    Fix for Profile Builder Previews in SU2013
    30 Posts 14 Posters 7.0k Views 14 Watching
    • gullfoG
      gullfo
      good catch Gus!
      Glenn
      http://www.runnel.com
      • W
        Whaat
        Thanks guys. Yes, I was working on the fix last night. I've need to make a couple of other changes to the code so that it is compliant with the new SU2013 extension warehouse so I need a bit more time to test. Hopefully, I can release the update within a week or so.
        Thanks for your patience.
        BTW, another way to fix the issue is to add this line to the HTML files inside the ProfileBuilder folder (within your plugins folder). It must be added to the <head> section.
        <meta http-equiv="x-ua-compatible" content="IE=7">
        • KrisidiousK
          Krisidious
          Thanks for the update Dale... Working better than ever for me as is.
          By: Kristoff Rand
            small08
            Yes, Gus! That's what I had done previously when this was an issue...and meant to say reload the latest *.js loader.
              rv1974
              Gus 👍
              • kingsiK
                kingsi
                Thanks Gus. Needed that sorted for today 😄
                Noobtastic
                • ccaponigroC
                  ccaponigro
                  Thank you!!!! I was pulling my hair out. Man I love this website.
                  cfcaia.com
                  • W
                    Whaat
                    Hi everyone,
                    An update has been released on Smustard.com (which fixes the preview issue). I think if you can find the original email with the download link, you should be able to upgrade. Alternatively, you should be able to access upgrades using the MySmustard toolbar.
                    • KrisidiousK
                      Krisidious
                      If we've already fixed it do we need to update Dale?
                      By: Kristoff Rand
                      • W
                        Whaat
                        No, you don't need to update if you have already fixed it. However, Mac users may want to upgrade because there was a small fix done to drastically reduce the time it takes to smooth the edges. Windows users are not affected.
                          mjnhproqb
                          Thanks you !!!
                          • C
                            CJRyan
                            OK, I'm still having issues with Profile builder in SU8 Pro, not being able to see thumbnails.
                            This first happened when I loaded SU 13. As none of the above fixes seemed to work, I removed SU 13 from my computer. That restored the thumbnails in PB.
                            I have now upgraded to SU 14 Pro and am having the same issues with my 8 Pro.
                            I dropped the new JS file into the plug-ins folder and got nothing but a bug-splat.
                            Any help for me out there?
                            • W
                              Whaat
                              Upgrade to the latest version from Smustard. Use the MySmustardToolbar or find your original email with the download link in order to get access the upgrade.
                              Cheers,
                              Dale
                              • 2 / 2
