    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      Thanks for the infos! β˜€
      Sorry for my poor technology.
      No problem! It's yet a truelly very cool plugin! πŸ‘
        mwm5053
        Thanks or all the help tak2hata this what I get with a slider.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • thkian92T Offline
          thkian92
          Nope, no error message was shown when starting sketchup 2013. The Toolbar doesn't show and I can't find the plugin anywhere. But the older version of your plugin works perfectly in sketchup 2013.
          How did you install version 2.0.6 in order to get it to work?
            DavorP
            Hi Takuji,
            Love the new Fur. Works great for populating grass. Here are a few images populated with Fur using Podium Browser grass instances and rendered with Podium.
            There is one thing I noticed though. Fur paints component instances with currently selected SU material when using Make by Component.
              kashkasha
              @mdm said:
              man this plugin is awesome 😍 πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰
              for landscaper couldn't be anything better, our dreams came through now we can grow grass in the computer, can't wait for the first mower 🀣 will be available
              great stuff I love it, and it's so much fun πŸ˜„
              where can i download it also? its seems everyone is "make-furing" except me... πŸ˜•
                Go to the start of the tools thread OR... please learn to use the SCF PluginStore... which can be accessed from the Resources menu above... πŸ˜’
                  tak2hata
                  Hi,Walt.
                  I create the test_dialog.html
                  test_dialog.html.zip
                  please copy this file to fur_en folder.
                  test_dialog copy to there
                  And open the html file on browser.
                  I will modify fur_en to create html file if the html file show sliders
                  Hi,Davor.
                  Nicely rendered image! 😍
                  Architecture need the beautiful grass like this.
                  Hi,kashkasha.
                  Please get install files on the top of this thread.
                  And Enjoy fur_en!
                  Hi,TIG.
                  Thank you very much for your advice.
                  Thanks All.
                  by TAK2HATA
                    leaosenzala
                    @thkian92 said:
                    Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
                    what i did was change the extension rbz to zip then extract to plugin folder
                      Are they really in the folder?
                      Do you have full security access rights to your Plugins folder?
                      Were all files left in the same relationship [subfolders etc] as in the RBZ [ZIP]?
                      Because you didn't bother to complete your User-Info we don't know your OS [although we can guess 64bit PC] or your SUp Version.
                      If you have SUp v8 or v2013 you could far more easily install RBZ files etc in several ways... avoiding any of the complications you outlined...
                      This kind of issue has been discussed many times, in many threads...
                        ChEBaNaNa
                        This Plugin is probably the best Plugin i've ever seen....
                        Big Thanks from Switzerland!!!!! πŸ˜ƒ
                        • plot-parisP Offline
                          plot-paris
                          Hey tak2hata,
                          excellent plugin! It is fun to use and a great enhancement for SketchUp.
                          However, sometimes I find it a bit difficult to master. Therefore I have two ideas:
                          1. Some of the settings use units that are not very intuitive. The stiffness for example is measured in a undefined number. Or while the jitter options use percent, the direction and force options use meters (which can be difficult, so that one has to test a lot before achieving the right result).
                            I think it might be better to have those as a percentage as well (0% no effect, 100% full effect). Like that one can see a linear increase of the effect, which makes it easier to understand.
                          2. Some of the settings are not self-explanatory. Do you think it would be possible to add tooltips that show up, when you hover over the setting with your cursor for some time? You know, with a short description of what the setting does...
                          Would be great to hear your opinion on this...
                            bb6
                            谒谒!hebeijianke
                              Sharkyzero
                              I don't seem to be getting the results everybody else is. I make a grass square and make it a component, then I try to use the crowd maker and it puts the grass everywhere else other than what I have selected. Anybody else have this problem? Also, how do you get so much grass? My comp is no slouch and it virtually crashes whenever I try to get more than a little bit in view.
                                tak2hata
                                Hi,Sharkyzero.
                                I need to know your detail to help the problems.
                                Please upload screenshot of your model and crownd maker dialog.
                                crowdmaker
                                Thanks.
                                by TAK2HATA
                                  Sharkyzero
                                  I just realized something, Tak. I think the fact that I'm not using instances of the grass components is screwing with everything. Let me fiddle around with it some more and I'll see if I can't get it working the way I think it should.
                                    tak2hata
                                    Hi,Sharkyzero.
                                    Good luck for fiddle around with it.
                                    Please ask me when you didn't get it working fine.
                                    Thanks.
                                    by TAK2HATA
                                      chillotti
                                      Hi everybody, I have a problem, I can’t install the plugin Fur Maker, I put the file http://sketchucation.com/resources/pluginstore?pln=fur_en
                                      And also the new icons
                                      http://sketchucation.com/forums/viewtopic.php?f=323&t=28092&start=480
                                      in the
                                      Can you help me? Please
                                      Carlo
                                        tak2hata
                                        in the
                                        Carlo
                                        Hi,chillotti.
                                        I guess you didn't use autoinstall from sketchupucation store tool.
                                        You must unzip the rbz file when you manually install it.
                                        Change the extenstion name "rbz" to "zip".and unzip it.
                                        "fur_en.rb" and "fur_en" folder will be shown.
                                        Copy both to plugin folder.
                                        And New Icon file "fur_en.rar" must unzip ,also.
                                        Copy the created png file to "fur_en" folder in plugins folder.
                                        Thanks.
                                        by TAK2HATA
                                          SuperJesus
                                          This was working previously for me but there are certain components that dont seem to want to constrain the surface I select. The preview shows everything in the right place but then they appear randomly spread out in mid air over a huge area when I do it. Its only certain components with the same settings so I don't get it. Has anybody had this issue before?
                                            tak2hata
                                            Hi,SuperJesus.
                                            I guess your problem of fur.
                                            watch video
                                            Please Check the axis origin of the component.
                                            Thanks.
                                            by TAK2HATA
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 32
                                            • 33
                                            • 27 / 33
