    [Plugin] ToolbarBuilder
    32 Posts 9 Posters 2.9k Views 9 Watching
      RickW
      The current problem with autoloading the custom toolbars is that they depend on commands created by other plugins, and there's no guarantee that those commands will have been created when ToolbarBuilder is loaded by SketchUp and tries to build its toolbars. The benefit is having the toolbar position remembered, the drawback is missing buttons.
      One solution is to have a button for a 1-click loader that will load all custom toolbars after SketchUp is fully launched and all .rb/s files are loaded. The benefit is all buttons load into the toolbar, the drawback is toolbar positions are not remembered.
      The other solution (and I think the final answer for now) is a hybrid - autoload at launch creates empty toolbars (with the saved positioning), and a single button on the Smustard toolbar loads all custom toolbars after launch is complete.
      Any input on this solution?
      RickW
      www.smustard.com
      • KrisidiousK Offline
        Krisidious
        I have an input on that solution... Where is my invoice? I can't find it.
        By: Kristoff Rand
        • panixiaP Offline
          panixia
          i don't know how it works, i've been using this for quite a while and it works fine, and the toolbars keep the saved position.. but it loads only native tools.. 😒
          http://sketchucation.com/forums/viewtopic.php?t=10041
            Aerilius
            Jim's custom toolbars create "clones" of the native tools. Immediately after they have been created, he adds them to toolbars.
            The problem with custom toolbars from other plugins is not to add them too early (when commands are missing) and not too late (when SketchUp doesn't remember the toolbar's last position).
            • F Offline
              function
              pressing the save button does nothing for me 😕
              • renderizaR Offline
                renderiza
                If you have SketchUp Free Version you might need to do this...
                1. Open your default Plugin Folder.
                2. Make New Folder with name "Toolbars"
                3. Try Plugin Again.
                Cheers!
                [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                • F Offline
                  function
                  ah that did it! thanks
                    Check you have FULL read/write security permissions to the Plugins folder, the manual creation of the subfolder might have fixed it for now but without FULL rights you will get problems with some scripts...
                    • H Offline
                      hebeijianke
                      Hope it can support chinese language
                      add some strings
                      <!DOCTYPE html>
                      <html lang="en-US">
                      <head>
                      [highlight=#ff4040:2056xzo0]<meta http-equiv="content-type" content="text/html;charset=utf-8">[/highlight:2056xzo0]
                      	<title>Smustard ToolbarBuilder</title>
                      	<style type="text/css">
                        RickW
                        Version 1.0.2 is now uploaded. I added a third button that loads all saved custom toolbars with a single click.
                        The problem with generating the buttons at SU launch is that not all .rb files have been loaded when ToolbarBuilder loads, and thus some commands have not been created. This causes errors when the plugin attempts to create the buttons. I will continue to explore possible resolutions to this issue.
                        RickW
                        www.smustard.com
                          Krisidious
                          How do we make custom bars for plugins that are not listed?
                          By: Kristoff Rand
                            RickW
                            I'll have to investigate that one. Right now, the plugin queries Toolbars and Command items to generate its list of items for customization. I'll have to see if there's a way to query (usually older) plugins that don't use the Command structure for creating their menu items.
                            EDIT: Are there any in particular that you don't see?
                            RickW
                            www.smustard.com
                              Krisidious
                              The one's I'm interested in making toolbars for are SDM tools, Vali Architect and ThomThom's many plugins
                              By: Kristoff Rand
                                RickW
                                Version 1.0.3 is now online, which has full autoloading of saved toolbars at launch, and they remember their positions!
                                Now to investigate Krisidious's request...
                                RickW
                                www.smustard.com
                                • panixiaP Offline
                                  panixia
                                  i can't see the wire tool button
                                  • F Offline
                                    function
                                    Having trouble saving in the new version. I did a clean install of the new sketchup, upgraded to IE 10, turned off all firewalls and made sure the folders all have full read/write. The new version also does not show ordinary sketchup commands.
                                      RickW
                                      That is correct. It can only address Ruby commands created with UI::Command. Plugins that do not use this (i.e., they create menu items only), will not be available. This is a limitation of the Ruby API.
                                      RickW
                                      www.smustard.com
                                        RickW
                                        Strange, it appears on my machine. Try opening the Ruby console before launching the WebDialog and see if there are any messages.
                                        WebDialog
                                        Resulting Toolbar
                                        RickW
                                        www.smustard.com
                                        • F Offline
                                          function
                                          can't save to Toolbars folder
                                          ToolbarBuilder callback ; save
                                          Error; #<NameError; undefined local variable or method `d' for #<Smustard;;ToolbarBuilder;0xb369--->>
                                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ToolbarBuilderPro.rb;283;in `write_file'
                                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ToolbarBuilderPro.rb;258;in `create_html'
                                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ToolbarBuilderPro.rb;283;in `call'
                                            RickW
                                            I'll look into it.
                                            EDIT: fixed (had a variable left over from command line testing, converted it to the "real" variable).
                                            Download 1.0.5 for the fix.
                                            RickW
                                            www.smustard.com
                                            • 2 / 2
