    [Plugin] ToolbarBuilder
    32 Posts 9 Posters 4.5k Views 9 Watching
    • panixiaP
      panixia
      mmm.. going on with testing and it only loaded the first toolbar i saved.. now it refuses to load others.. moreover it refuses to load the toolbar editor.. 😞
        RickW
        @krisidious said:
        what will happen with icons? if a plugin does not have icons can we make them?
        Assigning custom icons is a planned update, but it can be done manually by editing the .toolbar file and adding the path to the icons (large & small).
        RickW
        www.smustard.com
          RickW
          @panixia said:
          so.. is it possible to have some "arrange buttons" functionality?
          thank you!
          That is a planned update, but you can do this manually by editing the .toolbar file.
          RickW
          www.smustard.com
            RickW
            @panixia said:
            mmm.. another huge downside i didn't notice.. is that when you close and reopen sketchup the custom toolbars aren't loaded at all! i also saved the toolbar position and tried to restore, but nothing happens.. one have to load each saved toolbars every time? that's quite annoying..
            It is noted in the description that in this initial release, toolbars must be manually loaded, but the first planned (free) update is to include an autoloader.
            RickW
            www.smustard.com
              RickW
              @jorge2011 said:
              Thank you very much for this plugin.
              I installed this plugin and generates the following error:
              ToolbarBuilder callback: build
              Error: wrong argument type # <TypeError: (expected Sketchup::Command)>
              C 😕 Program Files (x86) / Google / Google SketchUp 8/Plugins/ToolbarBuilderFree.rb: 251: in add_item ' C :/ Program Files (x86) / Google / Google SketchUp 8/Plugins/ToolbarBuilderFree.rb: 251: in create_html '
              C 😕 Program Files (x86) / Google / Google SketchUp 8/Plugins/ToolbarBuilderFree.rb: 251: in each ' C :/ Program Files (x86) / Google / Google SketchUp 8/Plugins/ToolbarBuilderFree.rb: 251: in create_html '
              You can fix it?
              thank you very much
              It seems these are related. I'm looking into it and will issue a fix ASAP.
              RickW
              www.smustard.com
                RickW
                The issue has been resolved and the file uploaded. Your previous download link will now pull down the updated file.
                RickW
                www.smustard.com
                • F
                  function
                  this is great, i've had so many problems with skp 'remembering' my tool positions. the toolbar nightmare is over! looking forward to the updates - maybe consider an "add spacer" so tools can be grouped visually. thanks rick
                    RickW
                    The current problem with autoloading the custom toolbars is that they depend on commands created by other plugins, and there's no guarantee that those commands will have been created when ToolbarBuilder is loaded by SketchUp and tries to build its toolbars. The benefit is having the toolbar position remembered, the drawback is missing buttons.
                    One solution is to have a button for a 1-click loader that will load all custom toolbars after SketchUp is fully launched and all .rb/s files are loaded. The benefit is all buttons load into the toolbar, the drawback is toolbar positions are not remembered.
                    The other solution (and I think the final answer for now) is a hybrid - autoload at launch creates empty toolbars (with the saved positioning), and a single button on the Smustard toolbar loads all custom toolbars after launch is complete.
                    Any input on this solution?
                    RickW
                    www.smustard.com
                    • KrisidiousK
                      Krisidious
                      I have an input on that solution... Where is my invoice? I can't find it.
                      By: Kristoff Rand
                      • panixiaP
                        panixia
                        i don't know how it works, i've been using this for quite a while and it works fine, and the toolbars keep the saved position.. but it loads only native tools.. 😒
                        http://sketchucation.com/forums/viewtopic.php?t=10041
                          Aerilius
                          Jim's custom toolbars create "clones" of the native tools. Immediately after they have been created, he adds them to toolbars.
                          The problem with custom toolbars from other plugins is not to add them too early (when commands are missing) and not too late (when SketchUp doesn't remember the toolbar's last position).
                          • F
                            function
                            pressing the save button does nothing for me 😕
                            • renderizaR
                              renderiza
                              If you have SketchUp Free Version you might need to do this...
                              1. Open your default Plugin Folder.
                              2. Make New Folder with name "Toolbars"
                              3. Try Plugin Again.
                              Cheers!
                              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                              • F
                                function
                                ah that did it! thanks
                                  Check you have FULL read/write security permissions to the Plugins folder, the manual creation of the subfolder might have fixed it for now but without FULL rights you will get problems with some scripts...
                                  • H
                                    hebeijianke
                                    Hope it can support chinese language
                                    add some strings
                                    <!DOCTYPE html>
                                    <html lang="en-US">
                                    <head>
                                    [highlight=#ff4040:2056xzo0]<meta http-equiv="content-type" content="text/html;charset=utf-8">[/highlight:2056xzo0]
                                    	<title>Smustard ToolbarBuilder</title>
                                    	<style type="text/css">
                                      RickW
                                      Version 1.0.2 is now uploaded. I added a third button that loads all saved custom toolbars with a single click.
                                      The problem with generating the buttons at SU launch is that not all .rb files have been loaded when ToolbarBuilder loads, and thus some commands have not been created. This causes errors when the plugin attempts to create the buttons. I will continue to explore possible resolutions to this issue.
                                      RickW
                                      www.smustard.com
                                      • KrisidiousK
                                        Krisidious
                                        How do we make custom bars for plugins that are not listed?
                                        By: Kristoff Rand
                                          RickW
                                          I'll have to investigate that one. Right now, the plugin queries Toolbars and Command items to generate its list of items for customization. I'll have to see if there's a way to query (usually older) plugins that don't use the Command structure for creating their menu items.
                                          EDIT: Are there any in particular that you don't see?
                                          RickW
                                          www.smustard.com
                                          • KrisidiousK
                                            Krisidious
                                            The one's I'm interested in making toolbars for are SDM tools, Vali Architect and ThomThom's many plugins
                                            By: Kristoff Rand
