
                      • thkian92T Offline
                        thkian92
                        Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
                          No existing randomize size of elements, Components? 😲
                            tak2hata
                            Ummm...
                            It is difficult.
                            I consider well.
                            Please wait.
                            Hi,Pilou.
                            In Fur webdialog,
                            TopJitter(%) will randomize the size of placing component.
                            Or Use Crowd Dialog.
                            Hi,thkian92.
                            I tested on Sketchup13.It works well.
                            I have some questions.
                            Was the error mesasge show on starting sketchup?
                            Does fur Toolbar exits on your sketchup.
                            Did you install fur correctly?
                            Sketchup V8,too?
                            Thanks.
                            by TAK2HATA
                              Tested on V7 😉
                              Very cool! 😎
                              Does exist something for avoid "collisions" of volumes?
                              And seems Preview positions of the crowd don't gives the good result?
                              Number is good but not the position! 😲
                              Does it possible in the Crowd Menu to have something who gives random size
                              but not a rotation ?
                              What the "Stand Up" (Yes / No) is supposed to do ?
                                tak2hata
                                Hi,Pilou.
                                This tool is fur tool.
                                To interference solids will make too many raytest checks.
                                So it will be too slow to use.
                                The purpos of preview is chechking the styles.
                                The show full preview will too slowly to use fine.
                                I limit the number of fur in previwe to make it fast.
                                So preview position is not same to generating.
                                Sorry for my poor technology.
                                Hi,Walt.
                                This is last test.
                                Please open Ruby console in sketchup.
                                (menu bar -> windows -> ruby console)
                                And copy and paste this line.
                                wdlg=UI;;WebDialog.new( "Fur TEST", true, "T2H_FUR_DIALOG", 300, 680, 150, 150, true);wdlg.set_url("http://jqueryui.com/slider/");wdlg.show_modal
                                like this picture.
                                2013.06.30screenshot1
                                And press enter key to run the script.
                                Webdialog will be shown.
                                The right state of display is here.
                                2013.06.30screenshot2
                                I am not able to solve this problem when there is no slider.
                                If the slider is shown,I think the prbolem caused to "CSS" folder.
                                Thanks.
                                by TAK2HATA
                                  Thanks for the infos! ☀
                                  No problem! It's yet a truelly very cool plugin! 👍
                                    mwm5053
                                    Thanks or all the help tak2hata this what I get with a slider.
                                    2011 iMac
                                    V2 Twilight
                                    • thkian92T Offline
                                      thkian92
                                      Nope, no error message was shown when starting sketchup 2013. The Toolbar doesn't show and I can't find the plugin anywhere. But the older version of your plugin works perfectly in sketchup 2013.
                                      How did you install version 2.0.6 in order to get it to work?
                                        DavorP
                                        Hi Takuji,
                                        Love the new Fur. Works great for populating grass. Here are a few images populated with Fur using Podium Browser grass instances and rendered with Podium.
                                        There is one thing I noticed though. Fur paints component instances with currently selected SU material when using Make by Component.
                                          kashkasha
                                          @mdm said:
                                          man this plugin is awesome 😍 🎉 🎉 🎉 🎉 🎉 🎉
                                          for landscaper couldn't be anything better, our dreams came through now we can grow grass in the computer, can't wait for the first mower 🤣 will be available
                                          great stuff I love it, and it's so much fun 😄
                                          where can i download it also? its seems everyone is "make-furing" except me... 😕
                                            Go to the start of the tools thread OR... please learn to use the SCF PluginStore... which can be accessed from the Resources menu above... 😒
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 32
                                            • 33
                                            • 26 / 33
