    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 369.8k Views 57 Watching
    • OxerO Offline
      Oxer
      Hi Fredo,
      I typed in Ruby Console and I obtain this:
      %(#FF0000)[> { :a => 40.0 }.inspect
      {:a=>40.0}]
      I select a curve then I press an icon tool of Curvizard but I can't see the Tool Options Menu.
      EDIT:
      I deleted the sketchup preferences and for the moment it works fine again (it's possible that the preferences file was corrupt).
      • N Offline
        nesh70
        I just wanna say thanks for all your amazing SU tools!!!
        πŸ‘ πŸ‘ πŸ‘
        • utilerU Offline
          utiler
          Hi Fredo, when converting an arc / circle to construction lines a point is added to its segment end. Is there a way of not doing so?
          And once again, thank you for what you do for SU!!
          Just Curious...
          • utilerU Offline
            utiler
            Anyone? Here's a screenshot of what I'm referring too...
            Just Curious...
              Select all
              Right Click /Select Only Guide Points / Delete ?
                πŸ˜‰
                • massimoM Offline
                  massimo Moderator
                  Like this? πŸ˜„
                    Efectively more speedy than my basic method! πŸ’š
                    • utilerU Offline
                      utiler
                      I knew it had to be something simple.... Thanks guys! πŸ‘ πŸ‘
                      Just Curious...
                        dedmin
                        Date; 25-Aug-13 05;57;22
                        An error occured in Curvizard#edge_prop
                        The operation is aborted
                        undefined method `length' for nil;NilClass
                        CurvizardAlgo.rb; 451 -- execute_geometry
                        CurvizardTool.rb; 1596 -- geometry_generate
                        CurvizardTool.rb; 1496 -- top_execute
                        CurvizardTool.rb; 290 -- handle_initial_selection
                        CurvizardTool.rb; 267 -- activate
                        CurvizardTool.rb; 46 -- select_tool
                        CurvizardTool.rb; 46 -- launch_tool
                        CurvizardTool.rb; 41 -- action__mapping
                        Lib6Plugin.rb; 134 -- call
                        Lib6Plugin.rb; 134 -- launch_action
                        bootstrap_Curvizard.rb; 51 -- launch_action
                        bootstrap_Curvizard.rb; 81 -- declare_command
                        Lib6Plugin.rb; 1044 -- call
                        Lib6Plugin.rb; 1044 -- command_invoke
                        Lib6Plugin.rb; 1026 -- build_config_commands
                        Lib6Traductor.rb; 1074 -- call
                        Lib6Traductor.rb; 1074 -- add_command
                          dedmin
                          (screencast.com)
                            kein2006
                            very nice plugin. It's really useful, thank you so much
                            • fredo6F Offline
                              NEW RELEASE: Curvizard v1.4a - 15 Sep 13
                              Curvizard 1.4a is a release with the following updates
                              • New naming conventions
                              • Fixes a major bug in the Edge Prop tool (which was not working)
                              • Include an alternate icon toolbar by CadFather
                              Curvizard 1.4 requires an upgrade to LibFredo6 5.2 or higher.
                              • fredo6F Offline
                                @dedmin said:
                                (screencast.com)
                                I am not sure I see the problem.
                                But in any case, Simplify is not the opposite of Smooth.
                                Furthermore, Smooth can be used to simplify a curve by incresing the angle, whereas Simplify just remove vertices based on a minimum angle
                                • fredo6F Offline
                                  @dedmin said:
                                  [attachment=0:wmnznkk8]<!-- ia0 -->2013-08-25_055853.jpg<!-- ia0 -->[/attachment:wmnznkk8]
                                  The bug in Edge Prop tool should be fixed in Curvizard 1.4a.
                                  • guanjinG Offline
                                    guanjin
                                    Thank you updates, always so timely! πŸ‘
                                      dedmin
                                      Excellent and invaluable tools!!!
                                      No problems so far!
                                      Thanks!!
                                      • utilerU Offline
                                        utiler
                                        Thank you Fredo from all that use your tools!!!
                                        Just Curious...
                                          dedmin
                                          Date; 16-Sep-13 19;59;36
                                          An error occured in Curvizard#cleanup_curve
                                          undefined method `[]' for nil;NilClass
                                          Lib6G6.rb; 1249 -- vertices_from_edges_in_sequence
                                          Lib6Contour.rb; 468 -- contour_reshaping
                                          encoding.rb; 48 -- each_with_index
                                          Lib6Contour.rb; 437 -- each
                                          Lib6Contour.rb; 437 -- each_with_index
                                          Lib6Contour.rb; 437 -- contour_reshaping
                                          CurvizardAlgo.rb; 523 -- execute_geometry
                                          CurvizardTool.rb; 1595 -- geometry_generate
                                          CurvizardTool.rb; 1495 -- top_execute
                                          bootstrap_Curvizard.rb; 83 -- declare_command
                                          Lib6Plugin.rb; 1111 -- call
                                          Lib6Plugin.rb; 1111 -- build_config_handlers
                                          FredoTools__ThruPaint.rb; 2315 -- call
                                          • fredo6F Offline
                                            dedmin,
                                            Would you mind to post or PM me the model.
                                            This looks like a bug linked to the geometry.
                                            • 5 / 10
