    Fix for Profile Builder Previews in SU2013
    30 Posts 14 Posters 6.1k Views 14 Watching
    • KrisidiousK Offline
      Krisidious
      I reloaded Java to no effect... Except that roughly half of my toolbars had to be turned back on.
      As Thom points out lower int he thread, reloading Java will do nothing as it is not Javascript.
      By: Kristoff Rand
      • gullfoG Offline
        gullfo
        good catch Gus!
        Glenn
        http://www.runnel.com
        • W Offline
          Whaat
          Thanks guys. Yes, I was working on the fix last night. I've need to make a couple of other changes to the code so that it is compliant with the new SU2013 extension warehouse so I need a bit more time to test. Hopefully, I can release the update within a week or so.
          Thanks for your patience.
          BTW, another way to fix the issue is to add this line to the HTML files inside the ProfileBuilder folder (within your plugins folder). It must be added to the <head> section.
          <meta http-equiv="x-ua-compatible" content="IE=7">
            Krisidious
            Thanks for the update Dale... Working better than ever for me as is.
            By: Kristoff Rand
              small08
              Yes, Gus! That's what I had done previously when this was an issue...and meant to say reload the latest *.js loader.
                rv1974
                Gus 👍
                • kingsiK Offline
                  kingsi
                  Thanks Gus. Needed that sorted for today 😄
                  Noobtastic
                  • ccaponigroC Offline
                    ccaponigro
                    Thank you!!!! I was pulling my hair out. Man I love this website.
                    cfcaia.com
                    • W Offline
                      Whaat
                      Hi everyone,
                      An update has been released on Smustard.com (which fixes the preview issue). I think if you can find the original email with the download link, you should be able to upgrade. Alternatively, you should be able to access upgrades using the MySmustard toolbar.
                        Krisidious
                        If we've already fixed it do we need to update Dale?
                        By: Kristoff Rand
                        • W Offline
                          Whaat
                          No, you don't need to update if you have already fixed it. However, Mac users may want to upgrade because there was a small fix done to drastically reduce the time it takes to smooth the edges. Windows users are not affected.
                            mjnhproqb
                            Thanks you !!!
                              CJRyan
                              OK, I'm still having issues with Profile builder in SU8 Pro, not being able to see thumbnails.
                              This first happened when I loaded SU 13. As none of the above fixes seemed to work, I removed SU 13 from my computer. That restored the thumbnails in PB.
                              I have now upgraded to SU 14 Pro and am having the same issues with my 8 Pro.
                              I dropped the new JS file into the plug-ins folder and got nothing but a bug-splat.
                              Any help for me out there?
                              • W Offline
                                Whaat
                                Upgrade to the latest version from Smustard. Use the MySmustardToolbar or find your original email with the download link in order to get access the upgrade.
                                Cheers,
                                Dale
                                • 2 / 2
