    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 375.1k Views 57 Watching
    • utilerU Offline
      utiler
      @utiler said:
      Hi Fredo, when converting an arc / circle to construction lines a point is added to its segment end. Is there a way of not doing so?
      And once again, thank you for what you do for SU!!
      Anyone? Here's a screenshot of what I'm referring too...
      Just Curious...
        Select all
        Right Click /Select Only Guide Points / Delete ?
          πŸ˜‰
          • massimoM Offline
            massimo Moderator
            Like this? πŸ˜„
              Efectively more speedy than my basic method! πŸ’š
              • utilerU Offline
                utiler
                I knew it had to be something simple.... Thanks guys! πŸ‘ πŸ‘
                Just Curious...
                  dedmin
                  Date; 25-Aug-13 05;57;22
                  An error occured in Curvizard#edge_prop
                  The operation is aborted
                  undefined method `length' for nil;NilClass
                  CurvizardAlgo.rb; 451 -- execute_geometry
                  CurvizardTool.rb; 1596 -- geometry_generate
                  CurvizardTool.rb; 1496 -- top_execute
                  CurvizardTool.rb; 290 -- handle_initial_selection
                  CurvizardTool.rb; 267 -- activate
                  CurvizardTool.rb; 46 -- select_tool
                  CurvizardTool.rb; 46 -- launch_tool
                  CurvizardTool.rb; 41 -- action__mapping
                  Lib6Plugin.rb; 134 -- call
                  Lib6Plugin.rb; 134 -- launch_action
                  bootstrap_Curvizard.rb; 51 -- launch_action
                  bootstrap_Curvizard.rb; 81 -- declare_command
                  Lib6Plugin.rb; 1044 -- call
                  Lib6Plugin.rb; 1044 -- command_invoke
                  Lib6Plugin.rb; 1026 -- build_config_commands
                  Lib6Traductor.rb; 1074 -- call
                  Lib6Traductor.rb; 1074 -- add_command
                    dedmin
                    (screencast.com)
                      kein2006
                      very nice plugin. It's really useful, thank you so much
                      • fredo6F Offline
                        NEW RELEASE: Curvizard v1.4a - 15 Sep 13
                        Curvizard 1.4a is a release with the following updates
                        • New naming conventions
                        • Fixes a major bug in the Edge Prop tool (which was not working)
                        • Include an alternate icon toolbar by CadFather
                        Curvizard 1.4 requires an upgrade to LibFredo6 5.2 or higher.
                        • fredo6F Offline
                          @dedmin said:
                          (screencast.com)
                          I am not sure I see the problem.
                          But in any case, Simplify is not the opposite of Smooth.
                          Furthermore, Smooth can be used to simplify a curve by incresing the angle, whereas Simplify just remove vertices based on a minimum angle
                          • fredo6F Offline
                            @dedmin said:
                            [attachment=0:wmnznkk8]<!-- ia0 -->2013-08-25_055853.jpg<!-- ia0 -->[/attachment:wmnznkk8]
                            The bug in Edge Prop tool should be fixed in Curvizard 1.4a.
                            • guanjinG Offline
                              guanjin
                              Thank you updates, always so timely! πŸ‘
                                dedmin
                                Excellent and invaluable tools!!!
                                No problems so far!
                                Thanks!!
                                • utilerU Offline
                                  utiler
                                  Thank you Fredo from all that use your tools!!!
                                  Just Curious...
                                    dedmin
                                    Date; 16-Sep-13 19;59;36
                                    An error occured in Curvizard#cleanup_curve
                                    undefined method `[]' for nil;NilClass
                                    Lib6G6.rb; 1249 -- vertices_from_edges_in_sequence
                                    Lib6Contour.rb; 468 -- contour_reshaping
                                    encoding.rb; 48 -- each_with_index
                                    Lib6Contour.rb; 437 -- each
                                    Lib6Contour.rb; 437 -- each_with_index
                                    Lib6Contour.rb; 437 -- contour_reshaping
                                    CurvizardAlgo.rb; 523 -- execute_geometry
                                    CurvizardTool.rb; 1595 -- geometry_generate
                                    CurvizardTool.rb; 1495 -- top_execute
                                    bootstrap_Curvizard.rb; 83 -- declare_command
                                    Lib6Plugin.rb; 1111 -- call
                                    Lib6Plugin.rb; 1111 -- build_config_handlers
                                    FredoTools__ThruPaint.rb; 2315 -- call
                                    • fredo6F Offline
                                      dedmin,
                                      Would you mind to post or PM me the model.
                                      This looks like a bug linked to the geometry.
                                      • fredo6F Offline
                                        NEW RELEASE: Curvizard v1.5a - 27 Nov 13
                                        Curvizard 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                                        • sicksickisckS Offline
                                          sicksickisck
                                          some bug in ver 1.5a ..crash skp9 when I use Curvizard inside the component.
                                            What is skp9?
                                            You have to give some useful details if you want help. Post the SketchUp model and describe exactly what you were trying to accomplish.
                                            I just tried it and it works for me without crashing.
                                            • 5 / 10
