    Fix for Profile Builder Previews in SU2013
    30 Posts 14 Posters 6.2k Views 14 Watching
    • KrisidiousK Offline
      Krisidious
      I have not tried to use it but I would say it's the location difference between the two versions.
      By: Kristoff Rand
      • gullfoG Offline
        gullfo
        same here - cannot see the graphic although the relative path settings are identical to SU8. maybe the Javascript function is blocked somehow?
        missing graphic when profile is selected
        as a note: all permissions on the top level folder on down is set full control and even though the profile is not showing in the dialog (nor do the edit controls work "select a profile" msg) the profiles are being drawn when using the build or apply to selected edges.
        Glenn
        http://www.runnel.com
          Krisidious
          Have you tried creating a new profile to see if it shows up?
          By: Kristoff Rand
          • N Offline
            noro
            I am free version user, so I can't create my own profile... Anyway I don't think there are any problems with existing profiles from the library...
              ArCAD-UK
              Same problem here. I've flagged it up on the official PB support page but not had a response yet.
              • gullfoG Offline
                gullfo
                yes, creating a new profile works (i.e. i can create it and use it as-is) but still no display of the profile.
                Glenn
                  small08
                  Reload latest version of Javascript!
                  • Gus RG Offline
                    Gus R
                    Found a solution. Go into ...SketchUp\SketchUp 2013\Plugins\ProfileBuilder directory and replace wz_jsgraphics.js with the latest version uploaded here in zip form. Unzip it of course.
                    wz_jsgraphics.zip
                    www.instagram.com/gusrobatto/
                    www.facebook.com/gusrobatto
                    • Gus RG Offline
                      Gus R
                      Forgot that I was looking into this last night. Here's the original source.
                        Krisidious
                        Yes... That fixed it. Thanks Gus.
                        By: Kristoff Rand
                        • Gus RG Offline
                          Gus R
                          Tested it on SU 8 and it works there too so it's at least backwards compatible to that version. Someone, maybe one of the Trimble employees, should contact Dale Martens or Smustard as to the fix. I can give them contact information if they need it.
                          • Chris FullmerC Offline
                            I know Dale is working on it. I'll make sure to point him to this thread to take a look. Thanks Gus,
                            • N Offline
                              noro
                              @ Gus R - Many, many thanks you are the MAN!
                                @krisidious said:
                                I reloaded Java to no effect... Except that roughly half of my toolbars had to be turned back on.
                                Javascript is not Java...
                                  Krisidious
                                  I noticed... When reinstalling Java, which I have to do it seems weekly, did nothing. but thanks for the FYI...
                                  By: Kristoff Rand
                                    Krisidious
                                    As Thom points out lower int he thread, reloading Java will do nothing as it is not Javascript.
                                    By: Kristoff Rand
                                    • gullfoG Offline
                                      gullfo
                                      good catch Gus!
                                      Glenn
                                      • W Offline
                                        Whaat
                                        Thanks guys. Yes, I was working on the fix last night. I've need to make a couple of other changes to the code so that it is compliant with the new SU2013 extension warehouse so I need a bit more time to test. Hopefully, I can release the update within a week or so.
                                        Thanks for your patience.
                                        BTW, another way to fix the issue is to add this line to the HTML files inside the ProfileBuilder folder (within your plugins folder). It must be added to the <head> section.
                                        <meta http-equiv="x-ua-compatible" content="IE=7">
                                          Krisidious
                                          Thanks for the update Dale... Working better than ever for me as is.
                                          By: Kristoff Rand
                                            small08
                                            Yes, Gus! That's what I had done previously when this was an issue...and meant to say reload the latest *.js loader.
