    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 386.9k Views 57 Watching
    • V
      victor hugo
      RV1974 I'm not a user of this plugin but I saw the demo on the attached link, it looks it will help whit what you're wanting to do.
      (artisan4sketchup.com)
      other one can be Vertex tools at http://www.thomthom.net/software/vertex_tools/
      • jeff hammondJ
        However, Curvizard include an autoexit feature (See Default parameters). You preselect the segments by the SU Selection tool and then call Curvizard (icon or context menu) that will just make them curves and exit. I can easily do the brief highlight (actually I implemented the feature and disabled it). Instead, you have the highlight in pale green of any SU curve you mouse over.
        oh.. yeah.. that's good for preselecting then welding πŸ‘
        pretty much what i was imagining to myself earlier in the thread.. ha! 😳
        Jeff,
        I understand the requirement, but the capability of Curvizard to know exactly which segments will form a curve is limited (the Follow mode is based on angle continuity).
        right.. that's how recurve is set up too.. the angle is 1 radian.. the main reason i use recurve is because you only have to select one segment then it follows/selects anything under a radian.. (well, also because i don't have to answer any questions at the end as in weld.rb)
        i was thinking in the speed idea, the follow mode is using whatever number is listed in the palette.. (defualt 40 but if i change it to 60 at some point, then it will use that next time i use the speed mode)
        [sorry for this 'speed mode' talk.. sounds kinda corny.. i don't know what else to call it though]
        further, the mode could combine preselect & no selection.. (everything is already written/functioning.. i'm just suggesting (in my non-ruby-knowing-head) moving some of the wires around for a different style of user interaction)... usage-
        β€’ select a segment
        β€’ press keyshortcut
        β€’ curvizard's follow mode kick in then selects accordingly and welds
        β€’ auto exit
        -AND-
        β€’ have nothing selected
        β€’ press the same keyshortcut
        β€’ curvizard's cursor comes up
        β€’ select a segment, follow mode, weld
        β€’ auto exit
        i honestly think that would be the best welding tool yet.. by far
        not sure how others would feel about it but i can't grasp someone not liking it much better than weld.rb
        anyway, thanks for listening πŸ˜„
        • fredo6F
          NEW RELEASE: Curvizard v1.2a - 18 May 13
          Curvizard 1.2 is an technical update dedicated to the management of big number of edges and contours. It also fixes bugs related to operating on duplicated groups[/list]
          Duplicated groups are groups which are just been copied from an existing group (via the Move+ tool or Copy / paste). Until they are edited, Sketchup treats them as pseudo components. This creates a lot of issues for Ruby scripts and is the source of potential crashes or errors of type "Reference to deleted entity".
          Here is a short video showing the visual effect on a Make Curve process on 13,000 edges.
          Curvizard 1.1 requires an upgrade to LibFredo6 4.9 or higher.
          • CadFatherC
            CadFather
            Thanks Fredo ...some alternative icons just in case.
            CV.zip
            • OxerO
              Oxer
              I have installed the last versions of Curvizard and LibFredo and an error appears now.
              I work on Mac.
              • fredo6F
                Oxer,
                This is very strange that the value for angle max is written 40,0 (with a comma).
                I can't reproduce how this has been made possible, because even if comma may be the decimal separator in Spanish (like in French), the Ruby code only uses the notation with '.' as the separator.
                Just to be sure, could you type the following in the Ruby console:
                { :a => 40.0 }.inspect
                To fix it, you may start any Curvizard tool and click on the AngleMax value of the edge picker section and type another value. Tell me if this work.
                • OxerO
                  Oxer
                  Hi Fredo,
                  I typed in Ruby Console and I obtain this:
                  %(#FF0000)[> { :a => 40.0 }.inspect
                  {:a=>40.0}]
                  I select a curve then I press an icon tool of Curvizard but I can't see the Tool Options Menu.
                  EDIT:
                  I deleted the sketchup preferences and for the moment it works fine again (it's possible that the preferences file was corrupt).
                  • N
                    nesh70
                    I just wanna say thanks for all your amazing SU tools!!!
                    πŸ‘ πŸ‘ πŸ‘
                    • utilerU
                      utiler
                      Hi Fredo, when converting an arc / circle to construction lines a point is added to its segment end. Is there a way of not doing so?
                      And once again, thank you for what you do for SU!!
                      Just Curious...
                      • utilerU
                        utiler
                        Anyone? Here's a screenshot of what I'm referring too...
                        Just Curious...
                          Select all
                          Right Click /Select Only Guide Points / Delete ?
                            πŸ˜‰
                            • massimoM
                              massimo Moderator
                              Like this? πŸ˜„
                                Efectively more speedy than my basic method! πŸ’š
                                • utilerU
                                  utiler
                                  I knew it had to be something simple.... Thanks guys! πŸ‘ πŸ‘
                                  Just Curious...
                                    dedmin
                                    Date; 25-Aug-13 05;57;22
                                    An error occured in Curvizard#edge_prop
                                    The operation is aborted
                                    undefined method `length' for nil;NilClass
                                    CurvizardAlgo.rb; 451 -- execute_geometry
                                    CurvizardTool.rb; 1596 -- geometry_generate
                                    CurvizardTool.rb; 1496 -- top_execute
                                    CurvizardTool.rb; 290 -- handle_initial_selection
                                    CurvizardTool.rb; 267 -- activate
                                    CurvizardTool.rb; 46 -- select_tool
                                    CurvizardTool.rb; 46 -- launch_tool
                                    CurvizardTool.rb; 41 -- action__mapping
                                    Lib6Plugin.rb; 134 -- call
                                    Lib6Plugin.rb; 134 -- launch_action
                                    bootstrap_Curvizard.rb; 51 -- launch_action
                                    bootstrap_Curvizard.rb; 81 -- declare_command
                                    Lib6Plugin.rb; 1044 -- call
                                    Lib6Plugin.rb; 1044 -- command_invoke
                                    Lib6Plugin.rb; 1026 -- build_config_commands
                                    Lib6Traductor.rb; 1074 -- call
                                    Lib6Traductor.rb; 1074 -- add_command
                                      dedmin
                                      (screencast.com)
                                      • K
                                        kein2006
                                        very nice plugin. It's really useful, thank you so much
                                        • fredo6F
                                          NEW RELEASE: Curvizard v1.4a - 15 Sep 13
                                          Curvizard 1.4a is a release with the following updates
                                          • New naming conventions
                                          • Fixes a major bug in the Edge Prop tool (which was not working)
                                          • Include an alternate icon toolbar by CadFather
                                          Curvizard 1.4 requires an upgrade to LibFredo6 5.2 or higher.
                                          • fredo6F
                                            @dedmin said:
                                            (screencast.com)
                                            I am not sure I see the problem.
                                            But in any case, Simplify is not the opposite of Smooth.
                                            Furthermore, Smooth can be used to simplify a curve by incresing the angle, whereas Simplify just remove vertices based on a minimum angle
                                            • 5 / 10
