    Texture Mapping Curtains
    28 Posts 8 Posters 4.4k Views 8 Watching
    • neetsN Offline
      neets
      Hey guys/gals,
      I'm about to run to the hills. I've been trying to map a striped pattern onto curtains that are held back with tie-backs and the mapping when I use 'projected' isn't great. Does anyone have any words of wisdom or is this something that SU just hasn't been able to master yet??!!
      Anita
      Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
      • Rich O BrienR Online
        the short answer...
        SU is pants at mapping
        the long answer...
        If you've modeled in the QuadFace principle then you can easily paint the curtains. If not try using Fredo's ThruPaint using the Natural UV option.
        But withoutseeing the actual mesh it is hard to make a proper suggestion
        • neetsN Offline
          neets
          Thanks for getting back to me Rich. So what does everyone else do when they need to texture map an organic object??!! I've tried to attach a SU file of the curtains in question but I've been told that I've exceeded the allowance??!! The file only contains a set of curtains!! I've been able to project patterns onto curtains in the past but I'm assuming because these are quite 'draped' that it's causing problems?
          Anita
            Learn how to UV map or start a discussion here πŸ˜‰
            Try clicking my signature you never know what sh!t turns up in there
              Can you post a sample model? Then we could suggest what tools you can best apply to it.
              • renderizaR Offline
                renderiza
                Smart texturing with Tgi3D SU Amorph plugin for SketchUp ...
                [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                • jo-keJ Offline
                  jo-ke
                  I'm textureing my curtains with quadface tools
                  404 Not Found
                  (sketchucation.com)
                  the result is very nice and it's fast and easy to use.
                  http://www.zz7.de
                  • neetsN Offline
                    neets
                    Hi there, I've tried to upload the skp. file (which only contains a pair of curtains) and it says that I've exceeded the maximum allowance???!!!
                    I've also downloaded Quadface Tools but can't access it within SketchUp - I've obviously done something wrong...any ideas?!
                    • jo-keJ Offline
                      jo-ke
                      Can you post a picture of the mesh of your curtains (with hidden geometrie)
                      Or upload the skp somewhere else and post the link here.
                      http://www.zz7.de
                      • neetsN Offline
                        neets
                        Ok, here's a JPEG of the two different types of curtain that I've been trying to texture map recently and they look good when viewing them at front elevation but from the side the patterns are distorted.Curtains.jpg
                          @Neets
                          Did you look a my tut on umwrapping in Blender?
                          There's absolutely noway that'll map in SU unless you spend time converting it to QuadFace compliant
                          • KrisidiousK Offline
                            Krisidious
                            are those polys I see? I would say those could be a lot lighter... might want to hit ThomThom's cleanup tools or artisan's poly reducer.
                            By: Kristoff Rand
                            • neetsN Offline
                              neets
                              I've been playing around with Thrupaint and it's providing an excellent UV projection of the required texture BUT it isn't projecting it at the right rotation. These stripes should be vertical - when I try to rotate the texture using Thrupaint it distorts the texture. The JPEG material is vertical so I'm not sure why this is happening?Texture Projection.jpg
                              • fredo6F Offline
                                I've been playing around with Thrupaint and it's providing an excellent UV projection of the required texture BUT it isn't projecting it at the right rotation. These stripes should be vertical - when I try to rotate the texture using Thrupaint it distorts the texture. The JPEG material is vertical so I'm not sure why this is happening?[attachment=0:2uldkfx6]<!-- ia0 -->Texture Projection.jpg<!-- ia0 -->[/attachment:2uldkfx6]
                                Neets,
                                With the projection mode of ThruPaint, you have 2 parameters to choose
                                1. the plane of projection (via the floating palette). Instead of choosing the default, which "picked face", I guess you should select the vertical plane of the curtain.
                                2. the initial orientation, which is indicated by the samm red and green UV axes when you mouse over the faces.
                                But the fact that it is distorted when trying to align the texture 'vertically' has nothing with Thrupaint or the native SU paint bucket tool.
                                This is simply the normal behavior of any planar texture projection. Since the curtain is folded you will always have some parts which are almost perpendicular to the projection plane, and thus heavily distorted.
                                Only a Mesh mapping can make it. So the best is probably to use SketchUV and map it in an external software that can cope with this type of convoluted surface.
                                • Gus RG Offline
                                  Gus R
                                  Rich, great tutorial video. For some strange reason it's importing into Blender at a 45 degree angle. Not changing any of the texture positions in SU nor the position of the model.
                                  www.instagram.com/gusrobatto/
                                  www.facebook.com/gusrobatto
                                    Are you using SketchUV Gus?
                                    Did you explode the model to remove it default axix position?
                                    Did you remove the mats applied to the group and not the geometry?
                                    • neetsN Offline
                                      neets
                                      Darn,
                                      I had posted a reply and for some strange reason it hasn't appeared. I said something like; 'Fredo!!! The infamous Fredo!!! Thanks for your reply! πŸ˜‰ I shall act on your instruction tomorrow but I'm currently onto my 3rd glass of wine and singing into a mirror using my hairbrush - cos we all gotta take a step back (even from my beloved SketchUp) for a wee breather'
                                      Anita
                                      • neetsN Offline
                                        neets
                                        Rich, how on earth do you know all of this stuff??!! Huh?!
                                          I don't I just pretend πŸ˜‰
                                          • neetsN Offline
                                            neets
                                            Yea, right...!! If I can work out how to get those stripes to appear as good vertically using Thrupaint I shall treat myself to ANOTHER glass of wine!!
