    [Plugin] ToolbarBuilder
    32 Posts 9 Posters 3.3k Views 9 Watching
      RickW
      The issue has been resolved and the file uploaded. Your previous download link will now pull down the updated file.
      RickW
      [www.smustard.com](http://www.smustard.com)
      • F Offline
        function
        this is great, i've had so many problems with skp 'remembering' my tool positions. the toolbar nightmare is over! looking forward to the updates - maybe consider an "add spacer" so tools can be grouped visually. thanks rick
          RickW
          The current problem with autoloading the custom toolbars is that they depend on commands created by other plugins, and there's no guarantee that those commands will have been created when ToolbarBuilder is loaded by SketchUp and tries to build its toolbars. The benefit is having the toolbar position remembered, the drawback is missing buttons.
          One solution is to have a button for a 1-click loader that will load all custom toolbars after SketchUp is fully launched and all .rb/s files are loaded. The benefit is all buttons load into the toolbar, the drawback is toolbar positions are not remembered.
          The other solution (and I think the final answer for now) is a hybrid - autoload at launch creates empty toolbars (with the saved positioning), and a single button on the Smustard toolbar loads all custom toolbars after launch is complete.
          Any input on this solution?
          RickW
          • KrisidiousK Offline
            Krisidious
            I have an input on that solution... Where is my invoice? I can't find it.
            By: Kristoff Rand
            • panixiaP Offline
              panixia
              i don't know how it works, i've been using this for quite a while and it works fine, and the toolbars keep the saved position.. but it loads only native tools.. 😒
              http://sketchucation.com/forums/viewtopic.php?t=10041
                Aerilius
                Jim's custom toolbars create "clones" of the native tools. Immediately after they have been created, he adds them to toolbars.
                The problem with custom toolbars from other plugins is not to add them too early (when commands are missing) and not too late (when SketchUp doesn't remember the toolbar's last position).
                • F Offline
                  function
                  pressing the save button does nothing for me 😕
                  • renderizaR Offline
                    renderiza
                    If you have SketchUp Free Version you might need to do this...
                    1. Open your default Plugin Folder.
                    2. Make New Folder with name "Toolbars"
                    3. Try Plugin Again.
                    Cheers!
                    [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                    • F Offline
                      function
                      ah that did it! thanks
                        Check you have FULL read/write security permissions to the Plugins folder, the manual creation of the subfolder might have fixed it for now but without FULL rights you will get problems with some scripts...
                        • H Offline
                          hebeijianke
                          Hope it can support chinese language
                          add some strings
                          <!DOCTYPE html>
                          <html lang="en-US">
                          <head>
                          [highlight=#ff4040:2056xzo0]<meta http-equiv="content-type" content="text/html;charset=utf-8">[/highlight:2056xzo0]
                          	<title>Smustard ToolbarBuilder</title>
                          	<style type="text/css">
                            RickW
                            Version 1.0.2 is now uploaded. I added a third button that loads all saved custom toolbars with a single click.
                            The problem with generating the buttons at SU launch is that not all .rb files have been loaded when ToolbarBuilder loads, and thus some commands have not been created. This causes errors when the plugin attempts to create the buttons. I will continue to explore possible resolutions to this issue.
                            RickW
                              Krisidious
                              How do we make custom bars for plugins that are not listed?
                              By: Kristoff Rand
                                RickW
                                I'll have to investigate that one. Right now, the plugin queries Toolbars and Command items to generate its list of items for customization. I'll have to see if there's a way to query (usually older) plugins that don't use the Command structure for creating their menu items.
                                EDIT: Are there any in particular that you don't see?
                                RickW
                                  Krisidious
                                  The one's I'm interested in making toolbars for are SDM tools, Vali Architect and ThomThom's many plugins
                                  By: Kristoff Rand
                                    RickW
                                    Version 1.0.3 is now online, which has full autoloading of saved toolbars at launch, and they remember their positions!
                                    Now to investigate Krisidious's request...
                                    RickW
                                    • panixiaP Offline
                                      panixia
                                      i can't see the wire tool button
                                      • F Offline
                                        function
                                        Having trouble saving in the new version. I did a clean install of the new sketchup, upgraded to IE 10, turned off all firewalls and made sure the folders all have full read/write. The new version also does not show ordinary sketchup commands.
                                          RickW
                                          That is correct. It can only address Ruby commands created with UI::Command. Plugins that do not use this (i.e., they create menu items only), will not be available. This is a limitation of the Ruby API.
                                          RickW
                                            RickW
                                            Strange, it appears on my machine. Try opening the Ruby console before launching the WebDialog and see if there are any messages.
                                            WebDialog
                                            Resulting Toolbar
                                            RickW
