    Sketchup 2013 issues
    208 Posts 53 Posters 41.1k Views 53 Watching
    • Alan FraserA Offline
      Alan Fraser
      Maybe It will be a good idea to make a board with the plugins working or not with the new version ?
      Maybe, but other than Jim's Toolbar pretty much all plugins ought to be be working. Between them, I would imagine that the Beta testers have probably got just about every plugin out there (if they don't actually write them). They would most likely have come across most problems during the test period.
      3D Figures
        Alan Fraser
        @gaieus said:
        Alan, you might even break NDA' here... πŸ˜‰
        Diplomatically edited. πŸ˜‰
        3D Figures
          @alan fraser said:
          ...Diplomatically edited. πŸ˜‰
          Not my software - and not my Beta forums & NDA - but thanks. πŸ˜„
          • kenK Offline
            ken
            Ok, previously I had Sketchup V8 crash repeatedly lately as indicated in another thread. Last night and today, I have done everything I know that made V8 crash, and no crash. Crossing my fingers, but this does seem to be stable. If that proves to be true, this is a BIG improvement.
            I am so far happy with the new version.
            I especially like the extension web site.
            Ken
              @sepo said:
              Any Idea how to go about plugins such as rendering soft such as vray, lightup, podium, twilight, thea. Do you need to reinstall them or just move folders?
              Any plugin/extension that comes with an installer I'd install manually instead of copying.
                sepo
                That makes sense Thomas
                • KrisidiousK Offline
                  Krisidious
                  Is it just me or is copy and paste from Sketchup to Layout not working?
                  By: Kristoff Rand
                  • kenK Offline
                    ken
                    Toolbar Display in Toolbar menu box
                    One thing I would like to have changed, and I know it not going to happen right away. In the toolbar menu box the toolbars are listed alphabetically. I really did like having the native toolbars segregated, with the natives at the top and the plugins at the bottom.
                    Guess I get use to this new world.
                    Ken
                      tomasz
                      In case of Thea you can copy/move folder. Please make sure you have revision higher or equal to 071 installed. Mac version is not fully functional in SU2013 yet. We are working on it. Windows version is fully functional and SU2013 is on the list in the installer.
                      @chris fullmer said:
                      Generally, we did not do things that would break plugins moving from SU 8 to SU 2013. But there are always exceptions and unintended consequences..
                      Right. A change inside SU on Mac...
                      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                      • daleD Offline
                        dale
                        So Tomasz, would it be better to hold off on upgrading until Thea is fully functional on Mac?
                        I rely on Thea for work, and deadlines usually mean no time for screw ups.
                        Is there a timeframe on the Mac fix?
                          tomasz
                          I am working on it as we speak. It is a highest priority for me to fix it.
                          Please hold off with the full switch to SU2013.
                          This shouldn't stop you from testing the new version, but at the moment Thea is not correctly reading materials inside SU2013 for Mac.
                          I hope the fix will be ready in few days.
                          • daleD Offline
                            dale
                            Thanks Tomasz, both for your quick reply, and all your hard work.
                            Think I'll just hang on.
                              ArCAD-UK
                              I reinstalled Twilight and it seems to be working as expected. Profile Builder's preview window is broken.
                                Krisidious
                                Here's the fix.
                                By: Kristoff Rand
                                • david_hD Offline
                                  david_h
                                  I have a bit of a problem with which I hope you guys can help . .
                                  I downloaded 2013 for a minute, but changed my mind and off-loaded it immediately. (Nothin' against 13 per se I just didn't have time to play with it and decided to download it later) I did nothing else with my file structure. SU 8 still in tact, etc.
                                  However . . .now all of my SKP files have been Hi-jacked by Google as the Default program and the "open with" won't let me changeit back to SU for some reason. So I have to open SU first and then hunt for the file thru the "Open" pull down in SU rather than just double-click on the file itself to open it.
                                  Any ideas on how to fix this?
                                  Thx in advance.
                                  David
                                    Krisidious
                                    use that browse feature to find the SU V8 exe and then make sure that "Always use this application is checked" it should then default back to SU8.
                                    By: Kristoff Rand
                                      It doesn't remember your setting after you've browsed your way to Sketchup.exe?
                                        Krisidious
                                        You also might try the down arrow just under Chrome, (Other Programs) it may show SketchUp with out browsing to it.
                                        By: Kristoff Rand
                                        • david_hD Offline
                                          david_h
                                          Tried that several times. . .and it won't let me select Sketchup.exe or remember it. I will give it another go based on your suggestions.
                                          Thanks guys.
                                          D
                                          UPDATE . .when I click the down arrow to show additional programs. . .Sketchup Doesn't show up.
                                            Krisidious
                                            Thanks guys.
                                            D
                                            You're right... I just tried it and it won't go back to SU V8. This is not good.
                                            By: Kristoff Rand
                                            • 11
                                            • 3 / 11
