    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      mwm5053
      Path can be seen at bottom of screen shot.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        tak2hata
        I think there is no problem.....
        The problem becomes the mystery.
        I will create test code for you.
        Please wait.
        by TAK2HATA
        • Z Offline
          Zacchia
          Hi tak2hata
          Many thanks for your wonderful plugin! See attached an idea, hope you can understand πŸ˜’ It is just an idea.
            tak2hata
            Hi,Walt.
            I create the test ruby for you.
            test ruby
            It shows the folders for fur and Test Slider on Webdialog.
            Select from menu bar.
            Plugins -> Fur Test For Walt
            It will show like this.
            Show like this
            Hi,Zacchia.
            I understand your idea.
            But It will add new many properties.
            They take long time.
            Wait for Fur v3.0.
            Now I must sleep soon for tomorrow.
            Thanks.
            by TAK2HATA
              mwm5053
              Here we go still no slider.
              2011 iMac
              V2 Twilight
              • thkian92T Offline
                thkian92
                Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
                  No existing randomize size of elements, Components? 😲
                    tak2hata
                    Ummm...
                    It is difficult.
                    I consider well.
                    Please wait.
                    Hi,Pilou.
                    In Fur webdialog,
                    TopJitter(%) will randomize the size of placing component.
                    Or Use Crowd Dialog.
                    Hi,thkian92.
                    I tested on Sketchup13.It works well.
                    I have some questions.
                    Was the error mesasge show on starting sketchup?
                    Does fur Toolbar exits on your sketchup.
                    Did you install fur correctly?
                    Sketchup V8,too?
                    Thanks.
                    by TAK2HATA
                      Tested on V7 πŸ˜‰
                      Very cool! 😎
                      Does exist something for avoid "collisions" of volumes?
                      And seems Preview positions of the crowd don't gives the good result?
                      Number is good but not the position! 😲
                      Does it possible in the Crowd Menu to have something who gives random size
                      but not a rotation ?
                      What the "Stand Up" (Yes / No) is supposed to do ?
                        tak2hata
                        Hi,Pilou.
                        This tool is fur tool.
                        To interference solids will make too many raytest checks.
                        So it will be too slow to use.
                        The purpos of preview is chechking the styles.
                        The show full preview will too slowly to use fine.
                        I limit the number of fur in previwe to make it fast.
                        So preview position is not same to generating.
                        Sorry for my poor technology.
                        Hi,Walt.
                        This is last test.
                        Please open Ruby console in sketchup.
                        (menu bar -> windows -> ruby console)
                        And copy and paste this line.
                        wdlg=UI;;WebDialog.new( "Fur TEST", true, "T2H_FUR_DIALOG", 300, 680, 150, 150, true);wdlg.set_url("http://jqueryui.com/slider/");wdlg.show_modal
                        like this picture.
                        2013.06.30screenshot1
                        And press enter key to run the script.
                        Webdialog will be shown.
                        The right state of display is here.
                        2013.06.30screenshot2
                        I am not able to solve this problem when there is no slider.
                        If the slider is shown,I think the prbolem caused to "CSS" folder.
                        Thanks.
                        by TAK2HATA
                          Thanks for the infos! β˜€
                          No problem! It's yet a truelly very cool plugin! πŸ‘
                            mwm5053
                            Thanks or all the help tak2hata this what I get with a slider.
                            2011 iMac
                            V2 Twilight
                            • thkian92T Offline
                              thkian92
                              Nope, no error message was shown when starting sketchup 2013. The Toolbar doesn't show and I can't find the plugin anywhere. But the older version of your plugin works perfectly in sketchup 2013.
                              How did you install version 2.0.6 in order to get it to work?
                                DavorP
                                Hi Takuji,
                                Love the new Fur. Works great for populating grass. Here are a few images populated with Fur using Podium Browser grass instances and rendered with Podium.
                                There is one thing I noticed though. Fur paints component instances with currently selected SU material when using Make by Component.
                                  kashkasha
                                  @mdm said:
                                  man this plugin is awesome 😍 πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰
                                  for landscaper couldn't be anything better, our dreams came through now we can grow grass in the computer, can't wait for the first mower 🀣 will be available
                                  great stuff I love it, and it's so much fun πŸ˜„
                                  where can i download it also? its seems everyone is "make-furing" except me... πŸ˜•
                                    Go to the start of the tools thread OR... please learn to use the SCF PluginStore... which can be accessed from the Resources menu above... πŸ˜’
                                      tak2hata
                                      Hi,Walt.
                                      I create the test_dialog.html
                                      test_dialog.html.zip
                                      please copy this file to fur_en folder.
                                      test_dialog copy to there
                                      And open the html file on browser.
                                      I will modify fur_en to create html file if the html file show sliders
                                      Hi,Davor.
                                      Nicely rendered image! 😍
                                      Architecture need the beautiful grass like this.
                                      Hi,kashkasha.
                                      Please get install files on the top of this thread.
                                      And Enjoy fur_en!
                                      Hi,TIG.
                                      Thank you very much for your advice.
                                      Thanks All.
                                      by TAK2HATA
                                        leaosenzala
                                        @thkian92 said:
                                        what i did was change the extension rbz to zip then extract to plugin folder
                                          Are they really in the folder?
                                          Do you have full security access rights to your Plugins folder?
                                          Were all files left in the same relationship [subfolders etc] as in the RBZ [ZIP]?
                                          Because you didn't bother to complete your User-Info we don't know your OS [although we can guess 64bit PC] or your SUp Version.
                                          If you have SUp v8 or v2013 you could far more easily install RBZ files etc in several ways... avoiding any of the complications you outlined...
                                          This kind of issue has been discussed many times, in many threads...
                                            ChEBaNaNa
                                            This Plugin is probably the best Plugin i've ever seen....
                                            Big Thanks from Switzerland!!!!! πŸ˜ƒ
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 32
                                            • 33
                                            • 18 / 33
