    Texture Mapping Curtains
    28 Posts 8 Posters 4.9k Views 8 Watching
    • jo-keJ
      jo-ke
      Can you post a picture of the mesh of your curtains (with hidden geometrie)
      Or upload the skp somewhere else and post the link here.
      http://www.zz7.de
      • neetsN
        neets
        Ok, here's a JPEG of the two different types of curtain that I've been trying to texture map recently and they look good when viewing them at front elevation but from the side the patterns are distorted.Curtains.jpg
        Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
          @Neets
          Did you look a my tut on umwrapping in Blender?
          There's absolutely noway that'll map in SU unless you spend time converting it to QuadFace compliant
          • KrisidiousK
            Krisidious
            are those polys I see? I would say those could be a lot lighter... might want to hit ThomThom's cleanup tools or artisan's poly reducer.
            By: Kristoff Rand
            • neetsN
              neets
              I've been playing around with Thrupaint and it's providing an excellent UV projection of the required texture BUT it isn't projecting it at the right rotation. These stripes should be vertical - when I try to rotate the texture using Thrupaint it distorts the texture. The JPEG material is vertical so I'm not sure why this is happening?Texture Projection.jpg
              • fredo6F
                I've been playing around with Thrupaint and it's providing an excellent UV projection of the required texture BUT it isn't projecting it at the right rotation. These stripes should be vertical - when I try to rotate the texture using Thrupaint it distorts the texture. The JPEG material is vertical so I'm not sure why this is happening?[attachment=0:2uldkfx6]<!-- ia0 -->Texture Projection.jpg<!-- ia0 -->[/attachment:2uldkfx6]
                Neets,
                With the projection mode of ThruPaint, you have 2 parameters to choose
                1. the plane of projection (via the floating palette). Instead of choosing the default, which "picked face", I guess you should select the vertical plane of the curtain.
                2. the initial orientation, which is indicated by the samm red and green UV axes when you mouse over the faces.
                But the fact that it is distorted when trying to align the texture 'vertically' has nothing with Thrupaint or the native SU paint bucket tool.
                This is simply the normal behavior of any planar texture projection. Since the curtain is folded you will always have some parts which are almost perpendicular to the projection plane, and thus heavily distorted.
                Only a Mesh mapping can make it. So the best is probably to use SketchUV and map it in an external software that can cope with this type of convoluted surface.
                • Gus RG
                  Gus R
                  @rich o brien said:
                  what does everyone else do when they need to texture map an organic object
                  Learn how to UV map or start a discussion here πŸ˜‰
                  Try clicking my signature you never know what sh!t turns up in there
                  Rich, great tutorial video. For some strange reason it's importing into Blender at a 45 degree angle. Not changing any of the texture positions in SU nor the position of the model.
                  www.instagram.com/gusrobatto/
                  www.facebook.com/gusrobatto
                    Are you using SketchUV Gus?
                    Did you explode the model to remove it default axix position?
                    Did you remove the mats applied to the group and not the geometry?
                    • neetsN
                      neets
                      Darn,
                      I had posted a reply and for some strange reason it hasn't appeared. I said something like; 'Fredo!!! The infamous Fredo!!! Thanks for your reply! πŸ˜‰ I shall act on your instruction tomorrow but I'm currently onto my 3rd glass of wine and singing into a mirror using my hairbrush - cos we all gotta take a step back (even from my beloved SketchUp) for a wee breather'
                      Anita
                      • neetsN
                        neets
                        Rich, how on earth do you know all of this stuff??!! Huh?!
                          I don't I just pretend πŸ˜‰
                          • neetsN
                            neets
                            Yea, right...!! If I can work out how to get those stripes to appear as good vertically using Thrupaint I shall treat myself to ANOTHER glass of wine!!
                            • Gus RG
                              Gus R
                              Opened the skp. Removed the material from the group. One iteration of Artisan smoothing. Applied material. Exported UV with SketchUV within the group not moving or having rotated anything. Imported obj into Blender. Scaled it down. Right click and smooth. Tabbed into edit mode and click U and then UV unwrap. Then I switch over to texture mode and it's at 45 degrees. Tried it again with a fresh download of the skp in case I moved anything earlier.
                                @Gus
                                In the UV editor hover over the unwrapped mesh and press L to select it
                                R to rotate it
                                If you can give me a link to that cloth as I can't find it now...so I can investigate it.
                                I'm sure I'm missing something here
                                • Gus RG
                                  Gus R
                                  @rich o brien said:
                                  @Gus
                                  R to rotate it
                                  Thanks, was practicing the rotation as well. Reset Blender to factory settings as well. Here's the link to the model.
                                    So, here's my result
                                    Exploded SU model
                                    removed texture
                                    sub'd
                                    applied mat to front face
                                    selected all export UVs
                                    imported into Blender
                                    scaled down
                                    tabbed into edit mode
                                    U to unwrap and here's the results
                                      @Gus
                                      Looking at this again there is some stray geometry getting unwrapped
                                      http://sketchucation.com/forums/download/file.php?id=105623&mode=view/rokbox.jpg
                                      you can see it in the bottom right corner
                                      • Gus RG
                                        Gus R
                                        @rich o brien said:
                                        @Gus
                                        Rich, I found a fix by uninstalling Blender 2.63 and upgrading to 2.67. Works now. Thanks for your help.
                                        • jo-keJ
                                          jo-ke
                                          ah, these decorated curtains a very difficult. If had the same problems too and they aren't solved yet.
                                          Below I attach my file, for trying to texture with vertical stripes...
                                          raffschal.skp
                                          http://www.zz7.de
                                            D'oh!
                                            Never cross my mind you were on an old version. Happy mapping
