    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • panixiaP
      panixia
      I will see if I can make a palette style.
      thank you a lot!
      πŸ’­ maybe if you already got control over the label's color it could also be easier to change them with some colors which can work good with both light or dark line style, pheraps using colors wich ar not much light or much dark..
      • HieruH
        Hieru
        When working on architectural models, generating good topo for a hillside plot can be an absolute pain.
        I just tried this on a project that previously took me the best part of a day to deal with the landscaping. A few clicks with this plugin and job done - simply amazing
        www.davidhier.co.uk
          matt.gordon320
          Absolutely astounding work as always sir. A donation will be on it's way soon πŸ˜„
          • EscapeArtistE
            EscapeArtist
            This is AWESOME. I've been fighting with trying to smooth out some not-so-detailed contours from a USGS map for a while, this ruby did it in a snap with perfect detail. Thank you! πŸ‘ πŸ‘
            • olisheaO
              olishea
              HUGE time saver!!
              Normally i'd have to make construction point grids and then triangulate the points. This is so much more streamlined.
              πŸ‘ πŸ‘ πŸ‘ πŸ˜„
              oli
              • G
                gundamzd
                Thanks so much for sharing this great plugin. However everytime I click "Calculate Terrain" SketchUp just crashes....and I tried the old sandbox tool it worked OK...can anyone tell me how to resolve this? Thanks so much!
                • KrisidiousK
                  Krisidious
                  @gundamzd said:
                  do you have any of these conflicting plugins? and have you downloaded the new libfredo library?
                  IMPORTANT: Requires to download LibFredo6 4.8 or higher if not already installed
                  CONFLICTING PLUGINS: some plugins conflicts with some of my scripts
                  Some versions of Podium
                  SunPosition
                  Matchbox
                  By: Kristoff Rand
                  • fredo6F
                    @gundamzd said:
                    Could you post or PM me the contours model so that I have a look.
                    Does it happen on all models you test (for instance on the sample models which are attached to the first post of this thread)?
                    • G
                      gundamzd
                      @gundamzd said:
                      I reinstalled SketchUp and now it's working...must be some other conflicting plugins. Thanks again!
                      • G
                        gundamzd
                        @krisidious said:
                        @gundamzd said:
                        SunPosition
                        Matchbox
                        You're right it was some other conflicting plugin but solved the problem by re-installing SketchUp. Thanks!
                        • KrisidiousK
                          Krisidious
                          No Problem... Enjoy Fredo's awesome plugin.
                          By: Kristoff Rand
                          • plot-parisP
                            plot-paris
                            Hey Fredo,
                            pbacot's post made me thinking: One more nifty feature would be "Automatic Elevation".
                            Oftentimes one receives topographical data in 2D form (each line represents lets say 1 meter, but the actual model is just a 2D plan).
                            While your plugin does everything else perfectly, one still has to rely on manual labour (or another plugin) to move the contours up one by one.
                            Therefore this feature request for "Automatic Elevation". It would work as follows:
                            • when analyzing the model, TopoShaper checks, if there is a third dimension to the geometry.
                            • if all the contours reside on a planar surface, the plugin assumes a default step size (1 meter) and offsets each contour line by that distance in z-direction (or perpendicular to the planar surface of the contours).
                            • TopoShaper chooses one boundary-contour as the "bottom" (usually the southern one I would presume) and displays a gizmo, sitting on that contour.
                            • you can drag the gizmo to the other side of the terraint to reverse the direction of elevation
                            • alternatively you get that little popup-window (that is already being used by the plugin) to choose the direction. The gizmo would then jump to the other side
                            • the gizmo shows a vertical scaling-handle (like the green scale knob in the scale tool), which you can use to change the overall height of the terrain
                            • alternatively you can type in a numerical height in the menu at the top of the screen
                            • this "Elevation Gizmo" is deactivated by default, should the plugin find z-elevation already present in the model. It can be toggled on/off in the top menu though
                            In my opinion, this addition would perfect the plugin! Don't know, if it is possible. But considering what the plugin already does... πŸ˜‰
                            Would love to hear your thoughts on this.
                            • pbacotP
                              P-P
                              Contours, as you know can be convoluted. The tool I use in PowerCADD is more hands-on but goes pretty fast. You set the tool to the height of the contour you want to start with, set the increment and up-down direction. Then as you drag the cursor (in this case needle) it tells you what the contour under the cursor will be, then sets it when you let go. So you can do many contours in a sweep, all with a tag giving their elevation. You let go and they're set. Hovering with the cursor will give the contour's set elevation. And you can change it the same way.
                              PowerCADD is 2D but it will export such a set of contours in 3d dxf.
                              P
                              • panixiaP
                                panixia
                                i'm not into this kind of modeling.. anyway i'm interested into trekking and mountan biking so i tried to have fun with this plugin it works hella fine even with massive geometry here is my test with one of my favourite mountains πŸ˜„
                                • jolranJ
                                  jolran
                                  Fredo, you must be very rich giving a plugin like this away for free 😲
                                  Crazy amounts of code..
                                  • P
                                    Panga
                                    A really big thanks for this one Fredo, as always ! You don't imagine how many hours of my life you give me back with this ! I'll hit the donation button again, and hit it hard ! Now I have to learn this plugin, it seems that there's so many features in it !
                                    Thinking of it, you just made what I was waiting from the SU dev team since I started using sketchup...
                                      That's some nice terrain graphics there. Did you make the earth section texture yourself?
                                      • panixiaP
                                        panixia
                                        i don't deal with contour models, landscape and so on.. just wanted to play with this beauty of plugin.. so grabbed the mountain from google used contour maker by tig to cut the contours, used the cuntours to generate the mesh, did a bit of general cleanup and texturing with a mix of VT + QFT + trupaint, then copied and pasted in place into groups both the contours and the quad grid and converted them with "lines to tubes" plugin for vray to render them.
                                        just to practice.. one never knows.. plus this is funny.
                                        edit. i misunderstood the question.. my english is quite bad.. and i'm tired.. yeah i did the texture by myself.. here is the vismat if you like it..
                                        sezione terreno.zip
                                          rv1974
                                          Fantastic! thank you Fredo for sharing.
                                          • P
                                            publied
                                            no words. one only: amazing!
                                            +thank you
                                            hire me@ http://www.publied.it !
                                            • 22
                                            • 23
                                            • 3 / 23
