    For those using the new beta ...
    renderpluginsextensions
    20 Posts 10 Posters 1.5k Views 10 Watching
      rvdkruk75
      And what should be the effect of these settings?
      • KrisidiousK Offline
        Krisidious
        I got a nice crisp image... Although my color threshold to 0.003. does not go down that far. it only goes to 0.01... and I didn't set my reflections because I had not edited my materials at all.
        By: Kristoff Rand
        • StinkieS Offline
          Stinkie
          A considerable gain in speed. A quote from Stefan Laub, one of the Vray for C4D devs: "AA: as vray DMC is a very intelligent and complex system which deals not only with AA on the end,
          but with any calculation in vray (GI, Glossy, lights, materials, image sampling), raising the max value of the AA often speeds up the scene greatly, as the max value reduces the need to sample the max subdivisions in lights and materials (as it is the same engine), a max AA of 100 renders faster than a max value of 4 if the scene uses area lights and glossy materials. the rendering might get a little more noisy when raising the AA max value, but you can compensate that in using the AA threshold value and lower it from 0.01(default) to 0.005 or lower. 1x100x 0.003 will be faster in many things than 1x4x 0.01 (!)"
          I did some testing yesterday. Using 'orthodox' AA stettings, my test scene rendered in 2m20s. Using Laub's settings, it finished in 48s. I rendered the same scene at 10000 pixels wide, still using Laub's settings. It finished in ... 18 minutes. πŸ’š
          • andybotA Offline
            andybot
            shoot, learn something new every day. Thanks for sharing the knowledge β˜€
            • StinkieS Offline
              Stinkie
              You're welcome. You tried the new 64 bit rendering? It works. β˜€
              Quite happy with that. Now I don't have to buy C4D+Vray. Phew! πŸ’š
              • O Offline
                OSN58
                • stefanqS Offline
                  stefanq
                  Aahh Stinkie , this is an old school type of post, like in the days of Asgvis forum....
                  I'm getting nostalgic here. Remember Biebel, FreeAgent, Andeciula, Migz, Theofas, Thomthom, Nomeradona and many many others.....Remember Damien Alomar posts?
                  • V Offline
                    valerostudio
                    This is a fantastic tip. I did a quick test and I am really impressed. It leaves me wondering why we haven't been told to do this before? I cant believe I just rendered a material with 256 subdivs in 3 minutes.
                      @OSN58 thanks for posting the comparisons.
                      How does this setup work with Catmull-Rom AA?
                      • StinkieS Offline
                        Stinkie
                        That's odd, Kris. It should be able to go lower than that.
                        I suspect render time would go up a little.
                          But would the different type of AA affect the result - considering it's a sharpening filter...
                          • StinkieS Offline
                            Stinkie
                            Hm, I'm inclined to think the visual difference would be negligible, but then I don't know that much about AA filters. I usually sharpen in PS, if at all.
                            • O Offline
                              OSN58
                              Unfortunately, it only works with 256 subdivs, render speed in other cases less.
                              • StinkieS Offline
                                Stinkie
                                Still -pretty neat, huh?
                                  designo_84
                                  Hi all,
                                  Btw i tried your way as you described specifically to render hi poly car model (proxy) but the render times increased significantly
                                    rspierenburg
                                    I noticed the same as designo, increased render times with the new settings vs default.
                                    • andybotA Offline
                                      andybot
                                      I'm guessing it depends on the GI lighting... I tried this on an interior and my render times doubled. Seems to work fine on a simple exterior scene, but you need to decrease the reflection depth too to make it work. Otherwise, the reflection of reflections really bogs it down too. ymmv
                                      • andybotA Offline
                                        andybot
                                        Hey stinkie, I've noticed you've moved. How's "yes"? πŸ˜›
                                        "behind you" had kind of an immediacy to it...
                                        kind a like that cudgel.
                                        urp
                                        • StinkieS Offline
                                          Stinkie
                                          @andybot said:
                                          How's "yes"?
                                          A lot like this: http://25.media.tumblr.com/tumblr_m30eiuIS5a1r95uueo1_500.gif.
                                          Click it. You know you want to.
