    Fix for Profile Builder Previews in SU2013
    30 Posts 14 Posters 7.0k Views 14 Watching
      small08
      Reload latest version of Javascript!
      • Gus RG
        Gus R
        Found a solution. Go into ...SketchUp\SketchUp 2013\Plugins\ProfileBuilder directory and replace wz_jsgraphics.js with the latest version uploaded here in zip form. Unzip it of course.
        wz_jsgraphics.zip
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • Gus RG
          Gus R
          Forgot that I was looking into this last night. Here's the original source.
          • KrisidiousK
            Krisidious
            Yes... That fixed it. Thanks Gus.
            By: Kristoff Rand
            • Gus RG
              Gus R
              Tested it on SU 8 and it works there too so it's at least backwards compatible to that version. Someone, maybe one of the Trimble employees, should contact Dale Martens or Smustard as to the fix. I can give them contact information if they need it.
              • Chris FullmerC
                I know Dale is working on it. I'll make sure to point him to this thread to take a look. Thanks Gus,
                • N
                  noro
                  @ Gus R - Many, many thanks you are the MAN!
                    @krisidious said:
                    I reloaded Java to no effect... Except that roughly half of my toolbars had to be turned back on.
                    Javascript is not Java...
                    • KrisidiousK
                      Krisidious
                      I noticed... When reinstalling Java, which I have to do it seems weekly, did nothing. but thanks for the FYI...
                      By: Kristoff Rand
                      • KrisidiousK
                        Krisidious
                        As Thom points out lower int he thread, reloading Java will do nothing as it is not Javascript.
                        By: Kristoff Rand
                        • gullfoG
                          gullfo
                          good catch Gus!
                          Glenn
                          http://www.runnel.com
                          • W
                            Whaat
                            Thanks guys. Yes, I was working on the fix last night. I've need to make a couple of other changes to the code so that it is compliant with the new SU2013 extension warehouse so I need a bit more time to test. Hopefully, I can release the update within a week or so.
                            Thanks for your patience.
                            BTW, another way to fix the issue is to add this line to the HTML files inside the ProfileBuilder folder (within your plugins folder). It must be added to the <head> section.
                            <meta http-equiv="x-ua-compatible" content="IE=7">
                            • KrisidiousK
                              Krisidious
                              Thanks for the update Dale... Working better than ever for me as is.
                              By: Kristoff Rand
                                small08
                                Yes, Gus! That's what I had done previously when this was an issue...and meant to say reload the latest *.js loader.
                                  rv1974
                                  Gus 👍
                                  • kingsiK
                                    kingsi
                                    Thanks Gus. Needed that sorted for today 😄
                                    Noobtastic
                                    • ccaponigroC
                                      ccaponigro
                                      Thank you!!!! I was pulling my hair out. Man I love this website.
                                      cfcaia.com
                                      • W
                                        Whaat
                                        Hi everyone,
                                        An update has been released on Smustard.com (which fixes the preview issue). I think if you can find the original email with the download link, you should be able to upgrade. Alternatively, you should be able to access upgrades using the MySmustard toolbar.
                                        • KrisidiousK
                                          Krisidious
                                          If we've already fixed it do we need to update Dale?
                                          By: Kristoff Rand
                                          • W
                                            Whaat
                                            No, you don't need to update if you have already fixed it. However, Mac users may want to upgrade because there was a small fix done to drastically reduce the time it takes to smooth the edges. Windows users are not affected.
