    Fix for Profile Builder Previews in SU2013
    30 Posts 14 Posters 6.3k Views 14 Watching
    • N Offline
      noro
      @ Gus R - Many, many thanks you are the MAN!
        @small08 said:
        Reload latest version of Javascript!
        @krisidious said:
        I reloaded Java to no effect... Except that roughly half of my toolbars had to be turned back on.
        Javascript is not Java...
        • KrisidiousK Offline
          Krisidious
          I noticed... When reinstalling Java, which I have to do it seems weekly, did nothing. but thanks for the FYI...
          By: Kristoff Rand
            Krisidious
            As Thom points out lower int he thread, reloading Java will do nothing as it is not Javascript.
            By: Kristoff Rand
            • gullfoG Offline
              gullfo
              good catch Gus!
              Glenn
              http://www.runnel.com
              • W Offline
                Whaat
                Thanks guys. Yes, I was working on the fix last night. I've need to make a couple of other changes to the code so that it is compliant with the new SU2013 extension warehouse so I need a bit more time to test. Hopefully, I can release the update within a week or so.
                Thanks for your patience.
                BTW, another way to fix the issue is to add this line to the HTML files inside the ProfileBuilder folder (within your plugins folder). It must be added to the <head> section.
                <meta http-equiv="x-ua-compatible" content="IE=7">
                  Krisidious
                  Thanks for the update Dale... Working better than ever for me as is.
                  By: Kristoff Rand
                    small08
                    Yes, Gus! That's what I had done previously when this was an issue...and meant to say reload the latest *.js loader.
                      rv1974
                      Gus 👍
                      • kingsiK Offline
                        kingsi
                        Thanks Gus. Needed that sorted for today 😄
                        Noobtastic
                        • ccaponigroC Offline
                          ccaponigro
                          Thank you!!!! I was pulling my hair out. Man I love this website.
                          cfcaia.com
                          • W Offline
                            Whaat
                            Hi everyone,
                            An update has been released on Smustard.com (which fixes the preview issue). I think if you can find the original email with the download link, you should be able to upgrade. Alternatively, you should be able to access upgrades using the MySmustard toolbar.
                              Krisidious
                              If we've already fixed it do we need to update Dale?
                              By: Kristoff Rand
                              • W Offline
                                Whaat
                                No, you don't need to update if you have already fixed it. However, Mac users may want to upgrade because there was a small fix done to drastically reduce the time it takes to smooth the edges. Windows users are not affected.
                                  mjnhproqb
                                  Thanks you !!!
                                    CJRyan
                                    OK, I'm still having issues with Profile builder in SU8 Pro, not being able to see thumbnails.
                                    This first happened when I loaded SU 13. As none of the above fixes seemed to work, I removed SU 13 from my computer. That restored the thumbnails in PB.
                                    I have now upgraded to SU 14 Pro and am having the same issues with my 8 Pro.
                                    I dropped the new JS file into the plug-ins folder and got nothing but a bug-splat.
                                    Any help for me out there?
                                    • W Offline
                                      Whaat
                                      Upgrade to the latest version from Smustard. Use the MySmustardToolbar or find your original email with the download link in order to get access the upgrade.
                                      Cheers,
                                      Dale
                                      • 2 / 2
